HELP Wobbling sound/offcenter? bumpy ride after coil over install - Scion xB Forum
post #1 of 10 Old 08-21-2016, 04:20 PM Thread Starter
ghostxdm's Avatar
Quoted: 7 Post(s)
ghostxdm is on a distinguished road
I have a wobbling sound that gets louder at higher speeds. It feels like a wheel is off center perhaps? so you can feel the wobble or bumpiness at slow and high speeds and it gets louder at highways speeds. The sound and wobbly bumpy ride came after the coil overs were installed. I Also replaced the passenger cv axle at that same time. Not sure if the replacement axle could be the problem?
Really can't figure out what it is. I thought it could be a wheel bearing but when i lifted the car up i didn't feel any wiggle and its hard to listen for grinding or where the sound is coming from with the exhaust.. Kinda freaked out what it could be. I did get an alignment after i installed the coil overs and stuts. HELP PLEASE If anyone has any ideas of things i can test or experience with similar problems it would be appreciated. Also the wheels and tires drove fine before the coil over install so i don't feel like its a balancing issue. thanks
ghostxdm is offline
post #2 of 10 Old 08-21-2016, 05:17 PM
wagonbldr's Avatar
Quoted: 224 Post(s)
Do your wheels have hub centric rings? Maybe one stayed on hub and wheel didn't bolt up square when reinstalled. Just thinking outside the box.
wagonbldr is offline
post #3 of 10 Old 08-21-2016, 06:57 PM
Dead box
yesthatsteve's Avatar
Quoted: 95 Post(s)
yesthatsteve is on a distinguished road
Garage
Re: HELP Wobbling sound/offcenter? bumpy ride after coil over install
Did you get an alignment after installing the coilovers and CV axle? If not, that could be your problem.
Suit the action to the word, the word to the action.
-Shakespeare
yesthatsteve is offline
post #4 of 10 Old 08-22-2016, 09:34 PM Thread Starter
ghostxdm's Avatar
Quoted: 7 Post(s)
ya i did get an alignment after i installed the coils and axle... that was the first thing i thought it could be:\
---------- Post added 08-23-2016 at 01:37 AM ----------
and hmmm wagonbldr you know im not too sure ill have to look into that. Is there a special way to insert those rings?
---------- Post added 08-23-2016 at 06:45 PM ----------
So i checked wagonbldr and i am missing rings on my back wheels. wich is still odd because i havent changed anything with the wheels since i bought the car. and it ran smooth before with the rear hub rings missing??! i checked all the wheels just now and i tightened them in the air so they hopefully centered when i dropped it to the floor to do the final tightening.
i drove around and still felt it obviously... so im definitely going to buy two more matching hub rings for the back and hit the freeway to see if that helps cuz that did make tons of sense xD. im hoping it's that easy but PLEASE ANY MORE SUGGESTIONS WILL help. :[[[[ i dont think the rings are the solution but the rings were great advice!! derpsdfgsdf thanks wagonbldr!!
ghostxdm is offline
post #5 of 10 Old 08-24-2016, 04:47 AM
wagonbldr's Avatar
Quoted: 224 Post(s)
I just remembered someone with a similar issue where the ring stayed on the hub and the wheel they put on had a ring still on it. When they tightened it up it was a lil cockeyed and had similar symptoms. Wheels that use tapered seat nut are supposed to be self centering. Those that use a flat seated nut require the hub rings to center the wheel. Found out hard ways several years back.
post #6 of 10 Old 08-25-2016, 01:43 AM Thread Starter
ghostxdm's Avatar
Quoted: 7 Post(s)
awwww ya i was good on not doubling up on rings. im still going to get two more cuz i dont understand why the previous owner only had two on. could bent lug bolts cause the same problem?! making the wheel not seat properly. another wierd probability cuz this wasnt a problem till the axle and coils were installed. ill get those rings on hopefully by this weekend and keep you updated. thanks wagonbldr
ghostxdm is offline
post #7 of 10 Old 09-04-2016, 02:40 PM Thread Starter
ghostxdm's Avatar
Quoted: 7 Post(s)
FOUND OUT WHAT IT WAS GUYS! T_T
upon further inspection i got it dialed down to being the driver front wheel. I was tryna figure out if it was a problem from something installed improperly or if it was just a wheel and tire. i swapped the front wheel and put it to the back yesterday and BAM!! vibration moved to the back. i inspected the tire and it has a small bump. tiny tiny bump where the tread is raised and the front ran SMOOTH.
So all i need is a new tire... thinking about hitting up a used tire place for a temporary fix. I think this is a sign for me to buy the new 15's i wanted and some matching rubber
ghostxdm is offline
post #8 of 10 Old 09-04-2016, 03:08 PM
Dead box
Quoted: 95 Post(s)
Garage
That would do it, definitely! Thanks for following up.
-Shakespeare
post #9 of 10 Old 09-04-2016, 04:11 PM Thread Starter
ghostxdm's Avatar
Quoted: 7 Post(s)
yesthatsteve hahah i feel so stupid now!! Such a simple thing i swore it couldn't have been that so i didn't even take time to check. So much relief now knowing its just a tire I knew my coilover and axle install was solid. Time to move on
ghostxdm is offline
post #10 of 10 Old 09-04-2016, 07:38 PM
wagonbldr's Avatar
Quoted: 224 Post(s)
Glad it was something simple
RS 2.0 #923
RS 7.0 #528
Just another Wonderful day in Paradise, now watch some SOB try to ruin it.
