DIY: Universal Door Lock Actuator (Gen1 xB) - Scion xB Forum
post #1 of 17 Old 07-28-2011, 03:30 AM Thread Starter
Zman's Avatar
Quoted: 106 Post(s)
Zman will become famous soon enough Zman will become famous soon enough
Tools needed:
-Universal actuator (Can be found on Ebay, for around $5)
-2 screws to fasten actuator to backing plate.
-Screwdriver
-Drill with screwdriver attachment and small drill bit.
-X-acto knife
*Emergency tools, duct tape.
Kit includes:
actuator, backing plate, push rod, two metal screws, a clamp, and three small screws to fasten the rods together.
Step 1: Remove door panel
There are 2 screws, one in the handle, and one by the latch.
Pull panel off, and move up to clear door lock.
Pinch wire the connector off and set the panel aside.
(Now is a good time to install sound deadening material!)
Step 2: Attach metal plate to actuator.
I attached it the middle using a couple screws laying around since they weren't supplied.
Step 3: Test fit and make pilot holes into metal with a drill.
I had to stagger the bracket due to the shape of the hole in the door.
Step 4: Fasten bracket down with drill.
I used a backing piece to hold the screw on the left.
Step 5: Use supplied connector to attach the rods.
(This is the piece that failed me, the jolt from the unlocking door kept throwing the connector off. I found a not so permanent solution by making my own connector out of a small piece of metal and a screw and by also duct taping the rods together.)
My solution (don't laugh!)
Step 6: Remove wires from OEM actuator and splice into new actuator.
The blue/orange went to the green and the blue/black went to the blue in my case. Always test these out before crimping.
A simple butt connector works fine. I used wire nuts and some heatshrink for good measure, then shoved the wires in a hole to keep them from moving around.
Step 7: Test. The new rod should force the old one to move.
Step 8: Use Xacto knife to cut some of the yellow foam off the door panel to make it fit. One could also mount the actuator further back by using washers on the screw.
Step 9: Place door panel back on. Pop wire connector back on and check for clearance.
Should be good as new! I've had my xB for 4 years and have never had the back door unlock. It will take me some getting used to.
Zman is offline
post #2 of 17 Old 07-28-2011, 03:41 AM
slothead's Avatar
Quoted: 0 Post(s)
slothead will become famous soon enough slothead will become famous soon enough
Re: DIY: Universal Door Lock Actuator (Gen1 xB)
you are awesome. i gave up and paid to have mine replaced.
now. if you can find out why my back window won't roll down....
I Love HFD!
slothead is offline
post #3 of 17 Old 07-28-2011, 03:42 AM Thread Starter
Zman's Avatar
Quoted: 106 Post(s)
My right rear window wouldn't roll down for a few months, then this girl just held the button down in anger and it went down lol, and it's worked ever since.
My problem is that my windows rattle when halfway down, like the rubber trim isn't pushing on them enough.
Zman is offline
post #4 of 17 Old 07-28-2011, 03:45 AM
slothead's Avatar
Quoted: 0 Post(s)
hahahaha. oh i have tried that. believe me. my theory is that there is a short in the electrical circuit somewhere. My family has just gotten used to a can with three windows.
I Love HFD!
slothead is offline
post #5 of 17 Old 07-28-2011, 03:56 AM Thread Starter
Zman's Avatar
Quoted: 106 Post(s)
That sucks in AZ I bet. Why don't you have someone look at it?
Like a clubxBer?
Zman is offline
post #6 of 17 Old 07-28-2011, 04:02 AM
slothead's Avatar
Quoted: 0 Post(s)
i have. i have aaron's (blackbox's) actuator and motor in it and i have switched out the switches. Each time it works for a little while and then stops. btw i took this to the dealership a bunch of times while it was under warranty. They would fix it; it would work for a day or two, maybe even a few weeks, and then quit. grrrr.
they hate me.
i think it's haunted or something. or maybe it's hexed.
I Love HFD!
slothead is offline
post #7 of 17 Old 07-28-2011, 04:09 AM Thread Starter
Zman's Avatar
Quoted: 106 Post(s)
they hate me.
That sucks.
I can't think of why, may be a pinched wire or something.
Zman is offline
post #8 of 17 Old 07-28-2011, 08:45 AM
Quoted: 767 Post(s)
Great DIY there !!!!
dubeexb06 is offline
post #9 of 17 Old 07-28-2011, 09:17 AM
GET TO DA TOASTA!!!!!!!!!
hectarpit's Avatar
Quoted: 0 Post(s)
hectarpit is on a distinguished road
Send a message via AIM to hectarpit
DUUDEE!!! This is great thanks!! now to do it myself
hectarpit is offline
post #10 of 17 Old 07-28-2011, 10:03 PM Thread Starter
Zman's Avatar
Quoted: 106 Post(s)
Mines still working, so it passed the one day test haha.
I'm sure there's a metal bonding glue you could use underneath the duct tape. :P
Zman is offline
post #11 of 17 Old 07-28-2011, 10:09 PM
TTxB's Avatar
Quoted: 0 Post(s)
TTxB is on a distinguished road
great write up
I always thought it required an actuator with more than 2 wires.
Thanks for this info.
TTxB is offline
post #12 of 17 Old 07-29-2011, 12:22 AM
Quoted: 3 Post(s)
Congrats on making this work!!!
PCH is offline
post #13 of 17 Old 07-29-2011, 12:38 AM
Quoted: 0 Post(s)
adma89 is on a distinguished road
Great DIY! thanks!
adma89 is offline
post #14 of 17 Old 07-29-2011, 01:16 AM Thread Starter
Zman's Avatar
Quoted: 106 Post(s)
Thanks guys.
I really hope this helps some people out.
Zman is offline
post #15 of 17 Old 07-29-2011, 09:14 AM
Quoted: 767 Post(s)
Not some but alot of us !!!!
post #16 of 17 Old 07-30-2011, 07:24 AM
whitej47's Avatar
Quoted: 2 Post(s)
whitej47 will become famous soon enough whitej47 will become famous soon enough
Send a message via AIM to whitej47
I like complete write ups! Good job.
ETA= Soon enough...June '12, made it!
Originally Posted by BigRuss View Post
...and FUSA...
naahhhhhhh
whitej47 is offline
post #17 of 17 Old 08-08-2011, 11:06 AM
Wait, wait....VVTI time!
Nickell's Avatar
Quoted: 0 Post(s)
Nickell is on a distinguished road
Great write up, easy to follow. Seems like the door lock actuators fail often on Bs
Nickell is offline
