Go Back   Scion xB Forum > Scion xB DIY Articles > DIY Articles > Scion xB Engine
Old 09-21-2008, 10:58 PM   #1
surfcitylocal
Get off my lawn Moderator
surfcitylocal's Avatar
DIY: Changing gear oil 1st Gen xB manual transmission
This DIY is to change the gear oil in the manual transmission of the first generation xB.
You'll need the following:
2 Quarts gear oil
24mm socket and 1/2 drive ratchet
Towels
Drain pan
Gloves
Long funnel
Car ramps for jack and jack stands.
AS ALWAYS, USE CAUTION AND SAFE WORKING PRACTICES WHEN YOU ARE UNDER YOUR VEHICLE. BE SURE IT IS SUPPORTED SECURELY AND YOU ARE USING THE PROPER SAFETY EQUIPMENT.
Start by locating the fill hole for the manual transmission.
Next, apply enough brute force to bust the sucka loose.
Always remember, butt crack is optional!
Next, crawl under the vehicle and locate the drain plug.
Loosen the bolt and hold pressure against it until it has loosened all the way. Pull the plug from the hole and allow the used gear oil to drain into the pan.
Once all the used gear oil has drained from the transmission, clean the area and replace the drain plug along with the washer and tighten.
Be sure to dispose of your used gear oil at a proper recycling location or facility.
Now it is time to refill the transmission with new gear oil. Pat has chosen to use Royal Purple brand.
Remember, don't be like Pat. This is not an adult beverage!
Pour the new gear oil into the transmission using the long funnel.
Once the transmission is full, remove the funnel and clean the area around the opening with a shop towel. Replace the bolt and you're done!
surfcitylocal is offline
Old 09-22-2008, 08:57 AM   #2
teamneon
#1517 RS1
teamneon's Avatar
teamneon is on a distinguished road
Re: DIY: Changing gear oil 1st Gen xB manual transmission
How often should this be changed? Or should I say, what does the FSM call for?
awesome job btw
teamneon is offline
Old 09-22-2008, 03:44 PM   #3
squirrel
squirrel is on a distinguished road
Excellent choice in fluids!
squirrel is offline
Old 09-24-2008, 03:44 PM   #4
uprising
uprising's Avatar
uprising is on a distinguished road
Send a message via AIM to uprising
nice! i wanna do this
uprising is offline
Old 09-24-2008, 10:06 PM   #5
FoGbOx
FoGbOx is on a distinguished road
mee too... so when is it the first time that i have to do this? i got 61k on mine and have not done it yet. But i switched to Royal Purple in my engine at 60k and i could tell the difference
FoGbOx is offline
Old 09-25-2008, 06:50 AM   #6
mntegra01
mntegra01 is on a distinguished road
i have a box you can do it to. = )
So is the fill exactly 2 quarts? also what should I torque the bolts back to?
I have 38 K and I would reccommend changing the gear oil every 30K, safe than sorry... especially with an auto tranny... change it often!
edit.... do you need a special washer like the oil plug needs? the one with the teflon coating?
mntegra01 is offline
Old 09-25-2008, 08:20 AM   #7
surfcitylocal
awesome job btw
We couldn't find a recommendation on when to change it. Pat's got over 50,000 miles I believe.
Pat put just a little less than 2 quarts and the washer is already there. It's metal.
Old 09-25-2008, 07:20 PM   #8
Cravin
VIP Member
Crop Circle Moderator
Cravin's Avatar
Cravin will become famous soon enough
Send a message via MSN to Cravin
I noticed smoother shifts so far especially going into reverse I dont have to play around with the shifter to get it into gear.
Also my box has a short ram intake, if you have the stock intake you need to remove it to get to the fill plug. my car has 85,000 miles but the owners manual doesnt show any specific mileage to change the manual transmission oil.
Cravin is offline
Old 09-25-2008, 08:35 PM   #9
metro273
On here once in a while!
metro273's Avatar
metro273 is on a distinguished road
Nice write up!
Btw, I think what you call the fill plug, isn't the actual fill plug?
If you look up the trans, to the left of the drain plug, you'll see it. Looks like the drain plug. I could be wrong though...
metro273 is offline
Old 09-25-2008, 09:03 PM   #10
Cravin
VIP Member
Cravin's Avatar
Originally Posted by metro273 View Post
Nice write up!
Your right but the one on top works so much easier, less messy. unless you have the stock airbox its just as good.
Cravin is offline
Old 09-27-2008, 07:38 AM   #11
phillycamobox
Philly Scions
phillycamobox's Avatar
phillycamobox is on a distinguished road
doing this tomorrow. piece of cake! )
phillycamobox is offline
Old 09-27-2008, 09:00 AM   #12
bB_Gunnz
bB Squad
bB_Gunnz's Avatar
bB_Gunnz is on a distinguished road
Great write-up!! Thanks for sharing!
bB_Gunnz is offline
Old 09-30-2008, 01:05 AM   #13
awdwill
awdwill's Avatar
awdwill is on a distinguished road
I read that auto shops have equipment that "flush" out the entire transmission system instead of just draining it out and refilling it with fluid... anyone knows whether this commonly advertised service is actually worth paying for? Or is a DIY pretty much the same?
awdwill is offline
Old 09-30-2008, 01:34 AM   #14
Cravin
VIP Member
Cravin's Avatar
Thats for auto transmissions it flushes out the torque converter and Trans.
The manual trans doesnt need that. Just drain and refill, your good to go.
Cravin is offline
Old 09-30-2008, 01:42 AM   #15
awdwill
awdwill's Avatar
sweet~! thanks!
awdwill is offline
Old 09-30-2008, 10:34 AM   #16
randode
NO CLUB
randode's Avatar
randode is on a distinguished road
Nice write up!
i filled mine thru the one on the side. I used Mobil 1 with a hose on the bottle and squeezed until it came out of the hole.
I'm wondering if filling it thru the vent would put too much oil in there?
great write up and pics though.
randode is offline
Old 09-30-2008, 09:07 PM   #17
Cravin
VIP Member
Cravin's Avatar
2 quarts is amount called for by Toyota. mighty convenient I thinks.
Cravin is offline
Old 10-02-2008, 06:19 PM   #18
dabears1
dabears1 is on a distinguished road
thanks for the diy. did mine today
dabears1 is offline
Old 10-03-2008, 09:32 PM   #19
mntegra01
I see you have SAE 75WXXX Royal Purple brand...
I just bought some Synchromax for 12 bucks a quart and Im curious if thats ok to use seeing as how you didnt use it, BUt mine is
Synchromax High Performance Manual Transmission Fluid. And of course I have a manual gearbox...
Old 10-03-2008, 11:30 PM   #20
Cravin
VIP Member
Cravin's Avatar
Toyota calls for this grade of oil. (API GL-4 or GL-5: 75W90, 80W90)
Max-Gear 75W90 is that grade of oil.
Synchromax is recommended for manual transmissions that specify an automotive transmission fluid.
I had an Isuzu Trooper that used that grade oil. Its equivalent to 30 wt. motor oil or auto trans fluid.
Here is the link Royal Purple Transmission Lubricant Chart
Cravin is offline
