have to change serpentine belt on my 2009 XB. i notice the tension pulley bolt is slim, is there a alternate way to loosen belt? i have tried in past but the bolt is a hair away from going on. (from the top) haven't tried from the bottom, that's the next step but i figured i would ask.
going to assume the gobble is from the tension pulley as well, the belt it self is original but i did notice that the wear is length wise with the belt in the middle. like if you where creasing paper so much it started to split.
thanX in advance guys/gals
---------- Post added 09-03-2015 at 03:23 PM ----------
well i found it the hard way, for all of you non tech swavvy people, its a 19mm bolt under belt next to alternator.
