Has anyone "dynamatted" their roof ?? - Page 2 - Scion xB Forum
post #21 of 38 Old 12-26-2011, 08:32 PM
Acquiring stance.
xseveredveganx's Avatar
Quoted: 4 Post(s)
xseveredveganx is on a distinguished road
Re: Has anyone "dynamatted" their roof ??
I've tried some foam and it was pretty marginal. You could scuff up the edge a bit with a scotchbrite, then hit that edge with some clear silicone sealant. Let it dry, throw it on. Now it has the soft edge on the metal.
Look for videos on youtube from Hexibase. He has done a lot of cabin prep in his Grand Vitara.
xseveredveganx is offline
post #22 of 38 Old 12-30-2011, 04:19 PM
Acquiring stance.
Quoted: 4 Post(s)
Not the Second Skin product. I'm pretty sure you can apply it in almost any temperature. I've applied it in the winter months with no problem. Still sticks really well.
post #23 of 38 Old 01-17-2012, 11:02 PM
Quoted: 0 Post(s)
BJRothbone is on a distinguished road
For those who have "matted" the doors, when you do them, what do you do about the plastic lining? Do you just re-epoxy them to the doors over the mat? Kind of lost with this.
BJRothbone is offline
post #24 of 38 Old 01-18-2012, 12:30 AM Thread Starter
wantxb's Avatar
Quoted: 0 Post(s)
wantxb is on a distinguished road
I discarded mine
My id is wantxb cos I joined this forum waaay before I even bought my Xb!!
wantxb is offline
post #25 of 38 Old 01-18-2012, 01:49 PM
Quoted: 0 Post(s)
Originally Posted by wantxb View Post
I discarded mine
does that affect the amount of humidity that gets in?
post #26 of 38 Old 01-22-2012, 07:57 PM Thread Starter
wantxb's Avatar
Quoted: 0 Post(s)
No - I never had a problem
---------- Post added 01-22-2012 at 08:03 PM ----------
Apparently its not re-used when "dynamatting" (sound deadening) you door. Check this out and anyone doing their doors, here is a nice guide too :
---------- Post added 01-22-2012 at 08:04 PM ----------
http://www.dynamat.com/technical_ins...t_install.html
wantxb is offline
post #27 of 38 Old 01-22-2012, 11:14 PM
Quoted: 0 Post(s)
Hmmm... interesting, but doesn't it seem like a waste of material though? I mean the whole reason for putting it on the door is to reduce/stop the vibration of the metal... So if it's just hanging around not attatched to anything, seems like those pieces could be put to better use... Just my two cents (though they might not be worth that much)
post #28 of 38 Old 01-23-2012, 04:00 PM
No longer SW now Supa Red
Quoted: 0 Post(s)
PhatSWXB is on a distinguished road
You know, I was told by the guy at RAAM Audio/MAT, that you don't have to cover the entire door. Mostly cover the access holes. And put some mat on the inside of the door where the biggest part of loose metal is. But I noticed when I covered my doors that the Scion has some sound deadening on the door panels, so I just put strips that over lapped the factory stuff. Then covered the access holes on the door and covered the whole door with a foam mat also from RAAM Audio. Let's just say I spent less than two hundred dollars on everything and covered all five doors and the roof, what a huge difference. Sounds almost as quiet as my Lexus. I still need to do the floor, but don't wanna go through taking out all the seats and stuff yet until I decide what I am going to do about adding another amp for my mids and tweets.
PhatSWXB is offline
post #29 of 38 Old 01-23-2012, 08:34 PM Thread Starter
wantxb's Avatar
Quoted: 0 Post(s)
Phat, its pretty easy to do the floors and the seats come out pretty easy (just make sure you disconnect batt. at least 15 mins, for airbag sensors, etc.). There is some thick stryfoam on the floor in certain places (LOL). I only did parts of my floor cos I ran out - gonna finish it in the summer probably. Oh and YES, what a BIG difference!!!
wantxb is offline
post #30 of 38 Old 03-01-2012, 08:00 PM
Quoted: 0 Post(s)
ezekielguy86 is on a distinguished road
I don't have a system installed yet but I plan on matting every where just to reduce noise from the road. Of course it will help with the system later.
ezekielguy86 is offline
post #31 of 38 Old 04-16-2012, 09:34 PM
ManInTheBox's Avatar
Quoted: 0 Post(s)
ManInTheBox is on a distinguished road
I have Raam Audio mat on my rear door and plan to do the rest of the car. It does sound better but running DD M3A tends to negate any deadening. My truck still rattles.
