Go Back   Scion xB Forum > Scion xB - Generations > 2nd Gen: 2008 Scion xB > Scion xB Lights & Electronics
Old 09-16-2010, 05:32 PM   #1
Pirate
Usual Suspect
Pirate's Avatar
Pirate is on a distinguished road
OEM Headlight fuse ???
I had the low beam go out on my pass side. I swapped it out with two other bulbs, won't work. All of the bulb filiments look to be o.k.. Driver'
s side low beam works....both Hi beams work.
Would that individual lamp have it's own fuse? Other thoughts/suggestions.
It's still in warrenty but, if it's simple I'd just as soon fix it myself.
Thanks
Pirate is offline   Reply With Quote
Old 09-17-2010, 12:37 AM   #2
help23
help23's Avatar
help23 will become famous soon enoughhelp23 will become famous soon enough
Send a message via AIM to help23
Re: OEM Headlight fuse ???
I was just gonna post the same thing right now... my low beam went out on the passenger side and I have swapped it with other lights but it wont come one. High beam works fine... if anyone knows what this is let us know please
help23 is offline   Reply With Quote
Old 09-17-2010, 02:19 AM   #3
i_b_AO
Rawr!!!
i_b_AO's Avatar
i_b_AO will become famous soon enough
Send a message via AIM to i_b_AO
Check the fuses in the engine compartment. I had the same problem. That was the problem. Its one of the 10 fuses. Kthxbai...
i_b_AO is offline   Reply With Quote
Old 09-17-2010, 02:29 AM   #4
help23
help23's Avatar
thanks AO.... my first thought was a fuse but that didnt make sense to me as the high beam still worked.... I will check it in the morning.
thanks bro
Old 09-17-2010, 09:38 AM   #5
Pirate
Usual Suspect
Pirate's Avatar
thanks bro
It didn't make sence that one olw beam would work and the other would either.
What I should have done was put the Driver's side lamp on the pass side. because I know that one works. I just hate tring to get underthat dash to get at those fuses. NOT a job for a 6' 200er
Old 09-17-2010, 11:21 AM   #6
help23
help23's Avatar
I had the same thought about trying the other light but.... I am gonna check the fuses in a few....brb
Old 09-17-2010, 01:09 PM   #7
Pirate
Usual Suspect
Pirate's Avatar
Fuse is in the fuse box under the hood...NOT under the dash.....good thing.
There ARE infact indvidual 15 watt fuses.......good thing.
Big fat hands tring to get those low bean bulbs in ......NOT SO GOOD.
Old 09-17-2010, 02:08 PM   #8
i_b_AO
Rawr!!!
i_b_AO's Avatar
Ooh you second geners and your power needs. Lol. So was it one of the fuses or no?
Old 09-17-2010, 03:41 PM   #9
help23
help23's Avatar
each headlight low beam has its own fuse and mine was blown... new one in and I have light!
Old 10-07-2010, 03:28 PM   #10
circuslegend
circuslegend is on a distinguished road
Send a message via AIM to circuslegend
yay casey! lol
circuslegend is offline   Reply With Quote
Site Sponsors
Site Supporters
