Old 06-27-2009, 10:48 PM   #1
chargerowner
chargerowner is on a distinguished road
Extremely Loud Squealing Noise
The Scion doesn't do it all the time but......When we start our 04 Scion Xb sometimes it makes this horrible, extremely loud squealing noise. If rev the engine it goes away. Took it to the dealer, they have no idea, but it didn't make the noise while we were there. It is the worst noise I have ever heard in my life. Getting ready to drive from Sacramento CA to York PA, 2800 miles.
Any ideas what this could be please let me know ASAP, leaving Monday morning noise or not.
chargerowner is offline
Old 06-27-2009, 10:55 PM   #2
PCH
06.5 TCM
PCH's Avatar
Re: Extremely Loud Squealing Noise
Probably from one of the belts.
Originally Posted by chargerowner View Post
Got belts for mine at the dealer, installed myself, extremely easy
^^^ Does this have anything to do with the noise?
PCH is offline
Old 06-27-2009, 11:05 PM   #3
chargerowner
Not from one of the belts, we checked that as did the dealer. The noise is SO LOUD, that its difficult to tell where its coming from.
Old 06-27-2009, 11:09 PM   #4
PCH
06.5 TCM
PCH's Avatar
If it's manual, may be the throwout bearing?
PCH is offline
Old 06-27-2009, 11:11 PM   #5
chargerowner
I have thought it might be the clutch. Its got 82000 on it. I just flew in and bought it from my son, now I have to drive it back across the US. He says its been doing it for quite sometime now. It makes the noise in neutral.
Old 06-27-2009, 11:18 PM   #6
PCH
06.5 TCM
PCH's Avatar
If you pump the clutch pedal and the noise changes, it's likely to be the bearing. On some cars you can spray a little of white lithium grease onto the bearing but you need to be careful not to spray it all around the bellhousing. May help for some time.
PCH is offline
Old 06-27-2009, 11:21 PM   #7
chargerowner
Nope, pumping the clutch does not change the noise. Hitting he gas makes it go away, in neutral.
Old 06-27-2009, 11:28 PM   #8
PCH
06.5 TCM
PCH's Avatar
Water pump, alternator? Shouln't be that difficult to locate. Spray wd-40 on things and see (listen).
PCH is offline
Old 06-27-2009, 11:40 PM   #9
chargerowner
New water pump, new belts, we have been under the car when the noise is going on and believe me, if we could we would locate it. Just thought maybe someone else has had the problem. Very strange. You wouldn't believe how loud it is, its unbelieveable.
Old 06-27-2009, 11:55 PM   #10
PCH
06.5 TCM
PCH's Avatar
Check if harmonic balancer (crank pulley) is slipping. Never seen it happen on xB, but very easy to check so why not. Just make a mark on it and see if outer part moves relative to the inner part/flange.
PCH is offline
Old 06-28-2009, 12:04 AM   #11
chargerowner
We will try that tomorrow and see what happens. I'll let you know if you want we find! Thanks for the info tonight though! I appreciate it.
Old 06-28-2009, 12:05 AM   #12
TattooAl
HFD CLEVELAND
TattooAl's Avatar
TattooAl is on a distinguished road
dang dude, im gonna hit you up if i ever have a question.....
TattooAl is offline
Old 06-28-2009, 02:28 PM   #13
gravebox
gravebox's Avatar
gravebox is on a distinguished road
Send a message via AIM to gravebox
it's VERY likely that there's a small amount of oil getting on the back side of the belts or water even from using the AC. when this happens, your belts WILL scream ridiculously loud for a short period of time with a probability of it happening often when first starting the engine.
this will happen with any vehicle period. sometimes it's not actually a problem, just the environment.
gravebox is offline
Old 06-28-2009, 03:06 PM   #14
859Toaster
3 Time Scion Owner
859Toaster's Avatar
859Toaster has a spectacular aura about859Toaster has a spectacular aura about
I get a little squeal at first start up, but it goes away. Time for new belts here.
If it's not your belts, probably the muffler bearings.
859Toaster is offline
Old 06-28-2009, 09:08 PM   #15
Wookie384
Wookie384's Avatar
Wookie384 is on a distinguished road
Send a message via AIM to Wookie384
I'm willing to bet whoever installed the now belts didn't tighten them correctly and thats the noise. Either that or you'r blinker fluid may be low. :-P But seriously I think its your belts being a tad bit loose, check the tension on the belt while the motor is off, how much can you move the belt?
Wookie384 is offline
Old 06-28-2009, 10:37 PM   #16
TattooAl
HFD CLEVELAND
TattooAl's Avatar
yeah cant a belt tensioner go bad too?
TattooAl is offline
Old 06-29-2009, 07:36 PM   #17
Wookie384
Wookie384's Avatar
Yeah, if the 1NZ-FE had a belt tensioner I'd recomend that, but it doesn't have any.
Old 07-14-2009, 04:20 PM   #18
h22acrd
h22acrd is on a distinguished road
my car started to do that right now. it squeals and goes away
h22acrd is offline
Old 07-20-2009, 11:48 AM   #19
tracejupiter
tracejupiter is on a distinguished road
mine has also, i think it might be cheap dayco belts or the tensioner wasnt adjusted right
tracejupiter is offline
Old 10-23-2009, 02:08 PM   #20
lemusS08
speedy box
lemusS08's Avatar
lemusS08 is on a distinguished road
dude i have an 06 xb and i know what ya mean!! its this super loud noise and it sounds like it comes from the breaks! so what i did was i disasemblemed the rotor and break pad and noticed the breaks were still good so i i just cleaned the rotor and the breaks and assembled everything back and took it for a test drive and so far it hasn't made the noise! maybe it just needed a little air.lol hope it works in your case
lemusS08 is offline
Site Sponsors
Site Supporters
