Need help re: 16x8et30 and 16x9et15 - Scion xB Forum
post #1 of 22 Old 03-16-2012, 10:28 AM Thread Starter
Newbie from the PI
Quoted: 1 Post(s)
Cleng is on a distinguished road
So here's my question... I have a chance to pick up 4 pcs of 16x8et30 rims or 2 pcs of 16x8et30 for the fronts and 2 pcs of 16x9et15 for the rear. I tried the search button but i wanted to see more. It would be much help for me if you can post images with 16x8et30 all around and 16x8et30 fronts with 16x9et15 rears and please, if you can also include if it is cambered or not and what spacer size was used. Thanks all! It would be a big help for newbies like me.
Cleng is offline
post #2 of 22 Old 03-16-2012, 12:40 PM
SUSPNJNKY
Lifex's Avatar
Quoted: 0 Post(s)
Lifex will become famous soon enough Lifex will become famous soon enough
Re: Need help re: 16x8et30 and 16x9et15
here is a pic of 16x9 et 15 all around
the 16x8 et 30 will be pretty far in
while this is a 15x8 +25 it will sink in 5mm more compared to what you are looking for
---------- Post added 03-16-2012 at 12:42 PM ----------
and as for a reference, 'good' offsets for xB's are based on an 8" wide wheel +10 front, 0 rear for flush
also this thread you should look through.
Offset Guru Thread
Bought with Family, Built with Friends
Thread Killer
"My Girlfriend doesn't wrestle, no, but, you should see her box"
Lifex is offline
post #3 of 22 Old 03-16-2012, 01:24 PM Thread Starter
Newbie from the PI
Quoted: 1 Post(s)
Thanks for the refference pics sir. It helped a lot in visualizing what i wanted. With regerds to the first pic, is it cambered and spaced for the rear? I like how the rear seats but i think i want the second pic's front offset. Does 16x8et30 with 25mm spacers for the rear with 0 camber will be flushed without rubbing? Because the best i can do is roll the rear tirewells. I have no chance of getting rear camber kits down here unless i order it there in the states but shipping cost might be expensive. With regards to the front, will 16x8et30 work without using some spacers?
Cleng is offline
post #4 of 22 Old 03-16-2012, 02:56 PM
SUSPNJNKY
Lifex's Avatar
Quoted: 0 Post(s)
the first pic is 16x9 et 15 all around and the second pic is 15x8 +25 all around. the second pic has no spacers anywhere the back is sunk in 10mm than the fronts which is why it looks kinda weird.
you won't need spacers or camber for the rears but you might want to run some stretch like a 215 or 205 if you are comfortable with it.
the front's should be fine with out spacers since the stock upgrade trd wheels are 18x7.5 +45 and they clear with out spacers
Thread Killer
Lifex is offline
post #5 of 22 Old 03-16-2012, 03:14 PM Thread Starter
Newbie from the PI
Quoted: 1 Post(s)
Noted sir! Thanks so much for enlightening me regarding wheel fitment.
---------- Post added 03-17-2012 at 03:18 AM ----------
I might get the 16x9 rear ang 16x8 fronts. Is it common for xb's to have a staggered rim setup? I'm also planning to use 205x40x16 tires front and rear
Cleng is offline
post #6 of 22 Old 03-16-2012, 03:22 PM
SUSPNJNKY
Lifex's Avatar
Quoted: 0 Post(s)
mmm I haven't seen it too often for the lack of legitimately staggered wheels available. Of course in the world of work wheels and that sort its very common.
205/40 will be fine and dandy.
Also incase in you need just a WEE bit of camber check these out:
Important - Rear Alignment Shims
they aren't expensive, i think no more than 50 for two of the them (one for each side)
Thread Killer
Lifex is offline
post #7 of 22 Old 03-16-2012, 03:29 PM Thread Starter
Newbie from the PI
Quoted: 1 Post(s)
Checked out the link sir. I'll keep that in mind. Will it be readily available here in clubxb if ever i need some?
