Need help after mechanic broke my car - Scion xB Forum
post #1 of 29 Old 03-26-2019, 11:50 PM Thread Starter
Bassman-Soundking's Avatar
Quoted: 15 Post(s)
Bassman-Soundking is on a distinguished road
I have a rattling sound from belt side of engine. Mechanic too belt off and ran engine. Determined it was actually compressor clutch.
I told him I'll buy part and have him install it when it arrived.
He put the belt back on and left.
Next time the car turned on it has 6 trouble codes and drives like crap.
P0011
P0300
P0301
P0302
P0303
P0304
I think he broke something if the belt area possibly when tightening the alternator, or maybe damaged something running engine without the belt.
Any help would be awesome. The mechanic says he didn't do anything. This car never had any codes ever in the 3 years my daughter had it till immediately after her worked on it.
Bassman-Soundking is offline
post #2 of 29 Old 03-27-2019, 01:10 AM Thread Starter
Quoted: 15 Post(s)
P0011
P3000
P3001
P3002
P3003
P3004
I think he broke something if the belt area possibly when tightening the alternator, it maybe damaged something running engine without belt.
Any help would be awesome. The mechanic says he didn't do anything. This cat never had any codes ever in the 3 years my daughter had it till immediately after her worked on it.
By the way this is a 2006 Scion xA, but it's exactly the same engine as my 2006 xB
post #3 of 29 Old 03-27-2019, 06:09 AM
rush3969's Avatar
Quoted: 13 Post(s)
rush3969 is an unknown quantity at this point
Are you sure you typed those codes right, one of them shows something to do with hybrid lol.
I'm assuming you mean p0300-p0304 which should all be cylinder misfire.
P0011 is camshaft timing
rush3969 is offline
post #4 of 29 Old 03-27-2019, 09:53 AM Thread Starter
Quoted: 15 Post(s)
Yeah I wrote them wrong you are right
post #5 of 29 Old 03-27-2019, 11:11 AM
rush3969's Avatar
Quoted: 13 Post(s)
Check the vvt solenoid see if it didn't get plugged all the way back in or wire got messed up. I'll bet that's your other 4 codes for misfire.
Should be down by the alternator just check all plugs and wiring in that area.
I'm not home or I'd look at my other motor and tell you exactly where it is.
If that's all he messed with was drive belts nothing else should of gotten messed with but worth checking
rush3969 is offline
post #6 of 29 Old 03-27-2019, 11:17 AM
rush3969's Avatar
Quoted: 13 Post(s)
Located left side motor behind the alternator around the head
rush3969 is offline
post #7 of 29 Old 03-27-2019, 11:36 AM Thread Starter
Quoted: 15 Post(s)
I'm looking in that area, but my vision isn't great. I don't know what these things look like lol
post #8 of 29 Old 03-27-2019, 11:41 AM Thread Starter
Quoted: 15 Post(s)
Thank you for the reply.
I'm not sure how to reply without doing a quote
post #9 of 29 Old 03-27-2019, 11:41 AM
rush3969's Avatar
Quoted: 13 Post(s)
Watch "SCION XB P0012 Code VVT Solenoid?" on YouTube
https://youtu.be/vyp5_2i_3cA
Here is a video showing where it is.
rush3969 is offline
post #10 of 29 Old 03-27-2019, 11:48 AM
rush3969's Avatar
Quoted: 13 Post(s)
Just hit the plus button up top. Don't check the box on my post and it won't quote it
rush3969 is offline
post #11 of 29 Old 03-27-2019, 11:51 AM Thread Starter
Quoted: 15 Post(s)
this part?
post #12 of 29 Old 03-27-2019, 11:58 AM
rush3969's Avatar
Quoted: 13 Post(s)
Looks to be it. Could just need replaced also. Might just be a coincidence that happened to go bad at the same time. Try to wiggle it unplug it plug it back in. Reset your ecu see what happens
rush3969 is offline
post #13 of 29 Old 03-27-2019, 12:02 PM Thread Starter
Quoted: 15 Post(s)
ok I can see the mounting bolt after removing alt bracket. He never unplugged it, but could have leveraged against it and damaged it maybe.
post #14 of 29 Old 03-27-2019, 12:04 PM
rush3969's Avatar
Quoted: 13 Post(s)
Very possible. I know I use that area to leverage on to tighten my alternator belt but I watch closely so I don't hit it.
rush3969 is offline
post #15 of 29 Old 03-27-2019, 12:06 PM
rush3969's Avatar
Quoted: 13 Post(s)
Bottom of it looks like its been rubbed or paint on it from something in the picture you added. I go to the right of that when I tighten my belt
rush3969 is offline
post #16 of 29 Old 03-27-2019, 12:06 PM Thread Starter
Quoted: 15 Post(s)
I'm struggling to remove the connector plug.
post #17 of 29 Old 03-27-2019, 12:13 PM Thread Starter
Quoted: 15 Post(s)
Ok got it. Tightened alt again and reset codes. Hopefully this does it.
post #18 of 29 Old 03-27-2019, 12:28 PM
rush3969's Avatar
Quoted: 13 Post(s)
Hopefully, if not I'd prime one if you have Amazon and save a good chunk. Autozone and advanced are like 90+ a pop
rush3969 is offline
post #19 of 29 Old 03-27-2019, 12:39 PM Thread Starter
Quoted: 15 Post(s)
Yeah I'll do that. Thanks for the help I appreciate it.
post #20 of 29 Old 03-27-2019, 01:51 PM
rush3969's Avatar
Quoted: 13 Post(s)
No problem. Keep us posted if it comes back
rush3969 is offline
