Lightweight pulleys - Scion xB Forum
 1Likes
  • 1 Post By GregS
post #1 of 7 Old 04-03-2018, 01:01 PM Thread Starter
Quoted: 0 Post(s)
markster33139 is on a distinguished road
Lightweight pulleys
I have already installed the Agency Power crank pulley, but I couldn't find any other available pulleys for the alternator etc only for 1st generation Xb and TC. Does anyone know if these are available for the 2nd generation, assuming that the TC pulleys are not compatible with the Xb. Thanks.
Sent from my ONEPLUS A5000 using Tapatalk
markster33139 is offline
post #2 of 7 Old 04-03-2018, 05:01 PM
Lots o leather and copper
GregS's Avatar
Quoted: 70 Post(s)
Re: Lightweight pulleys
The 1st gen tC and 2nd gen xB share the same engine and pulleys so ones designed for the tC should work fine on the xB. Usually the only reason to change the other pulleys is if you have gone with an undersized crank pulley to make sure the accessories are operating at the same RPM they were before. Since you went with an Agency Power pulley, which keeps the stock diameter, there really is no need to change the other pulleys. It won't hurt to change them if they are the same diameter as stock but if they are larger, which they would be to compensate for a smaller crank pulley, then you would be over-driving the alternator. The other reason you aren't seeing other pulleys for the xB is that it uses an electric power steering unit so there is not power steering pump pulley to replace.
dubeexb06 likes this.
FB & IG : Steelpunkxb
GregS is offline
post #3 of 7 Old 04-03-2018, 05:03 PM Thread Starter
Quoted: 0 Post(s)
Thank you and understood
post #4 of 7 Old 10-22-2018, 11:56 AM
A Flawed Perspective
bigmarv_05's Avatar
Quoted: 9 Post(s)
bigmarv_05 is on a distinguished road
Garage
What's the benefit of a lightweight pulley?
bigmarv_05 is offline
post #5 of 7 Old 10-22-2018, 02:33 PM
GregS's Avatar
Quoted: 70 Post(s)
Less mass for the engine to turn so more power able to go the the wheels. It might add a whole 2 hp.
GregS is offline
post #6 of 7 Old 10-22-2018, 02:46 PM
bigmarv_05's Avatar
Quoted: 9 Post(s)
Garage
The epic gains in power aside.... is it worth the investment and time to install? While my box is definitively climbing in mileage, and while I certainly contradict myself, I like the idea of taking stress off the motor where I can. I contradict myself because at the same time I'm looking into small performance mods.
post #7 of 7 Old 10-22-2018, 02:54 PM
GregS's Avatar
Quoted: 70 Post(s)
For the $130-150 it costs to get one new, no I don't think it's worth it. i managed to get one used a while back and for the $60 I paid I felt that was worth it, mainly for the little extra pep you feel off the line.
GregS is offline