Cleng is offline
post #8 of 22 Old 03-16-2012, 03:42 PM
SUSPNJNKY
Lifex's Avatar
Quoted: 0 Post(s)
just search them online - they are easy to find via google
Thread Killer
Lifex is offline
post #9 of 22 Old 03-16-2012, 08:33 PM Thread Starter
Newbie from the PI
Quoted: 1 Post(s)
Thank you sir!
Cleng is offline
post #10 of 22 Old 03-19-2012, 10:11 AM
SUSPNJNKY
Lifex's Avatar
Quoted: 0 Post(s)
you're welcome. those are only good up to 2 degrees either way, for anything more you can easily get -3 camber shims via http://www.2zero6factory.com/ and -5 can also be had but I am not too certain from where.
Thread Killer
Lifex is offline
post #11 of 22 Old 04-26-2012, 04:41 PM
Quoted: 0 Post(s)
salinasBB is on a distinguished road
whos white xb is that?how much camber is he running to pull a 16x9 +15 all around off?yes i know this a month old thread lol
salinasBB is offline
post #12 of 22 Old 04-26-2012, 09:35 PM
I'm Marcel NOT Stenger
ToyBox_02's Avatar
Quoted: 0 Post(s)
ToyBox_02 will become famous soon enough ToyBox_02 will become famous soon enough
Depends on how low you are or want to go, -5 will clear with fender rolled and -3 slammed is cutting it close.
Originally Posted by slothead View Post
shhhhh. family will hear you. seriously, i can't take out my toys until they are gone.
ToyBox_02 is offline
post #13 of 22 Old 04-28-2012, 01:52 PM
ken-chan
jdmtoyobb's Avatar
Quoted: 0 Post(s)
jdmtoyobb is on a distinguished road
Send a message via Yahoo to jdmtoyobb
im rocking 16x9 +15 in the rear with an extra 10mm and -5 shims and this is how it fits.
Support quality say no to reps
jdmtoyobb is offline
post #14 of 22 Old 04-28-2012, 03:03 PM
ToyBox_02's Avatar
Quoted: 0 Post(s)
16x9+15f, 16x9+5 rear. Running a 10mm spacer in the rear with -5 camber also.
---------- Post added 04-28-2012 at 02:08 PM ----------
Oops
post #15 of 22 Old 04-28-2012, 07:50 PM
Quoted: 0 Post(s)
xtgdxown3dx is an unknown quantity at this point
Nice fitment. on the 16x9
xtgdxown3dx is offline
post #16 of 22 Old 04-28-2012, 08:13 PM
ToyBox_02's Avatar
Quoted: 0 Post(s)
If you do 16x9+15 up front your gonna have to space the front fenders, mine are spaced just over a 1/2" on each side.
post #17 of 22 Old 05-02-2012, 04:17 PM
Quoted: 0 Post(s)
does anyone have a picture os a 16x9 +15 in the rear -3 camber?
post #18 of 22 Old 08-04-2012, 09:03 PM
deleteme
Quoted: 0 Post(s)
jstauff93 is on a distinguished road
For -3 camber a 5mm spacer should be about right
jstauff93 is offline
post #19 of 22 Old 08-10-2012, 08:42 AM
Quoted: 0 Post(s)
Piggie is on a distinguished road
Anyone know what rims are the ones on the white xb. Can you put a link up i need those. lso if i run those on bags can i still slam with out it rubbing
Piggie is offline
post #20 of 22 Old 08-10-2012, 08:58 AM
bbszero's Avatar
Quoted: 6 Post(s)
bbszero will become famous soon enough bbszero will become famous soon enough
Garage
The first one has Borbet Type A's. The second one looks like Enkie 92's.
Hub Spacers * Camber * Plate Mounts * HVAC Knobs * NS Wheels *Clazzio Seat Covers * Grip Royal steering wheels* and more.....
THE FACTORY HAS COMPLETE AIR RIDE KITS STARTING AT 1,425!
[url]http://www.facebook.com/?
bbszero is offline
