Rear Trailing Arm Bushing Replace-2006 xB - Scion xB Forum
post #1 of 2 Old 08-29-2017, 11:12 AM Thread Starter
Quoted: 0 Post(s)
brymul is on a distinguished road
After reading up on this (links below), I decided to go with the stock bushings for replacement. My box has 130k and the bushings are rotted and squeaking. My question is about the install. I have access to a hand press and am wondering if I would still need to drop the axle completely to get them installed. In the CLUBxB thread posted below, 859Toaster stated:
"There are also hand presses available for use. We use them at work when lugging a giant gear box over to the press is too much. Which would just require dropping the bolts and letting the shocks hold it in place."
Does this mean that I can do this by ONLY removing the two axle bolts that go through the bushings? Any other thoughts or guidance about this? Thanks!
https://www.clubxb.com/forums/scion-x...placement.html
https://www.scionlife.com/forums/sci...s-xa-xb-26773/
brymul is offline
post #2 of 2 Old 09-04-2017, 01:17 AM Thread Starter
Quoted: 0 Post(s)
Re: Rear Trailing Arm Bushing Replace-2006 xB
Seriously, anyone know what will happen if I just remove the two axle beam bolts that go through the bushings?
brymul is offline
