Go Back   Scion xB Forum > Scion xB - Generations > 1st Gen: 2003 - 2007 Scion xB > Scion xB Lighting & Electrical
Scion xB Lighting & Electrical There's options for Scion xB Lighting and Electrical from the factory, but honestly where's the fun in that. In this Scion xB Lighting and Electrical forum you can share ideas with eachother on what works well and looks good for Scion xB lighting.
Old 02-10-2009, 08:02 PM   #1
DJArchngl
DJArchngl's Avatar
DJArchngl is on a distinguished road
HELP! Code PO103
I was putting in some replacement wal-mart fogs, and installing a newer (not rusty) filter on my CAI, and my car is throwing a PO103 code (according to the scanguage).
Car sounds like **** and idle's horribly.
I've disconnected the battery, re-connected the battery mumerous times, and re-tightened all of the hinges on my CAI.
Any input?
-Ken
DJArchngl is offline
Old 02-10-2009, 08:10 PM   #2
awinter
NorCal - East Bay Area
awinter's Avatar
awinter will become famous soon enough
Re: HELP! Code PO103
Souds like a faulty MAF sensor.
link: http://www.v8sho.com/SHO/Update8.gif
awinter is offline
Old 02-10-2009, 08:13 PM   #3
MattyRattyPoo
MattyRattyPoo is on a distinguished road
Send a message via AIM to MattyRattyPoo
You should just google search the code next time.
OBD-II Trouble Code: P0103 Mass Air Flow (MAF) Circuit High Input
MattyRattyPoo is offline
Old 02-10-2009, 08:17 PM   #4
Black_Box
chop top
Black_Box's Avatar
Black_Box has a spectacular aura aboutBlack_Box has a spectacular aura about
Send a message via AIM to Black_Box
does the filter have oil on it, clean your MAF
Black_Box is offline
Old 02-10-2009, 08:18 PM   #5
DJArchngl
DJArchngl's Avatar
How do you clean the MAF?
And I just oiled the filter...
Old 02-10-2009, 08:20 PM   #6
awinter
awinter's Avatar
Go to auto parts store and buy MAF Sensor cleaner. [follow directions on can]
How long ago did you oil the filter? It should have had time to completely dry before being reinstalled. Otherwise, you are just coating your MAF and Intake with oil.
awinter is offline
Old 02-10-2009, 08:25 PM   #7
DJArchngl
DJArchngl's Avatar
Latest Update: We reset the ECU, and turned the key to the ON position (without turning the engine) and it still popped the code.
Unlikely, because the MAF is reading too much air.
Old 02-10-2009, 08:30 PM   #8
Black_Box
chop top
Black_Box's Avatar
never know till ya try, use a Q tip or get a can of cleaner.
Old 02-10-2009, 08:38 PM   #9
DJArchngl
DJArchngl's Avatar
OK, it's the sensor, but the code is present even before starting the car. So I'm thinking a wire was pulled out somewhere in the MAF sensor wiring harness when I was dickin' around in the engine bay. Is that even something you can buy?
OR am I screwed and have to take this to a dealer...
Also, is there a PDF or something that can tell me what the voltage of all the wires is suppsed to be? Cause if it's just one wire, I might be able to fix that.
*this sounds like domething thomas could come up with*
Old 02-10-2009, 08:44 PM   #10
Black_Box
chop top
Black_Box's Avatar
go to SL, they have wiring diagrams with that stuff...and..give me a few minutes, i might have a diagram for ya....
i had the same prob, you dont need to be running ot throw a MAF code. i swaped it with my wife, and it was ok, he car didnt have a prob with it.
Old 02-10-2009, 08:46 PM   #11
PCH
06.5 TCM
PCH's Avatar
Look into the connector to see if all the pins are on the same level. It's pretty hard to dislocate them by accident, though. The MAF could've been damaged by overoiling the air filter, def try to clean the sensor first.
