The big question AWD - Scion xB Forum
post #1 of 38 Old 04-18-2012, 11:32 AM Thread Starter
Got Bags?
tetro's Avatar
Quoted: 0 Post(s)
tetro is on a distinguished road
Send a message via AIM to tetro
So i've searched nothing came up on this but for the Gen 2's which is ridiculous because the gen 2 and rumion are not as similar as the gen 1's and the NCP35.
So lets talk about it.
I really want to see if its possible to take the drivetrain from a ncp35 and swap it onto our 1nzfe and make it work. This way our cars might have a little more hook up and fun.
I know the NCP35 has a 1.3 liter motor so that may be a concern as well as the rear suspension and possibly the whole rear floor pan might be different but if someone has good connects to japan and could make this happen better believe you could make a ton of money selling all wheel drive kits too the us.
So anyone have any technical information any suggestions or insight?
THINK OUTSIDE OF THE BOX...(step out of your car)
tetro is offline
post #2 of 38 Old 04-18-2012, 11:43 AM
ogerdgonz's Avatar
Quoted: 19 Post(s)
Send a message via Skype™ to ogerdgonz
Re: The big question AWD
The whole underside of the car is different, the rear shock towers are possibly different, and the NCP35 is only available as an automatic. Also the gas tanks are probably different and the exhaust system possibly.
If you really want to convert to AWD, my recommendation is to buy the complete drive train from an AWD Vibe/Matrix. You will want to make sure you get the rear disc brakes/emergency/brake/differential/axles/front axle shafts/front wheel hubs/brakes/mounts/suspensions. Then cut open your floor at the tunnel, and begin to mount that set up in your car. Then close your floor, could possibly cut the tunnel from the donor car. By converting the front and rear to this you also gain 4 wheel disc brakes, and 5x100 wheels. However if you are doing all this work you probably should just swap the 1.8 motor as well since it has more potential for NA power than most turbo set ups for the 1nzfe.
National Sales Rep for Dare 2B Different Motorwerks
Check out the new Facebook Page
http://www.facebook.com/D2BDmotorwerks
ogerdgonz is offline
post #3 of 38 Old 04-18-2012, 11:56 AM Thread Starter
Got Bags?
tetro's Avatar
Quoted: 0 Post(s)
So the issue still sits as the trans is column shift automatic. Then as well as rear floor pan is different and rear suspension is different but could the trans bolt up to our motors?
tetro is offline
post #4 of 38 Old 04-18-2012, 12:02 PM
Quoted: 3 Post(s)
Some talk and related pics here: 3s-gte 4wd bB..
PCH is offline
post #5 of 38 Old 04-18-2012, 12:15 PM Thread Starter
Got Bags?
tetro's Avatar
Quoted: 0 Post(s)
Very good info over there but he seemed to drop the idea pretty quick I'm thinking about how it would be basically to get a donor ncp35 then take its rear floor pan cut out mine and weld it in place swap the suspensions rear axle and drive shaft then look at the issues of mating a all wheel drive trans that will work with our car and retain being a manual.
tetro is offline
post #6 of 38 Old 04-18-2012, 12:16 PM
ogerdgonz's Avatar
Quoted: 19 Post(s)
The shifter is not an issue because you would use the USDM column. You can not use the JDM RHD column in a LHD car because the column shifter is on the left side and not the right side. You would use the floor shifter. Also the NCP35 was available with the 1.5 so it would bolt up.
post #7 of 38 Old 04-18-2012, 12:28 PM Thread Starter
Got Bags?
tetro's Avatar
Quoted: 0 Post(s)
So the trans would bolt up its just swapping to a auto?? Or is there a way to still do a manual. This is sounding pretty good.
