DIY - Modified Door Locks - Scion xB Forum
post #1 of 18 Old 07-24-2013, 02:33 PM Thread Starter
jx1379's Avatar
Quoted: 0 Post(s)
jx1379 will become famous soon enough
Finally got tired of smacking my arm on them and not being able to put my arm in that one sweet spot (for me at least) when cruising with arm out window due to door lock being in the way.
Asked around, searched a bit, and basically no info was found or shared. Soooo, i found a door lock i had laying around and practiced on it so when i went to do mine i wouldn't screw it up. Now for steps and pics on how i did it.
Tools i used:
Tape Measure
Masking Tape
Phillips Head Screwdriver
Flat Head Screwdriver
11/64 Drill Bit
Drill Press
stock door lock - unlocked
stock door lock - locked
pull plastic piece off by hand from the top - very little force is needed
remove phillips head screw from door handle
remove phillips head screw from cup handle
remove plastic retainer for door panel
on bottom of door panel you will feel a lip or edge to pull on - pull it with a little force (pictured is where the edge was for me to start pulling)
keep pulling till you are able to lift it up off the door panel rail where the glass slides up and down in track (keeping general terms to make it basic)
but dont pull it completely off, you still have to disconnect the wiring for the door panel switches.
plug is a 2 part plug - slide the locking clip on outer part of white harness plug and then pull the big plug out of panel (they dont separate its a 2 part plug if that makes sense)
once wiring is disconnected, set panel aside so it doesnt get scratched up by mishaps
what the door looks like w/o panel
now the fun part....you have to remove the lock by unscrewing it and then remove the white guide for the door lock rod
now put in the 11/64 drill bit in a press and manually turn it by hand to cut down on the possibilities of screwing it up. im sure a normal drill would work just fine and it really doesnt take alot of muscle to get the drill bit to drill thru the plastic door locks. the biggest problem that could happen is you bore it out using the wrong drill bit and its then too big to fit, or you use to small of a drill bit and it ends up cracking or breaking when threading it back onto the door lock rod
once i figured out which drill bit wouldn't mess up the door lock, i had to figure out how deep to drill it. screw measuring it with a tape measure for the right depth, i did it all by feel and to be honest it was the easiest way. the magic number for depth to drill was 1 1/4" (i started at an 1 1/8" and went bigger until it worked out thankfully it only took a couple tries)
locked and ready to go
hold the door lock in one hand and turn the drill with the other hand nice and slow so nothing gets messed up
all done....now to start reassembling everything the same way it came off
the finished product - unlocked
the finished product - locked
By far my favorite mod to date - amazing how something so simple can be in the way lol
jx1379 is offline
post #2 of 18 Old 07-24-2013, 03:25 PM
Doc
68WSTi's Avatar
Quoted: 0 Post(s)
68WSTi is on a distinguished road
Re: DIY - Modified Door Locks
I considered doing this mod but never got around to it. Great write-up!
68WSTi is offline
post #3 of 18 Old 07-24-2013, 06:10 PM
Abstract Ninja
Bamboo's Avatar
Quoted: 45 Post(s)
Bamboo is on a distinguished road
If it wasn't for booboos I would do this right now. Awesome writeup!
<--My Build
My Video Feature - Time Attack Photography
Follow me on instagram! - @rskimmel
Square Squad! - @thesquaresquad
Bamboo is offline
post #4 of 18 Old 07-24-2013, 06:37 PM
Quoted: 0 Post(s)
Barchulo is on a distinguished road
Nice mod...great DIY...lots of pics
Barchulo is offline
post #5 of 18 Old 07-24-2013, 06:37 PM
TTxB's Avatar
Quoted: 0 Post(s)
TTxB is on a distinguished road
First of all.
Very nice.
Don't get mad
However, if you are in an emergency situation and you need to pull the locks open manually.......yikes.
Also, given the inconsistency of the actuators, and their indifference to the cold, etc. you could really screw yourself only using the key fob.
After one look at this planet any visitor from outer space would say 'I want to see the manager.'
-William S. Burroughs
TTxB is offline
post #6 of 18 Old 07-24-2013, 07:00 PM Thread Starter
jx1379's Avatar
Quoted: 0 Post(s)
I would never get mad for someone offering their insight - hell I encourage it so I can make a worthy mod for others to enjoy as I do.
