Old 08-22-2012, 01:05 PM   #1
whitej47
whitej47's Avatar
whitej47 will become famous soon enoughwhitej47 will become famous soon enough
Send a message via AIM to whitej47
Cataclean- Catalytic converter cleaner fuel additive
Hey guys,
I usually don't buy into hype with fuel additives, but I wanted to share my experience with people here on the forum. My friend has an '05 Camo that had a fouled up coil pack and she drove on it for about a month. I had to diagnose the problem by changing certain compnents, etc. I switched out the dead coil for another used one and everything worked fine after that.
Until the CEL...
The car didn't run rough or anything, but it was due for SMOG and a new catalytic converter being the likely culprit, I opted to test the cheap stuff out first.
Enter Cataclean:
Purchased at the local hardware store. Less than $30 I think. The CEL went off in 2 days and stayed off. I thought the grilles in the cat had some deposits from having burned rich for a few weeks. I suppose if the car had been driven really hot for a while, the deposits would eventually burn off. I decided to give it a try. The car passed smog last week with flying colors. Cat and motor have about 125k and are still functioning well. I think it was worth it.
I filled up with half a tank of 91 octane and added this fluid in. There are specific directions on the side of the bottle.
whitej47 is offline   Reply With Quote
Old 08-22-2012, 02:17 PM   #2
Zman
Zman's Avatar
Zman will become famous soon enoughZman will become famous soon enough
Re: Cataclean- Catalytic converter cleaner fuel additive
It just goes in the gas tank?
I know Seafoam and others need to go in the vacuum line which is impossible to do by yourself!
Zman is offline   Reply With Quote
Old 08-26-2012, 07:13 AM   #3
SlayerX301
SlayerX301 is on a distinguished road
You can.
Just use any vacuum line. The easier way is with the brake booster.
-Unplug the hose on the brake booster
-put it in the mug with the seafoam and at the same time, give some air by openening manually the throttle body
I use seafoam one time each year and my engine never does strange noise
SlayerX301 is offline   Reply With Quote
Old 08-26-2012, 02:28 PM   #4
Zman
Zman's Avatar
I just threw a code for the rear O2 sensor. Do you think this will help?
FYI I cleared the code and it hasn't come back.
Old 08-26-2012, 02:48 PM   #5
whitej47
whitej47's Avatar
It takes a while for your code to come back on.
Old 08-26-2012, 05:11 PM   #6
SlayerX301
If it takes a while to comme back, it's a common problem and it can be fix with an oxygen sensor spacer on the rear O2 sensor
If it come back quickly, it can be a damaged O2 sensor or you need to change the catalytic converter
Old 09-26-2012, 12:52 PM   #7
DTRAIN619
VIP Member
Undercover Moderator
DTRAIN619's Avatar
DTRAIN619 is a jewel in the roughDTRAIN619 is a jewel in the roughDTRAIN619 is a jewel in the rough
Okay, I got the dreaded "3 lights of doom" this morning. Code read: P0420. Thanks to Victor reminding me of this thread, I made a run to Pep Boys and picked up a bottle of Cataclean.
I cleared the code, and will be sure to report back if the lights re-appears. Current mileage: 135,599 on the original catalytic converter. Worse case scenario: Replace that cat. Thanks again for putting this up, Joe.
BTW, how's your friend's car doing as of late?
DTRAIN619 is offline   Reply With Quote
Old 09-26-2012, 06:51 PM   #8
whitej47
whitej47's Avatar
Well, it passed smog with flying colors and the light has not come back on. There were about 8 problems at once around 120K, but since everything has been fine. I don't know how the thing is running on a daily basis, but it seems to be good overall. This is the same car with the door lock issue and coil pack issue...
Old 10-04-2012, 09:45 AM   #9
DTRAIN619
VIP Member
DTRAIN619's Avatar
Update: It's been a week and a day, no code.
Old 10-04-2012, 12:02 PM   #10
PCH
06.5 TCM
PCH's Avatar
Did you do any freeway driving Dion?
Old 10-04-2012, 02:37 PM   #11
DTRAIN619
VIP Member
DTRAIN619's Avatar
Everyday, 40 miles round trip commute plus the usual errands.
Old 10-04-2012, 03:26 PM   #12
whitej47
whitej47's Avatar
Nice man, I hope it works out for you. Keep us posted!
Old 10-04-2012, 03:37 PM   #13
DTRAIN619
VIP Member
DTRAIN619's Avatar
Will do, Brother. And thank you for the lead!
Old 11-12-2012, 02:47 AM   #14
C4 Cory
C4 Cory is on a distinguished road
I have question for the people that are having the cats go bad at low and somewhat low mileage, do guy use any additives like fuel system cleaner or injector cleaner to your gas regularly?
C4 Cory is offline   Reply With Quote
Old 11-24-2012, 11:43 PM   #15
HeadLightBulbsDotCom
HeadLightBulbsDotCom is on a distinguished road
I use Sea Foam randomly in my vehicle.. I pour it directly into the gas tank and then I fill the tank up with 91 octane. It increases my MPG and all together helps the vehicle run better/cleaner..
I dont mean to be a thread jacker..
I will look into that product as well "Cataclean" Sounds like an amazing product..
CataClean $30 a bottle
Sea Foam $10 a bottle
Both are 16oz
CataClean: http://catacleanus.com/
SeaFoam: http://www.seafoamsales.com/how-to-u...treatment.html
HeadLightBulbsDotCom is offline   Reply With Quote
Old 05-30-2014, 01:24 AM   #16
imBOXY
imBOXY's Avatar
imBOXY is on a distinguished road
So I've had this same problem for almost 3 years now and decided to give the cataclean a try before I try replacing parts.
So it's been 100+ miles since I've cleared the code and applied the cataclean. I dive about 35 miles a day to work and back and the light hasn't come on.
So the part I don't understand is that the CEL/MIL hasn't come on but if I connect my scanner to the OBDII port the scanner still reads a P0420 code. One one though. Before it would have two of the same codes come on (P0420 twice).
I don't know if I should try my luck and bring it to smog now or not.
imBOXY is offline   Reply With Quote
Old 07-11-2014, 03:29 PM   #17
Blumonster
Blumonster is on a distinguished road
Gumout Regane, Redline SI, Chevron Techron fuel system cleaners work well, they have PEA,but I am not sure if it will clean catalytic converters. They are not harmful when used moderately.
Blumonster is offline   Reply With Quote
Old 07-11-2014, 08:00 PM   #18
xhero
xhero is on a distinguished road
Both are 16oz
I use seafoam too but why put 91 octane in you gas tank? The owners manual calls for 87 octane. Couldn't using higher octane cause problems?
xhero is offline   Reply With Quote
Old 07-12-2014, 12:36 AM   #19
BigLobe
addicted
BigLobe's Avatar
BigLobe is on a distinguished road
Side note off subject....what the heck happened to Joe?
BigLobe is offline   Reply With Quote
Old 07-21-2014, 01:48 AM   #20
uwintoday
uwintoday's Avatar
uwintoday is on a distinguished road
Do we have a DIY to remove and clean a cat?
uwintoday is offline   Reply With Quote
Site Sponsors
Site Supporters
