HELP!!! Need to replace positive battery terminal
I was trying to undo the bolt holding my amp wire on the positive terminal and while doing that i bent the terminal to much and completely seperated the red plastic terminal cover and the bolt from the terminal itself. The break is at the weld which holds the bolt holder to the battery connector itself. How do i replace it? T.T
i probably have to remove the red box behind the battery too. IDk what to do.
Reason: Automerged Doublepost