I see what you are saying and that thought never occurred to me, so from here on out I will keep my fingers crossed the actuators don't go out any time soon. The only other fall back I have is to not shave the handles and keep the one key lock on drivers door as a fail safe. As for the other door locks, I did make a tool to stick in between the lock and panel so I can pry it up to unlock in case that ever happens!
good looking out - thx
jx1379 is offline
post #7 of 18 Old 07-24-2013, 07:01 PM
Zman's Avatar
Quoted: 106 Post(s)
Zman will become famous soon enough Zman will become famous soon enough
Good point.
Could you just keep twisting them down by hand? I twisted mine another turn and added a piece of tape so they don't rattle at all anymore.
Zman is offline
post #8 of 18 Old 07-24-2013, 07:08 PM Thread Starter
jx1379's Avatar
Quoted: 0 Post(s)
You could but it only turns maybe 2 full rotations before it stops/bottoms out. In order to get as low as me you have to cut some stuff up haha. But seriously, the white door lock rod guide keeps it from going any lower so that's why I removed it to make it flush with the top of the door panel.
Also with this mod the door locks do not rattle at all or at least mine didn't, and I just redid my sub box and it hits harder than before and they still don't rattle.
Good call on the electrical tape Zach - might come in handy for others not wanting to go the whole nine yards for this mod!
jx1379 is offline
post #9 of 18 Old 07-24-2013, 07:34 PM
addicted
Quoted: 115 Post(s)
BigLobe will become famous soon enough
Im doing this. Thanks!
BigLobe is offline
post #10 of 18 Old 07-24-2013, 08:04 PM
Cantaloupe
dgoizo's Avatar
Quoted: 10 Post(s)
dgoizo is on a distinguished road
Wow awesome DIY!! Gonna have to do this one
@dgoizo - Livin' that bB Life
dgoizo is offline
post #11 of 18 Old 07-24-2013, 08:46 PM
TTxB's Avatar
Quoted: 0 Post(s)
TTxB is offline
post #12 of 18 Old 07-25-2013, 03:50 AM
Call Da Amberlamps!
Iateacricket's Avatar
Quoted: 4 Post(s)
Iateacricket is on a distinguished road
Send a message via AIM to Iateacricket Send a message via Yahoo to Iateacricket
Great write-up! I'll give this a go tomorrow, finally no more dent in my arm after long drives!
Originally Posted by shortbus_8 View Post
repo came to take mine back but they were looking for a 4 door
Iateacricket is offline
post #13 of 18 Old 07-25-2013, 04:41 AM
minkus
minkushxc's Avatar
Quoted: 1 Post(s)
minkushxc is on a distinguished road
I didn't do this but the previous owner must have mine sit flush when locked lol would have never known if it wasn't for this
Sent from my HTC_Amaze_4G using Tapatalk 2
minkushxc is offline
post #14 of 18 Old 07-26-2013, 04:49 AM
Zman's Avatar
Quoted: 106 Post(s)
I would totally do this if I didn't have booboo's. I have to hang my arm further forward when it's nice and sunny outside.
Zman is offline
post #15 of 18 Old 07-27-2013, 02:40 PM
Cantaloupe
dgoizo's Avatar
Quoted: 10 Post(s)
Just did it yesterday. Awesome mod!!! Mind if I post it over on bBsquad?
dgoizo is offline
post #16 of 18 Old 07-27-2013, 02:56 PM Thread Starter
jx1379's Avatar
Quoted: 0 Post(s)
Thanks and by all means plz do
jx1379 is offline
post #17 of 18 Old 07-27-2013, 03:23 PM
Tactical Toaster
LiquidSnak's Avatar
Quoted: 0 Post(s)
LiquidSnak will become famous soon enough
Might have to do this today
It's amazing what I learn when I get into it and figure it out. ~EquineScion
LiquidSnak is offline
post #18 of 18 Old 07-28-2013, 03:32 AM
imBOXY's Avatar
Quoted: 0 Post(s)
imBOXY is on a distinguished road
Sweet! I've always wanted to try this. Thanks for the DIY!
imBOXY is offline