PCH is offline
Old 02-10-2009, 08:55 PM   #12
Black_Box
chop top
Black_Box's Avatar
if you can read the pic and match up to this info your golden
BATT-E1 : Always approx. 9-14 volts
+B-E1 : 9-14 volts with the ignition SW on and the engine stopping
VC-E1 : 4.5-5.5 volts with the ignition SW on and the engine stopping
IGF-E1 : Pulse generation with the engine idling
THA-E1 : 0.5-3.4 volts with the engine idling and the intake air temp. 0 C (32 F) - 80 C (176 F)
THW-E1 : 0.2-1.0 volts with the engine idling and the engine coolant temp. 60 C (140 F) - 120 C (248 F)
W-E1 : 9-14 volts with the engine idling
: 0-3 volts with the ignition SW on and the engine coolant temp. sensor connector disconnects
STA-E1 : 6.0 volts or more with the engine cranking
VTA-E1 : 0.3-1.0 volts with the ignition SW on and the throttle valve fully closed
: 3.2-4.9 volts with the ignition SW on and the throttle valve fully open
STP-E1 : 7.5-14 volts with the brake pedal depressed
PRG-E1 : 9-14 volts with the ignition SW on and the engine stopping
FC-E1 : 9-14 volts with the ignition SW on and the engine stopping
: 0-3 volts with the engine idling
NE, G2-NE- : Pulse generation with the engine idling
OCV+ -OCV- : Pulse generation with the ignition SW on and the engine stopping
IGT1, IGT2, IGT3, IGT4-E1 : Pulse generation with the engine idling
#1, #2, #3, #4-E1 : Pulse generation with the engine idling
E01, E02, E03, E1, E2, EC-Ground : Always conti
Click image for larger version
Old 02-10-2009, 10:11 PM   #13
ogerdgonz
Authorized Vendor
ogerdgonz's Avatar
ogerdgonz is on a distinguished road
Send a message via Skype™ to ogerdgonz
the filter oil fouled the maf sensor.... they hate oil
ogerdgonz is offline
Old 02-10-2009, 10:58 PM   #14
SAKURA
HELA FASS DOOO
SAKURA's Avatar
with what matty gave you, heres another. bookmark it!
btw, this is what you got, * DTC P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency
ODBII Codes
SAKURA is offline
Old 02-11-2009, 11:32 AM   #15
DJArchngl
DJArchngl's Avatar
Picked up some maf cleaner @ autozone.
Cleaned it, reset the ECU, plugged it back in. Same problems.
Repeated cleaning and reset again.
No luck.
The only thing I can think is the wires from my MAF to my CAI were fairly taught... maybe a single wire came unplugged?
I don't want to take it to the dealer if I don't have to, last time I had wiring issues, I took it there for a "full diagnostic", and they charged me 97 dollars and quoted me the codes. I figured out what it was myself and fixed it for virtually nothing and 30 minutes of work.
So.... yeah. I think I'm up **** creek.
Car won't go over 3k rpms w/o bogging.
Old 02-11-2009, 12:05 PM   #16
PCH
06.5 TCM
PCH's Avatar
Any chance there is water in the connector?
Factory manual for the P0103 advises to theck for open in any 3 of the VG, E2G and +B circuits or a short in +B or VG.
Another possible cause is the ECM.
If the wiring brakes that usually happens near the connector. Sometimes you can even feel or notice it through the insulation. Black, Violet and Pink are the 3 wires.
PCH is offline
Old 02-11-2009, 01:15 PM   #17
SAKURA
HELA FASS DOOO
SAKURA's Avatar
also check yer ground wires from the headlight area to battery. when i had that unhooked, it bogged and sputered badly when i was driving.
SAKURA is offline
Old 02-11-2009, 05:47 PM   #18
DJArchngl
DJArchngl's Avatar
^did your check engine light go on too?
Old 02-11-2009, 06:04 PM   #19
SAKURA
HELA FASS DOOO
SAKURA's Avatar
yup. once i hooked it back up, i was all good.
what i did was i put in an aftermarket ground wires and i left the oem ground cable from HL to neg. battery unhooked and that was my problem. not sure if this is your problem thou, but i thought ill throw it out to you.......
btw, i started a thread with all the links to engine/VSC/ABS light comming on and what our members did/do to solve the problem. you may need to check my profile and click on "find threads started by" and scroll and locate thread.
here ya go, >>> http://www.clubxb.com/forums/f28/eng...ing-24290.html
SAKURA is offline
Old 02-11-2009, 10:14 PM   #20
awinter
awinter's Avatar
Update on problem?
awinter is offline
Site Sponsors
Site Supporters
