Go Back   Scion xB Forum > Scion xB - Generations > 1st Gen: 2003 - 2007 Scion xB > Scion xB Lighting & Electrical
Scion xB Lighting & Electrical There's options for Scion xB Lighting and Electrical from the factory, but honestly where's the fun in that. In this Scion xB Lighting and Electrical forum you can share ideas with eachother on what works well and looks good for Scion xB lighting.
Old 06-09-2010, 02:13 PM   #1
ahughejazz24
ahughejazz24's Avatar
ahughejazz24 is on a distinguished road
Brake lights not working!!!
I have a 2004 RS1, and recently, as I was driving to work, a car pulled up next to me and told my that my tail lights werent working.
When I got to work, I put my work boots on the brake pedal to see if the tails were working, and they weren't.
The third brake light still works, the turn signals still work, the tail lights still light up when the headlights are on, I replaced the TAIL and STOP fuses, and nothing worked.
Any suggestions??? I'm going to remove the tails and see if anything got pinched.
ahughejazz24 is offline   Reply With Quote
Old 06-09-2010, 02:22 PM   #2
SAKURA
HELA FASS DOOO
SAKURA's Avatar
Re: Brake lights not working!!!
is it just one of the tails or both?....
if its just one of them, could be your bulbs. they have 2 filements and possibly your "brake" filements went out.
Old 06-09-2010, 03:31 PM   #3
ahughejazz24
Yup!!! That's exactly what it turned out to be. Oddly enough, both brake light filaments are worn down so both tail lights went out. I just switched the bulbs around until I get some new led bulbs to replace the worn down ones. Thanks Eric!!!
Old 06-09-2010, 03:33 PM   #4
SAKURA
HELA FASS DOOO
SAKURA's Avatar
cool bro *thumbs up*
Old 07-22-2010, 07:36 PM   #5
jawknee915
Location: Originaly from El Paso, TX but live in Phoenix, AZ !!!!!!!!!!
jawknee915 is on a distinguished road
so I got the same problem, but it was just for my right brake light, i replaced both right and left both anyways but still not working, checked all fuses, thinking its the circuit for the bulb or the back socket for the bulb???? any advice????
jawknee915 is offline   Reply With Quote
Old 07-22-2010, 07:39 PM   #6
Black_Box
Black_Box has a spectacular aura aboutBlack_Box has a spectacular aura about
Send a message via AIM to Black_Box
if u think its the circuit try shooting power at the connector that plugs to your tail light
Black_Box is offline   Reply With Quote
Old 07-22-2010, 07:50 PM   #7
PCH
06.5 TCM
PCH's Avatar
If you are sure the 10Amp STOP fuse is OK, you can jump the switch at the brake pedal with the paper clip and see if that makes them work.
Old 08-22-2010, 11:44 PM   #8
XHBxBX
XHBxBX is on a distinguished road
I'm having a similar problem and I was curious - it seems my fuse is ok (i.e. it looks like a "good fuse" via the pictures in the owners manual). So where is the switch at the brake pedal? Is it something I would have to get under my car to get at? Sorry if this seems like a pretty obvious questions - but I am not the most mechanical guy and I am working on my own vehicle because I am stone cold broke.
How would you go about doing this? On my 2006 xB the actual socket for the brake light/rear tail light snaps in/out without any wires seemingly attached to it.
XHBxBX is offline   Reply With Quote
Old 08-26-2010, 10:29 PM   #9
Box_Boy
Box_Boy's Avatar
Box_Boy will become famous soon enough
I have a little of the same topic...I just bought LED smoked tails and they say to use ur stock blinker and parking light...but i dont have stock tails so where can I buy the bulbs from? here is the ebay add too
03 04 05 06 Scion XB BB Red/Smoke Lens LED Tail Lights: eBay Motors (item 390188674697 end time Jul-08-10 11:57:57 PDT)
Box_Boy is online now   Reply With Quote
Old 10-17-2010, 10:32 PM   #10
whozat6000
whozat6000 is on a distinguished road
my brake and tail light are out on the right side ive changed the bulb checked the fuses switched them around ..WHAT COULD I POSSIBLY BE MISSING!!??
is there a relay or something if so where is it?
whozat6000 is offline   Reply With Quote
Old 10-18-2010, 09:18 PM   #11
Zman
Just an ugly toaster.
Zman's Avatar
Zman will become famous soon enough
LEDs don't go out very often
Zman is online now   Reply With Quote
Old 02-08-2012, 11:30 PM   #12
ThatArsonist
ThatArsonist is on a distinguished road
Right now my TYC right side break light is not working; so I know the frustration. Im new with all of this so I guess im stuck buying a new tail light unit, but the one on ebay dont plug right into my car frustration frustration
ThatArsonist is offline   Reply With Quote
