DIY: Sway Bar End Link Bushing Replacement - Page 2 - Scion xB Forum
post #21 of 66 Old 11-25-2006, 09:59 PM Thread Starter
Quoted: 1 Post(s)
surfcitylocal will become famous soon enough surfcitylocal will become famous soon enough
Just read all the posts and the only thing I can tell you about the spacer is that if you use one with the 4" bolt it won't fit. There isn't enough thread left over to make a secure fitment of the nylon nut. The bushings don't compress as much as the stock ones so the measurements you see in the side by side photo are what you have when they are installed. I have no difference in spacing between the bar and the end link since installing the new ones. I drove about 50 miles today and had no trouble or noise, the handling was fine. If anyone uses the 4" bolt with a spacer let me know how it turns out.
FUSCION Yes, I saw you dance. No, I don't have a dollar
Haole: I live on the Mainland but my heart is in Hawaii.
post #22 of 66 Old 11-26-2006, 12:12 PM
Quoted: 2 Post(s)
Alright I attempted to use what I had and ran into some difficulties. The set-up I got was bigger than I thought. I was still able to use them though, by moving the spacer to the underside of the control arm. I will be cutting the spacer in half and getting it where it goes. But this will work for now.
If I was able to get it in, the top of the bolt would hit the axle. But half the spacer should work. With no spacer, it did shorten the space between the Control arm and the Sway bar making them less stiff, so they are definatally in need of atleast a 1/4" spacer to get them back to normal specs. I will try to get a half inch in for a little more tention. It will be a few days till I get a chance to do it though.
ID:	3962   Click image for larger version
-------------->>>>>Padanky Customz<<<<<--------------
Padanky Grille Owners Club
Big_Kokujin(4!), Surfcitylocal sold to Dion!, Dajap, eE, Spamcan, Uthamandan (RIP), Iron_Lion_Scion(2), Dooby, Hanakepa, Moonray, Simijoecool, Padanky, Djfookyu, Toyota_bB, Caden Stargate, Squirrel, poru_no_hako_desu(2), 8Thousand, TOAST3R, 06Box, familyguy96782, Silvertoast, jcoyne1979, AllWheelDeal, kanakahaole, equinescion, Lifex, Elsion, ?.
Padanky is offline
post #23 of 66 Old 11-26-2006, 02:46 PM
hayalex6's Avatar
Quoted: 0 Post(s)
hayalex6 is on a distinguished road
Send a message via AIM to hayalex6
So basically what you have now is the same thing as just having no spacer, but a longer bolt lol. Good luck with shorter spacer.
hayalex6 is offline
post #24 of 66 Old 11-26-2006, 03:10 PM
polarproject's Avatar
Quoted: 0 Post(s)
polarproject is on a distinguished road
Send a message via AIM to polarproject
what are the benefits of this??? smoother ride? improved handling?
polarproject is offline
post #25 of 66 Old 11-26-2006, 04:27 PM
hayalex6's Avatar
Quoted: 0 Post(s)
I don't really know, I didn't notice too much. I just wanted to replace the stock ones after looking at them.
hayalex6 is offline
post #26 of 66 Old 11-26-2006, 04:30 PM
Quoted: 2 Post(s)
Pretty much, and no extra cost on new bolts and no extra trips. Definitely needs spacers though, the space between the bar and control arm is about 1/4 - 1/2 shorter, so it will probably lean just as much as before to make up for that difference.
Padanky is offline
post #27 of 66 Old 11-26-2006, 04:31 PM
Quoted: 2 Post(s)
Less lean, better handling.
Padanky is offline
post #28 of 66 Old 11-26-2006, 11:47 PM Thread Starter
Quoted: 1 Post(s)
It was a busy day here at Casa de TAZ, I replaced the sway bar bushings on three more Boxes. Rodney (hawaiianbuilt), Kurt & Kurt (ocxb) and Pat (Cravin) came by the house and we changed out everyone's old sway bar bushings.
Kurt got into the act on his Box.
Here's the left overs from the change outs...
Everyone noticed an improvement in handling and less play in the steering. I highly recommend this mod. For the cost, the results are awesome!
post #29 of 66 Old 11-26-2006, 11:53 PM
Quoted: 2 Post(s)
I found this on there site. It looks like my bar and control arm are parallel, but I know it's not the same spacing it was before.
ID:	3981   Click image for larger version
Padanky is offline
post #30 of 66 Old 11-27-2006, 12:39 AM Thread Starter
Quoted: 1 Post(s)
If you're still having trouble lining this up you could measure the distance of someone's who hasn't made the change and then size it up with yours.
post #31 of 66 Old 11-27-2006, 12:42 AM
Quoted: 97 Post(s)
DTRAIN619 is a jewel in the rough DTRAIN619 is a jewel in the rough DTRAIN619 is a jewel in the rough
Garage
*Watching with earnest...*
post #32 of 66 Old 11-27-2006, 12:51 AM
xjeepguy's Avatar
Quoted: 0 Post(s)
xjeepguy is on a distinguished road
Normally that would be while the car is sitting on the ground under it's own weight at normal ride height. It would change from parallel then.
Matt
Laws that forbid the carrying of arms... disarm only those who are neither inclined nor determined to commit crimes. ...Such laws make things worse for the assaulted and better for the assailants; they serve rather to encourage than to prevent homicides, for an unarmed man may be attacked with greater confidence than an armed man.
Thomas Jefferson.
xjeepguy is offline
post #33 of 66 Old 11-27-2006, 01:03 AM
Quoted: 0 Post(s)
when i get my ride back i am next to go to taz's garage o tune up for xb's
need 411 on wear to get the parts for the sway bar bushings plz pm me if you can thanks
short bus is offline
post #34 of 66 Old 11-27-2006, 01:03 AM Thread Starter
Quoted: 1 Post(s)
How is old Earnest doing? Does he enjoy watching with you?
post #35 of 66 Old 11-27-2006, 01:28 AM
Cravin's Avatar
Quoted: 0 Post(s)
Dave its an off the shelf Autozone item, PLUS you get to go to HOME DEPOT too for the nuts and bolts! USDM CHOICE!
<a href=https://www.clubxb.com/forums/signaturepics/sigpic585_1.gif target=_blank>https://www.clubxb.com/forums/signat...igpic585_1.gif</a>
“Klaatu barada nikto.”
Cravin is offline
post #36 of 66 Old 11-27-2006, 01:29 AM Thread Starter
Quoted: 1 Post(s)
PM sent, when the ride is home stop on by and I'll do you up right! Choice!
post #37 of 66 Old 11-27-2006, 01:32 AM
Quoted: 0 Post(s)
A BIG CHOICE THANKS
post #38 of 66 Old 11-27-2006, 07:10 AM
Ain't too Funk to Druck.
Quoted: 5 Post(s)
ketchup_xb will become famous soon enough ketchup_xb will become famous soon enough
damn. all the talk of greased nuts and bush-ings. LOL.
HelaFassDooo
Thank you my HFD family from the bottom of my<3 for the rack!
2ZERO6FACTORY.COM
[B][COLOR="Cyan"]
ketchup_xb is offline
post #39 of 66 Old 11-27-2006, 08:04 AM
Quoted: 2 Post(s)
I didn't think about that, thanks.
TAz, they went right in once I figured out how to make them work. Second side took a whole 3 min. to get on and tight.
Padanky is offline
post #40 of 66 Old 11-27-2006, 08:42 AM Thread Starter
Quoted: 1 Post(s)
Cool! Did you use the spacer? And the bolt that came with the set?