09 Black Sand Pearl, Easy Street Kit, 5-Axis, Anzo Dual Halo HL HID 10k, OEM Fogs HID 12k, Oznium Vent Lights, V-LED Dual Color Turn Signals, Helo 888 18's, OEM Spoiler, Tinted Windows, Clazzio Covers - Black/Gray/Blue, V-LED/Oznium Blue Interior Lighting, Painted Tails and Reverse Light, 2011 SNS-200 Alpine Navigation (DVD/Navi Fix), Digital Designs Amp M3A, Memphis Audio Amp 100.4, Digital Designs Components, 2 Treo Engineering SSP 12" Subs
ManInTheBox is offline
post #32 of 38 Old 04-16-2012, 10:16 PM
stock sucks
Speck's Avatar
Quoted: 0 Post(s)
Speck is on a distinguished road
There's no need to cover your vehicle top to bottom with dampening material, actually doing that can give you negative effects,
Check out sounddeadenershowdown.com he goes into the topic deeper and makes awesome stuff. I'm getting some of his tiles to place around strategically.
Speck is offline
post #33 of 38 Old 06-12-2012, 05:24 PM
Quoted: 3 Post(s)
HeadLightBulbsDotCom is on a distinguished road
I did the entire roof doors paneling etc.. Basically anywhere that I could get this in I did it.. It worked extremely well and I would definately recommend it to anyone..
http://www.rblox.com/
Thank You,
The #1 AfterMarket HeadLight Bulbs Period!!
All HeadLight Bulbs Come With A 12 Month Warranty And A 60 Day Money Back Guarantee!
http://www.HeadLightBulbs.com
HeadLightBulbsDotCom is offline
post #34 of 38 Old 07-11-2012, 07:37 PM
Quoted: 0 Post(s)
wdiddy is on a distinguished road
Make sure you buy the lightweight stuff and it would be a good idea to use some adhesive as warm weather can make the sheets fall off, maybe use a spray instead.
wdiddy is offline
post #35 of 38 Old 07-12-2012, 03:12 PM Thread Starter
wantxb's Avatar
Quoted: 0 Post(s)
Misleading to an extent sir. Many vehicles have had multiple layers of the material applied - there is no real lightweight or heavyweight stuff and the thicker the better when it comes to doing this. Also, good quality soundproofing / dampening material is made to withstand extreme temperatures IF applied correctly. ALWAYS clean the area thoroughly before applying and make sure you apply it as per the instructions, which is usually a roller and apply adequate pressure.
This procedure has never let me down in the last 20 or so years
---------- Post added 07-12-2012 at 03:13 PM ----------
The thicker the better to an extent btw, I found on extreme spl vehicles pushing over 150dB's that 3 layers is enough sometimes....
wantxb is offline
post #36 of 38 Old 08-03-2012, 10:57 PM
Quoted: 0 Post(s)
826_of_2500 is on a distinguished road
Damn there some good advice in this thread, I wish I had the motovation to sound proof the old RS 5.
826_of_2500 is offline
post #37 of 38 Old 02-16-2013, 08:18 AM
Quoted: 0 Post(s)
xbowner? is on a distinguished road
I have done the doors and hatch in RaaMmat. It deadened outside noise and when you shut the doors it gives a thunk like the European cars do.
It did not deaden the road noise because I have not done the floor yet. Driving around on certain road surfaces (especially concrete roads) most of the noise comes from around the area where the pedals are at. Looked around that area and sure enough there is no sound deadner at all.
Thinking I'll just peel the carpet back as much as I can without removing the seats and insulate those areas.
xbowner? is offline
post #38 of 38 Old 04-13-2013, 05:09 PM
Quoted: 0 Post(s)
You should also look at doing something with the wheel wells in front l there is a bunch of road noise that comes from there, I did a redo of full sound deadening floors, roof, spare tire , quarter panels and I still have noise coming from the front. I am planning to take the plastic fender liners out on front and spay them with some rubberized undercoating and see what that does. I kind of did that once before on my original white XB and I noticed a slight difference.
PhatSWXB is offline
