Go Back   Scion xB Forum > Scion xB - Generations > 1st Gen: 2003 - 2007 Scion xB > Scion xB Interior
Scion xB Interior There's no arguing that there's plenty of room inside the Scion xB interior. Which is why the Scion xB interior deserves an entire forum of it's own. Here you can discuss any customizing you have done to the interior of your Scion xB.
Old 03-06-2011, 08:40 AM   #1
mbillones
mbillones is on a distinguished road
04-07 Scion XB Aftermarket Cruise Control???
Any of you guys ever put an aftermarket cruise control on your xb? If so, any feedbacks on it? Good investment? Bad investment?
mbillones is offline   Reply With Quote
Old 03-06-2011, 10:15 AM   #2
The_Doctor
@HFDane on Instagram
The_Doctor's Avatar
The_Doctor will become famous soon enough
I have the Rostra cruise control in mine, I installed it myself, took me a little over an hour from start to end. It's definitely worth it, really helps out on those long trips and easy to install.
Sent from my iPhone 4 using Tapatalk
The_Doctor is offline   Reply With Quote
Old 03-06-2011, 10:42 AM   #3
BestmpgxB
Pishtaco
BestmpgxB's Avatar
Re: 04-07 Scion XB Aftermarket Cruise Control???
I also have the Rostra cruise control. Its the one Toyota dealers installed in the 1G xBs. Mine didn't work after installation in my '06.5. I was leaving on a month-long trip around the country, so I didn't have time to troubleshoot it. Rostra tech support found me a factory installer in Albuquerque who fixed it for $75 (problem was I tapped the wrong wire for the VSS).
Old 03-06-2011, 10:47 AM   #4
The_Doctor
The_Doctor's Avatar
Yeah I had the same problem, the instructions were not for the 06.5 but I found a write up on SL that showed the correct wire to tap into. I emailed Rostra about it but I don't know if they updated their instructions.
Old 03-06-2011, 08:54 PM   #5
BestmpgxB
Pishtaco
BestmpgxB's Avatar
I also recall seeing something on SL about Rostra's wrong wire diagram.
FWIW, the cruise control was well worth its cost on my cross-country vacation, and ever since.
Old 03-07-2011, 08:29 AM   #6
xB_Jag_Bx
G33ksta
xB_Jag_Bx's Avatar
xB_Jag_Bx is on a distinguished road
I don't know which one I have, it was installed before I bought it, it has bugs; but, it gets the job done
xB_Jag_Bx is offline   Reply With Quote
Old 03-07-2011, 09:09 AM   #7
JP_Extreme
JP_Extreme's Avatar
JP_Extreme is on a distinguished road
I've checked into it before and it cost a pretty penny to have the dealership install it. So I just learned different positions to drive in.
JP_Extreme is offline   Reply With Quote
Old 03-07-2011, 10:17 AM   #8
mbillones
this Rostra cruise control, is this for 5-speed or for automatics or for both?
Old 03-07-2011, 10:20 AM   #9
The_Doctor
The_Doctor's Avatar
If you can follow directions you can install a Rostra CC. I think the hardest and most time consuming part for me was putting in the clutch override switch, you have to screw it in behind the pedal and there is very little room so it took me about 10 mins of frustration before it went in.
Old 03-07-2011, 10:21 AM   #10
The_Doctor
The_Doctor's Avatar
Both, I have mine installed in my 5 speed box
Old 03-08-2011, 11:44 PM   #11
ZumCRX1
Low Post Triple O.G.
ZumCRX1's Avatar
ZumCRX1 is on a distinguished road
AS everyone else has stated the Rostra cruise control kit is the way to go, its what was offered from yoda. Its a pretty straight forward kit, except that out cars electrical anything under dash it a pain in the ass to work on, otherwise the fitment is great. My is on my 04 5spd.
ZumCRX1
ZumCRX1 is offline   Reply With Quote
Old 03-15-2011, 06:41 PM   #12
ToyotaBB_UK
ToyotaBB_UK is on a distinguished road
will it fit a gen1 xB? i actually got a Toyota bB year2000...should fit right???
ToyotaBB_UK is offline   Reply With Quote
Old 03-15-2011, 07:19 PM   #13
BestmpgxB
Pishtaco
BestmpgxB's Avatar
Yes, we're all running Gen 1s. Should fit your bB following the instructions for the automatic transmission installation.
Old 03-16-2011, 04:02 AM   #14
ToyotaBB_UK
AWESOME!!!!! Thats was the one thing I really thought was missing!!!!
Ordering now now now!!!!
Old 08-08-2011, 08:43 AM   #15
Virusmind
Stock06
Virusmind's Avatar
Virusmind is on a distinguished road
I just bought my first Scion XB over the weekend and already want to add cruise control. I'm sure I will go with the brand name everyone is mentioning but I can't decide if I am confident enough to install this by myself.
On a level of say 1 to 5, how easy is the install? 5 being the easiest? Thanks for your feedback!
Virusmind is offline   Reply With Quote
Old 08-08-2011, 11:33 PM   #16
BestmpgxB
Pishtaco
BestmpgxB's Avatar
I'd rate it a 3. I got the mechanical parts set up with no problems, and thought I had the electrical wring hooked up OK, too. But it didn't work, and I was leaving on a one-month cross-country trip, so I didn't have time to debug the problem.
Rostra technical support hooked me up with one of their approved installation shops in Albuquerque, and they got it working in an hour, for $75. Their tech support is pretty good, and the installation manual is thorough. My problem was I hooked up the wrong wire for the Vehicle Speed Sensor. The reason, I'm pretty sure, is that the wiring changed in post-December '05 xBs.
Old 08-09-2011, 07:24 AM   #17
Bobb_todd
Bobb
Bobb_todd is on a distinguished road
I got the Mr Cruise cruise control. I think it was $450 installed. It works well and I couldn't do long trips without it
Bobb
Bobb_todd is offline   Reply With Quote
Old 08-10-2011, 08:33 PM   #18
Virusmind
Stock06
Virusmind's Avatar
Thanks for the feedback Bobb_Todd.. I'm leaning towards just paying someone to put it in to avoid ant headaches.
Old 08-10-2011, 08:51 PM   #19
kraziMonkey
MonkyBx
kraziMonkey's Avatar
kraziMonkey is on a distinguished road
i just put a Rostra Cruise kit in my box a few weeks back. it was way eazy. there is only 3 wires you will need to tap into. one is under the driver side dash and the other 2 are under the glove box. everything else is easy. i took a few pics so if you need them prior to making a decision on paying someone to do it let me know. i would install it if you lived in my area. the kit cost me 240 ish and not worth paying someone 260 to install this. maybe a 100 bucks.
kraziMonkey is offline   Reply With Quote
Old 08-10-2011, 09:13 PM   #20
Virusmind
Stock06
Virusmind's Avatar
Wow that's pretty nice of you KraziMonkey to offer help with pics. I guess I'm afraid of crappy directions more than anything. I keep hearing about wire color coding being off in the instructions when dealing with an '06. But hell 3 wires... I think I could handle that. How can I get the pics from you of the install? I really appreciate that.
Site Sponsors
Site Supporters
