DIY: Gen1 M/T Non Slapstick for Auto Mod - Scion xB Forum
post #1 of 7 Old 03-29-2014, 02:05 PM Thread Starter
SHABBY3's Avatar
Quoted: 3 Post(s)
SHABBY3 is on a distinguished road
This writeup will be based off my other DIY tutorial I posted back in 2011.
https://www.clubxb.com/forums/showthread.php?t=40142
My problem with my last mod. The last tech that drove my car broke my shifter. He didn't press down and applied to much pressure and broke the inner plastic in the shifter mechanism.
Here is what it looks like after I fixed it.
It works just like before but with a different design. Press down to put car in gear.
Up position.
Pressed down position to put in gear.
Here is how it's done.
I started by cutting off the inner plastic rod flush with the outer metal rod with a dremel.
Then I took a drill bit and hollowed out about 2 to 3 inches of the inner plastic rod. Be careful with this step. Go nice and slow to prevent melting the plastic rod.
My knob came with three different adapters for different size shifters. I used the biggest size.
Test fit the bolt to make sure it slips nicely into the metal shifter shaft. I think mine was M10 125
Once you have the right size bolt measure the length your bolt needs to be. There needs to be 1/4" to 1/2" of movement to push down your shifter to put the car in drive.
Cut the head off your bolt to length. I used a dremel.
That's about it. This is a very sturdy way to do it and gives you the freedom to switch shift knobs as often as you like!
---------- Post added 03-29-2014 at 04:59 PM ----------
I just realized that I posted the wrong photo for the down position.
Follow my VIP styled Build
SHABBYS Build
SHABBY3 is offline
post #2 of 7 Old 03-30-2014, 11:48 PM
EquisBe's Avatar
Quoted: 43 Post(s)
EquisBe is on a distinguished road
Garage
Re: DIY: Gen1 M/T Non Slapstick for Auto Mod
Nice write up bro, I know what I'm doing after next payday
---------- Post added 03-30-2014 at 09:49 PM ----------
What was the total length of bolt once you trimmed it down?
IG: 05BLUEBOX
Cajitas Bajitas C.C.
"Lil Lowered Boxes"
EquisBe is offline
post #3 of 7 Old 05-29-2014, 08:56 PM
ToddMS's Avatar
Quoted: 15 Post(s)
ToddMS is on a distinguished road
I think it will depend on how far down you drill in step 2.
ToddMS is offline
post #4 of 7 Old 05-29-2014, 09:02 PM Thread Starter
SHABBY3's Avatar
Quoted: 3 Post(s)
Yeah, it all depends how for you drill down. You should drill down about 3 inches.
SHABBYS Build
SHABBY3 is offline
post #5 of 7 Old 05-29-2014, 09:04 PM
Quoted: 0 Post(s)
jnaram is on a distinguished road
Is there a way to get a longer bolt about 1'-2' long? I wanna do mine pretty high
Sent from my SCH-I535 using Tapatalk
jnaram is offline
post #6 of 7 Old 05-29-2014, 09:08 PM Thread Starter
SHABBY3's Avatar
Quoted: 3 Post(s)
My bolt was about 5 inches. Snoop around your local hardware store or order the length you need online.
SHABBYS Build
SHABBY3 is offline
post #7 of 7 Old 05-29-2014, 09:44 PM
ToddMS's Avatar
Quoted: 15 Post(s)
Or put a smaller/sturdier bolt in and attach an extension.
Sent from my iPhone using Tapatalk
ToddMS is offline