tetro is offline
post #8 of 38 Old 04-18-2012, 12:43 PM
ogerdgonz's Avatar
Quoted: 19 Post(s)
No you can not just take the NCP35 and use it with a manual. As far as this sounding good, I can make anything that actually fits in the car work for you, but it costs money. If you want a shop to do an AWD conversion for your car, contact Steve. It is not easy but I know it could happen and William can make it happen for the right amount of money. Steve and I could work with you and design the whole thing and William would do the work.
post #9 of 38 Old 04-18-2012, 12:54 PM Thread Starter
Got Bags?
tetro's Avatar
Quoted: 0 Post(s)
After this build is finished and the car hits shows for awhile then I'll consider doing it. Need to stack some more money and get a new daily then this will happen.
tetro is offline
post #10 of 38 Old 04-18-2012, 12:59 PM
ogerdgonz's Avatar
Quoted: 19 Post(s)
That was what I was hinting at, that it will take some savings to make it happen. If it was easy it would already have been done.
post #11 of 38 Old 04-18-2012, 01:54 PM Thread Starter
Got Bags?
tetro's Avatar
Quoted: 0 Post(s)
Oh I know it'll be an arm and a leg. But you have to pay to play. My xb hasn't been a cheap build believe me. I'm glad I got some sponsors along the way too help out. Yet if I could do it on my own obviously it'd be cheaper.
tetro is offline
post #12 of 38 Old 06-02-2012, 03:31 PM
Quoted: 0 Post(s)
dj2383 is on a distinguished road
pretty cool to see all these ideas
---------- Post added 06-02-2012 at 11:39 AM ----------
tetro, if you don't mind me asking, how much money have you put into it?
dj2383 is offline
post #13 of 38 Old 06-02-2012, 11:59 PM Thread Starter
Got Bags?
tetro's Avatar
Quoted: 0 Post(s)
My car so far???????
tetro is offline
post #14 of 38 Old 06-03-2012, 12:22 AM
whitej47's Avatar
Quoted: 0 Post(s)
whitej47 will become famous soon enough whitej47 will become famous soon enough
Send a message via AIM to whitej47
Haha get the calculator and secretary out lol. May be doing RHD swap soon! Keep you posted...I have 2 clips coming in
ETA= Soon enough...June '12, made it!
Originally Posted by BigRuss View Post
...and FUSA...
naahhhhhhh
whitej47 is offline
post #15 of 38 Old 06-03-2012, 12:30 AM
Quoted: 6 Post(s)
BoxLife is on a distinguished road
Joe, keep me posted on that...I have calls out to several people finding a RHD clip for me as well.
BoxLife is offline
post #16 of 38 Old 06-03-2012, 02:10 AM Thread Starter
Got Bags?
tetro's Avatar
Quoted: 0 Post(s)
Joe. We seriously need to talk hit me up brother.
tetro is offline
post #17 of 38 Old 06-03-2012, 03:59 AM
whitej47's Avatar
Quoted: 0 Post(s)
I am trying to figure out how to register the car so it is legal. For "strictly show" you shouldn't have any problems. I hear out firewalls are already stamped...
...and FUSA...
naahhhhhhh
whitej47 is offline
post #18 of 38 Old 06-03-2012, 09:18 AM
Quoted: 6 Post(s)
Yea the vin is on the firewall under the cowl from the factory. Getting rid of that is no sweat, as for the factory Vin tag in front of the dash though, idk.
BoxLife is offline
post #19 of 38 Old 06-03-2012, 01:34 PM
@HFDane on Instagram
The_Doctor's Avatar
Quoted: 5 Post(s)
The_Doctor will become famous soon enough
The vin in front of the dash is simple. Remove the windshield, drill out the old rivets, put it on the new firewall and rivet it to the plate. I did this with a CRX I had a couple years ago.
Follow me on Instagram @HFDane
The_Doctor is offline
post #20 of 38 Old 06-03-2012, 03:50 PM
Quoted: 6 Post(s)
Yea, I was referring to the legality aspect, not so much the labor part. I buy DA shells on the regular and when I make one car, I always use the cleanest title and dash lol...
BoxLife is offline
