Rough, Low Idle issue... - Scion xB Forum
post #1 of 29 Old 06-11-2010, 11:10 AM Thread Starter
rcarmchl's Avatar
Quoted: 0 Post(s)
rcarmchl is on a distinguished road
I am having a bit of an issue with a rough/low idle that occurs on,y when the car is in gear (drive or reverse) - it occurs specifically when the brakes are applied - stopped at a light, drive through, etc - It has idled aroun 700RPM for a long time, but recenlty when stopped the cooling fans kick on and the brakes applied the idle will drop well below 500, the car vibrates until it picks back up.
It has died only once at a full stop.
its an 05 XB - auto tranny - at present it is not throwing any codes.
any help in diagnosing this?
the car is maintenced regularly - sparkys have about 5k on them - NGK Plat's.
rcarmchl is offline
post #2 of 29 Old 06-11-2010, 11:31 AM
Quoted: 3 Post(s)
Re: Rough, Low Idle issue...
May try cleaning the throttle body and Idle Speed Control with seafoam or wd-40.
http://scionlife.org/Scion_Docs/2004...m/onvein40.pdf
http://scionlife.org/Scion_Docs/2004...stallation.pdf
http://scionlife.org/Scion_Docs/2004...y/conponen.pdf
PCH is offline
post #3 of 29 Old 06-11-2010, 11:40 AM Thread Starter
rcarmchl's Avatar
Quoted: 0 Post(s)
Thanks PCH ...but linkie no workie...
rcarmchl is offline
post #4 of 29 Old 06-11-2010, 11:45 AM
Quoted: 3 Post(s)
Don't know why, i just copied them from an older post.
Here: http://scionlife.org/Scion_Docs/2004...y/conponen.pdf
The issue is likely with ISC Valve
If you pull off the rubber intake boot, you can spray a little wd-40 into the cavity on the bottom and let it soak. If the valve is sticking, it should clean it up.
PCH is offline
post #5 of 29 Old 06-11-2010, 11:51 AM Thread Starter
rcarmchl's Avatar
Quoted: 0 Post(s)
Ok- hard to tell from the pics what you're describing...will I need to remove the TB itself to get to the ISC Valve or are you stating tyhat by removing the intake boot that I should be able to access the bottom cavity?
rcarmchl is offline
post #6 of 29 Old 06-11-2010, 12:06 PM
Quoted: 3 Post(s)
Yeah, just pull off the boot and you'll see the cavity at the bottom right before the butterfly plate.
PCH is offline
post #7 of 29 Old 06-11-2010, 12:06 PM
-EC HFD YO-
i_ride_naked's Avatar
Quoted: 3 Post(s)
i_ride_naked is on a distinguished road
when is the last time your spark plugs were changed?? that could be your problem right there.
Like a good neighbor, HFD is there.
follow me on instagram @06scion
i_ride_naked is offline
post #8 of 29 Old 06-11-2010, 01:06 PM Thread Starter
rcarmchl's Avatar
Quoted: 0 Post(s)
As stated in the original post - they are 5k old - NGK Plats...
rcarmchl is offline
post #9 of 29 Old 06-11-2010, 01:21 PM
-EC HFD YO-
Quoted: 3 Post(s)
that doesnt mean 1 or 2 cant be bad/dirty. its an easy check
post #10 of 29 Old 09-02-2010, 08:09 AM
Quoted: 0 Post(s)
dksheahoward22 is on a distinguished road
i just bough a 2006 scion xb 5 speed but when i press on the clutch it wants to kill the engine any suggestions.. i hear it could be the iac but it only wants to die when i drive it. it can sit there and idle fine please help
dksheahoward22 is offline
post #11 of 29 Old 01-07-2011, 10:49 AM
JDMJim's Avatar
Quoted: 0 Post(s)
JDMJim is on a distinguished road
bad battery. happened to a friend.
JDMJim is offline
post #12 of 29 Old 01-07-2011, 11:03 AM
Quoted: 0 Post(s)
thanks but figured it out turned out to be the clutch positioning switch that was trying to kill it.
post #13 of 29 Old 01-07-2011, 05:24 PM
Quoted: 0 Post(s)
craftyslug is on a distinguished road
I've tried looking for the clutch positioning switch for an automatic in the online manual however I am not able to find what you are referring to.
do you know of it by another name?
craftyslug is offline
post #14 of 29 Old 01-07-2011, 06:33 PM
Quoted: 3 Post(s)
It's five speed, not an auto.
PCH is offline
post #15 of 29 Old 01-08-2011, 11:48 AM
Quoted: 0 Post(s)
His first post states its an AUTO
post #16 of 29 Old 01-08-2011, 11:50 AM
Quoted: 0 Post(s)
doesn't allow me to edit posts...
post #17 of 29 Old 01-08-2011, 12:22 PM
Quoted: 3 Post(s)
But you are talking to dksheahoward22, not rcarmchl.
PCH is offline
post #18 of 29 Old 05-13-2011, 04:41 PM
Quoted: 0 Post(s)
flipp3r is on a distinguished road
My idle drops very low, then comes back up, as well. It happens when I am stopped in gear and the A/C or defroster is cycling. I will try cleaning the ISC valve.
I also seem to have issues with a low (24-26) mpg. I am hoping the issues are related. I will post back when I fix it.
flipp3r is offline
post #19 of 29 Old 06-04-2011, 02:25 PM
tilt's Avatar
Quoted: 9 Post(s)
tilt will become famous soon enough
Garage
anything new on this?
"Your best?! Losers always whine about their best. Winners go home and f**k the prom queen."
Professional Installer of Mobile Products
"They can be a great people, Kal-El, they wish to be. They only lack the light to show the way. For this reason above all, their capacity for good, I have sent them you... my only son." - jor-el
"Save the cheerleader, save the world..."
It's all shits and giggles until someone giggles and shits....
tilt is offline
post #20 of 29 Old 06-05-2011, 12:25 AM
Quoted: 0 Post(s)
I've been to busy to try it. I have just been dealing with it. It has never died or anything, it's just annoying to think that it might.
flipp3r is offline
