Go Back   Scion xB Forum > Scion xB - Generations > 1st Gen: 2003 - 2007 Scion xB > Scion xB Lighting & Electrical
Scion xB Lighting & Electrical There's options for Scion xB Lighting and Electrical from the factory, but honestly where's the fun in that. In this Scion xB Lighting and Electrical forum you can share ideas with eachother on what works well and looks good for Scion xB lighting.
Old 06-29-2012, 01:10 PM   #1
MassiveAttack
xB Noob
MassiveAttack's Avatar
MassiveAttack is on a distinguished road
HID Headlights, No High Beams
I purchased my 2004 xB used, and it has several mods that are not working. I have worked out a few problems, but not this one.
The High Beams do not work, whether I "flash" the lights by pulling towards myself with the stalk, or if I push away to keep the high beams on. In either case the the dash indicator for high beams lights, but outside the car the lights go dark. The low beams always work.
I just wasted $99 buying a replacement Sylvania Bulb, so I don't think the bulbs are the issue. Any suggestions?
Thanks
MassiveAttack is offline   Reply With Quote
Old 06-29-2012, 01:45 PM   #2
The_Doctor
for groceries huh?...cute
The_Doctor's Avatar
The_Doctor will become famous soon enough
Most HID kits are single beam meaning they only work for low beam.
The nicer kits out there are dual beam but they cost more and a lot of people just don't purchase them.
The_Doctor is offline   Reply With Quote
Old 06-29-2012, 01:56 PM   #3
MassiveAttack
xB Noob
Unhappy Re: HID Headlights, No High Beams
Thanks for your reply, I'll try to get some research done on the model and type to see if my unit has high beam support.
Old 06-29-2012, 04:09 PM   #4
The_Doctor
The_Doctor's Avatar
If you take a picture of the bulb itself we would be able to tell easily.
Old 06-29-2012, 04:12 PM   #5
Zman
Just an ugly toaster.
Zman's Avatar
Zman will become famous soon enough
Theres a fuse just for high beams.
Zman is online now   Reply With Quote
Old 06-29-2012, 06:34 PM   #6
schwartz329
South Bound
schwartz329's Avatar
schwartz329 is on a distinguished road
Check 10amp low beam fuses as well, thats what fixed my high beam issue like yours
Sent from my iPad using Tapatalk HD
schwartz329 is offline   Reply With Quote
Old 06-30-2012, 02:45 PM   #7
MassiveAttack
xB Noob
The low beams have a separate fuse? Hmm...I'll check the manual and the fuse and post back.
My HIDs have the following information, and I have included 2 pix with the bulb and the HID unit. The guys at Autozone didn't know at all when
Vorschaltgerat
Xenon-Licht 12v
5dv 007760-41
D2S DSR 2000h
Thanks, guys!
Click image for larger version
ID:	20573   Click image for larger version
Old 06-30-2012, 02:53 PM   #8
The_Doctor
The_Doctor's Avatar
Those are single beam bulbs. But what housings are you running them in? Stock housings are H4, I'm kinda lost on this one at the moment
Old 06-30-2012, 02:59 PM   #9
MassiveAttack
xB Noob
So I checked fuses 9 and 10, which are the Left and Right Headlights, according to the manual. Both are good, but #10 has a 20 Amp fuse in it. I'll buy some spares and replace that with a #20.
I think the housings are stock, but I'll have to research what the stock ones looks like to sure. I'm going to resign myself to knowing that these HIDs don't support high beams until I find a manual on the product.
Thanks again, The_Doctor, schwartz329, and Zman.
Old 06-30-2012, 03:46 PM   #10
MassiveAttack
xB Noob
I meant to say I would replace the 20A fuse with a 10A fuse.
Old 06-30-2012, 05:15 PM   #11
PCH
06.5 TCM
PCH's Avatar
There are little adapter plates to run D2S bulbs in place of H4's. Probably has that put into the headlight sockets.
Old 09-04-2012, 10:23 PM   #12
Big_Kokujin
Big_Kokujin's Avatar
Big_Kokujin is on a distinguished road
Send a message via Yahoo to Big_Kokujin
I know it's old but I don't see the resolution.
I've done a few retrofits on my box and I may be able to help you out. With HID, like what you pictured, if you want high beams you will need to retrofit a bixenon projector. This will allow the same bulb to do both. There is a mechanical cut off on the projector that usually drops when the high beam is activated, thus allowing full light to shine as opposed to just half.
Big_Kokujin is offline   Reply With Quote
