Need all torque specs, to replace both sides cv axle, Auto Trans. 30MM Nut, tie rod ends, all info. I seen specs on 2010 scion tc, but nothing on 2006 xb, are they the same?
Thank you.
---------- Post added 08-14-2017 at 04:32 PM ----------
Sorry, the specs are for 2013 scion tc, not 2010, Are they the same as 2006 scion xb?
Late reply is late, but if you still needed the info, as per the FSM:
30mm 12 point Axle Nut: 159ft/lbf
Lower Control Arm Balljoint Nut: 72ft/lbf
Tie Rod End Nut: 36ft/lbf
Brake Line Bracket Nut: 22ft/lbf
Stabilizer Bar Nut: 13ft/lbf
Should be noted that the 30mm Axle Nut and all cotter pins/nut clips are spec'd as non-reusable.
When I did both axle's on my 06 about a month and a half ago, I did not undo the lower control arm, just the tie rod ends and brake line and was able to get the axles out and shimmy the new ones in with a little bit of elbow grease and persuasion. Ended up reusing the 30mm nut, but replaced the cotter pins while I was at it, haven't had an issue yet.
I have a 2006 Scion xB and a 30mm did not work, we used and inch and a quarter.
Related Threads
Scion xB Forum
1.1M posts
33.6K members
Since 2005
