Old 01-05-2007, 07:17 AM   #1
Sir
I'm fast in a slow way.
Sir's Avatar
Sir is on a distinguished road
Send a message via AIM to Sir Send a message via MSN to Sir Send a message via Yahoo to Sir
how much for 30000 mi?
Okay...still a 'Noob' to this,
SO, my car just reached 30k and I asked my stealership how much it would cost to do the check up, and the figure nearly bowled me off my feet $360.95!!!!!
I have a feeling that this just cant be right....can you help me out? Where can I get a 30k check up done for cheap?
Sam
Sir is offline
Old 01-05-2007, 07:47 AM   #2
Resolve
Resolve's Avatar
Resolve is on a distinguished road
that sound to expensive to me.. I asked at my 30K and dont think it was that much
Resolve is offline
Old 01-05-2007, 04:56 PM   #3
heathenbrewing
heathenbrewing's Avatar
heathenbrewing is on a distinguished road
If I remember correctly, the only thing that the stealership changes is your engine and tranny oilůmaybe your air filter too. Everything else is simply a visual inspection which you may be able to do yourself depending on your mechanical ability.
heathenbrewing is offline
Old 01-05-2007, 04:59 PM   #4
heathenbrewing
FYI - Any decent autoshop would charge $125-$200 for the same service.
Old 01-05-2007, 05:03 PM   #5
stankubrick
stankubrick's Avatar
stankubrick is on a distinguished road
^^Yeah, just ask that they do what is stated in the manual. That's what I did for my 15k service. It was much cheaper to order "a la carte" than to buy one of their "specials."
I don't have a garage, I don't have tools, I am NOT mechanically inclined, and I especially don't have time, so I am always at the mercy of mechanics and/or dealerships....what a crappy feeling Anybody know of any good Scion-friendly mechanics in the Bay Area?
stankubrick is offline
Old 01-06-2007, 09:10 PM   #6
scvscions
Authorized Vendor
scvscions's Avatar
scvscions will become famous soon enough
It all depends on your Box:
Regular oil and filter $20
Regular Plugs $4
T-IV for autos, Regular gear for sticks $20
Paper air filter $10
Toyota Red Coolant $10
Cabin Air Filter $10
I use synthetic so the prices are different. The plugs are regular plugs but I put in iridiums which cost about $28 to $32. If you have an auto it's a must that you use T-IV or the correct Lubeguard additive with dexron III. In the sticks I had Synthetic as well for a 4% savings in gas mileage. Every little bit helps. Toyota Red is not a long life coolant and likes to be changed in 30K increments to help stop the hoses ends from foaming up like they do when corrosion kicks in. If you have a reusable air filter, now's a good time to clean it and let it DRY. If you use oil use it sparingly. And change your cabin air filter at this time(whether you make it yourself or buy it pre made)
scvscions is offline
Old 01-07-2007, 06:11 PM   #7
Skeeter
Skeeter's Avatar
Skeeter is on a distinguished road
Send a message via ICQ to Skeeter Send a message via AIM to Skeeter Send a message via Yahoo to Skeeter
THere is nothing to grease on the chassis, so jsut change the oil, filter, if it an auto you may need to change the trans fluid as well, depending on the type of plugs you may need to change those as well. YOu might want to clean the throttle body, cant hurt. Dealerships offer that crappy service for those who dont have time. I do everything on my own.
Skeeter is offline
Old 01-13-2007, 03:53 PM   #8
06xbox
06xbox's Avatar
06xbox is on a distinguished road
I believe the manual says to just change engine oil and filter, air filter, spark plugs, and visually inspect brakes and so on...coolant doesn't have to be done until longer because it is Super Long Life. I would reccommend changing it before the service interval of 100,000 miles probably around 3 yrs or 45,000. But keep in mind doing service at dealerships will help you if you ever need assistance on warranty item expecially if your just out of warranty by a little bit they will most likely goodwill repairs if they seen you have your maintence done at the dealership.
06xbox is offline
Old 01-15-2007, 09:06 AM   #9
heathenbrewing
Originally Posted by 06xbox View Post
....But keep in mind doing service at dealerships will help you if you ever need assistance on warranty item expecially if your just out of warranty by a little bit they will most likely goodwill repairs if they seen you have your maintence done at the dealership.
That is simply untrue.
You should read up on The Magnusson-Moss Act. DIY'ers are fully covered, and the warranty stays intact.
Old 01-22-2007, 05:21 PM   #10
Sesh1975
Sesh1975's Avatar
Sesh1975 is on a distinguished road
Send a message via AIM to Sesh1975
Regular Plugs $4
Are you a Toyota tech? If so how much do you charge for the service?
Sesh1975 is offline
Old 01-22-2007, 06:50 PM   #11
Skeeter
Skeeter's Avatar
Sounds like your dealer needs to be investigated. Email Scion and report them. Like the corp investigate.
Skeeter is offline
Old 02-05-2007, 10:51 PM   #12
cubeDriven
the ONE
cubeDriven's Avatar
cubeDriven is on a distinguished road
Post
actually dealers vary on what they actually put on their major service. and yeah.. its almost around that much more or less. this is whats on our major service for a scion..
"parts"
oil filter
gasket
oil
brake clean
air filter
battery cleaner
engine oil supplemnt
fuel treatment
coolant
type t4 trans fluid ($7 a quart x4)
(some dealers will throw in the cabin filter as part of the service, spark plugs.. if they are the regular ones ie. $5.00 or less, it comes with it, iridiums.. $10+ it optional..extra money on your part.)
"inspection"
wiper blades
drive belts
thermostat
all fluids "must top off if low"
int. lamps and horn
hoses
plugs, cap, rotor
axle boot
tires
"service"
rotate tires
clean brakes
re-torque suspension bolts
+ replacement of all parts above.
most of the stuff your paying for are in the labor. your looking at under $100 in parts. my suggestion, do an intermediate w/ a coolant and tranny service. its pretty much the same thing and youll save a few bucks.
cubeDriven is offline
Old 02-06-2007, 10:34 AM   #13
Sir
Sir's Avatar
I found the same service advertised at another scion dealership for more than one hundred dollars less....and they did the same things as this dealership does.
Sir is offline
Old 02-06-2007, 11:19 AM   #14
Sesh1975
Sesh1975's Avatar
I actually got a coupon in the mail from Hamer but I dont really care to take my car there. So I just took the coupon to Glendale and they honored it. So I got the service to $225.00. I thought that was pretty good. I always keep my eye open for dealership service ads.
Sesh1975 is offline
Old 02-06-2007, 03:58 PM   #15
cubeDriven
the ONE
cubeDriven's Avatar
yea.. 90% of the time dealers will accept any outside dealer coupons. even quotes.. if your quoted a certain price on a part from one dealer.. and another is more expensive.. bring them the quote and they usually accept it. its what keeps the customers coming back.
Old 02-06-2007, 11:47 PM   #16
Sir
Sir's Avatar
I went to the dealer today...and he tryed so hard to find any reason to keep the price jacked up....but all he found was things that the other dealer did, that they didnt...and the other dealer was CHEAPER!!!!
Sir is offline
╗ Site Sponsors
╗ Site Supporters
