Old 07-27-2010, 08:06 PM   #1
GRNDHOG
RS 2.0 #1282
GRNDHOG's Avatar
GRNDHOG is on a distinguished road
Fuel Injector Service
What is done on this service (60,000 miles?)
I'd like to do the 60k myself, but am unsure about the "optional extra" Fuel injector service.
Also, what are the recommendations for spark plugs? oem or a replacement?
GRNDHOG is offline   Reply With Quote
Old 07-28-2010, 03:54 PM   #2
GRNDHOG
RS 2.0 #1282
GRNDHOG's Avatar
Re: Fuel Injector Service
Bump? It's in the Scion Service Schedule!
Old 07-28-2010, 04:07 PM   #3
PCH
06.5 TCM
PCH's Avatar
It's called Fuel Injection Service. Not in the schedule, but many places try selling it. It's supposed to clean the system and sometimes it can make things better.
Old 07-28-2010, 04:33 PM   #4
jimmylw8787
jimmylw8787
jimmylw8787 is on a distinguished road
A couple years ago I paid Wal-Mart $69 to clean the injection system on my 2001 Explorer it had around 95k miles at the time. I assumed at the least it would improve mileage.... It did nothing for mileage, power, acceleration, etc. Basically everything they said would improve didn't. In my opinion it is a waste of money and the two hours it took for them to do it.
jimmylw8787 is offline   Reply With Quote
Old 07-28-2010, 04:44 PM   #5
silvertoast
silvertoast's Avatar
silvertoast will become famous soon enough
a real auto shops injection cleaning is worth if u have alot of miles, run cheap gas, or never run injector cleaner.
again a real shop will hook into the fuel line and bascically force clean the system with a chemical
what walmart tire and lube does ( i used to work there years ago) is dump injector cleaner in ur car then spray carb cleaner down ur intake, sometime resulting in cel codes and having to be reset, thats it. and u can do that urself
silvertoast is offline   Reply With Quote
Old 07-28-2010, 04:58 PM   #6
PCH
06.5 TCM
PCH's Avatar
True. Most shops just do top engine cleaning. May as well do a simple seafoam treatment.
http://www.clubxb.com/forums/f28/sea...not-31926.html
Old 07-28-2010, 06:00 PM   #7
GRNDHOG
RS 2.0 #1282
GRNDHOG's Avatar
cool thanks!
I looked at the schedule I had, and it is dealer specific. I won't be wasting any money getting that done. Perhaps, I will throw some additive to the fuel for the hell of it, but I'll just stick to the oil/spark plug routine.
Any thoughts on Spark Plugs?
Old 07-28-2010, 06:12 PM   #8
Gutling
Gutling is on a distinguished road
At the Toyota dealership I work with we use a can of Toyota Fuel Injector cleaner. The cleaner is a pressurized can we hook straight to your fuel rail, and run your car until its empty. It literally runs just on the cleaner, so it goes straight to your injectors.
We also do a 3 part cleaning. One bottle goes in your gas tank, one bottle gets run through your engine through a vac source (like seafoam) and the last is a cleaner we do your throttle body with.
Gutling is offline   Reply With Quote
Old 07-28-2010, 06:28 PM   #9
PCH
06.5 TCM
PCH's Avatar
Do you do this only as preventative maint or does it also fix existing problems, like rough running, misfire codes, etc.?
Old 07-29-2010, 03:43 AM   #10
Gutling
We recommend it at 30k, 60k, etc intervals as maintenance, but if someone came in that had never done it before, higher miles and had a slight hesitation or running rough we would rec it if there was nothing mechanically wrong (bad sensor, etc)
Old 11-24-2010, 04:59 PM   #11
jetblast
jetblast's Avatar
jetblast is on a distinguished road
I would bet the Toyota system is manufactured by 3M. Back in my dealership days they had a direct cleaning system like that. There's also a 3M tank additive avail at NAPA
jetblast is offline   Reply With Quote
Site Sponsors
Site Supporters
