Help!! dash light-VSC,ABS,trac off,Brake - Scion xB Forum
post #1 of 126 Old 08-31-2009, 07:59 PM Thread Starter
sid
sid's Avatar
Quoted: 2 Post(s)
VSC,ABS,trac off,Brake indicator lights are all solid on.
It happened after i took off the battery(ground wire to post) for 4 hours, for some testing, then when I put it back on and drove half a block, i notice all this 4 indicator lights are on.
I didn't notice any limping on the motor, but i decided to go back home and use another car.
just got home, and started the xB, still same lights on.
Does anyone ever experience something like this?? whats the fix???
I did talk to Eric about this and just waiting if he find some answer, but if anyone knows, help!!!!
100 Pogi points added daily!!!
Get your camber plates now!!!
http://www.realcamber.com/
for your custom vinyl decals & signage
http://www.stickyicons.com/
sid is offline
post #2 of 126 Old 08-31-2009, 08:03 PM
ddjp
Quoted: 0 Post(s)
iluvmybb05 is on a distinguished road
Re: Help!! dash light-VSC,ABS,trac off,Brake
i had that same prob but my car was jerking so i used the obd 1 and it said i had a miss fire so i changed out my spark plugs and everything was koo but i dunno good luck
iluvmybb05 is offline
post #3 of 126 Old 08-31-2009, 10:25 PM Thread Starter
sid
sid's Avatar
Quoted: 2 Post(s)
well, kinda wierd lights. i started the xB, same 4 lights, normal idle, on park apply gas, seems normal. and why Brake warning indicator light on??? even hand brake were released??
i'ma try to drive it tomorrow and see if it limp, hope not.
sid is offline
post #4 of 126 Old 08-31-2009, 10:45 PM
I'm Awesome.
Toup's Avatar
Quoted: 1 Post(s)
Toup has a spectacular aura about Toup has a spectacular aura about
Sid. I know it's a common problem and most people say the car drives fine with them on...
Maybe this thread will help you a bit...
http://www.clubxb.com/forums/f28/eng...ing-24290.html
I do wish I was more help though...
Toup is offline
post #5 of 126 Old 08-31-2009, 10:48 PM
HaoleXB's Avatar
Quoted: 2 Post(s)
HaoleXB is on a distinguished road
Send a message via AIM to HaoleXB
only way to tell exactly what caused it, is to hook it up to the obd reader. to reset, just either disconnect the negative battery for 5 mins and then hook back up, or, you can removed the EFI fuse in the fuse block next to the battery for 2 or 3 mins, and that will have the same effect without erasing your stereo memory, etc. only drawback is that it will reset the mapping of your VVTI, and it will take a few drives for it to "learn" how you drive again.
post 666^^ oooh scary
HaoleXB is offline
post #6 of 126 Old 08-31-2009, 10:53 PM Thread Starter
sid
sid's Avatar
Quoted: 2 Post(s)
thanks toup, been reading it, closest scene is krazylowbox, i might check if i missed some lines, i doubt.
wes, did that too!(bat disconnect), still same
damn!!, who got obdi scanner?? taz anyone???
sid is offline
post #7 of 126 Old 08-31-2009, 11:02 PM
supermario6582's Avatar
Quoted: 1 Post(s)
supermario6582 will become famous soon enough
Send a message via AIM to supermario6582 Send a message via Yahoo to supermario6582
same thing happened to me when we installed some 10mm hub spacers. i drove it home and about half way there they went off.
supermario6582 is offline
post #8 of 126 Old 08-31-2009, 11:06 PM
Part-Time Alkoholik
Tarbaby75's Avatar
Quoted: 0 Post(s)
Tarbaby75 is on a distinguished road
Hey, I had a similar dash light up scenario, but you know what my issue was? I didn't secure my gas cap tight enough. It ran fine on the way home from work but I took it to Toyota and they hit me up for $100 just to tell me that I need to tighten up after refills. Talk about stupid but it was a good lesson learned. The codes threw a "fuel evaporation" code. Twist at least 4 good loud "clicking" turns. It happened 6 days after last fillup. Hope that helps!!!
Tarbaby75 is offline
post #9 of 126 Old 08-31-2009, 11:08 PM Thread Starter
sid
sid's Avatar
Quoted: 2 Post(s)
been taking on/off camber/spacer shims on mine for lots of time, with no problem. just today when i unplug the ground battery line.
did you fix it???
sid is offline
post #10 of 126 Old 08-31-2009, 11:09 PM
simplejdm's Avatar
Quoted: 0 Post(s)
simplejdm is on a distinguished road
sid, leave the car on for a bit, take it for a spin or just let it run for a while. get the alternator moving. if that doesnt help, gotta get the obd reader.
Formerly Cubedriven
simplejdm is offline
post #11 of 126 Old 08-31-2009, 11:15 PM Thread Starter
sid
sid's Avatar
Quoted: 2 Post(s)
oops, thats for mario
thanks john, i'ma do that tomorrow, i wanna do it right now but i don't want it to limp and die and get stuck away from the house at night
i did left it running for 10 minutes idling, but lights still there.
thanks, i know that goes with check engine light, i don't have the check engine light, i also tried that, still there.
sid is offline
post #12 of 126 Old 09-01-2009, 12:02 AM
I'm Awesome.
Toup's Avatar
Quoted: 1 Post(s)
Damn Eric with all the info.... This may be one of the most informative threads ever.
Toup is offline
post #13 of 126 Old 09-01-2009, 12:21 AM
HELA FASS DOOO
Quoted: 6 Post(s)
SAKURA has a spectacular aura about SAKURA has a spectacular aura about
also check yer alternator.
heres some info in regards to the dummy lights. first things first, go to the most simplest thing first. back track what you did prior to the dummy lights turning on. i.e. battery, connection, fuse, cables, etc.
btw, get a hold of either jason aka: "scvscions" or victor aka: "pch" theyre certified techs.
gluck bro.
Fail safe function:
When a failure occurs in the ABS & BA & TRAC & VSC systems, the ABS warning light and the VSC warning light turns on and the ABS & BA & TRAC & VSC operations are prohibited. In addition to this, when there failure that disables the EBD operation, the brake warning light also turns on and the EBD operation is prohibited.
05–259
PRECAUTION DIAGNOSTICS – ABS WITH EBD & BA & TRAC & VSC SYSTEM
05–264
PARTS LOCATION
68–1
POWER SOURCE LOCATION
05–324
LOW BATTERY POSTIVE VOLTAGE
19–13
STARTING/CHARGING SYSTEM
05–265
WARNING LIGHT TROUBLESHOOTING
05–334
ABS WARNING LIGHT CIRCUIT (REMAINS ON)
05–343
BRAKE WARNING LIGHT CIRCUIT
05–339
VSC WARNING LIGHT CIRCUIT (REMAINS ON)
05–347
TRAC OFF INDICATOR LIGHT, TRAC OFF SWITCH CIRCUIT
05–351
SLIP INDICATOR LIGHT CIRCUIT
05–314
ABS CONTROL SYSTEM MALFUNCTION
SAKURA is offline
post #14 of 126 Old 09-01-2009, 12:59 AM
Ain't too Funk to Druck.
Quoted: 5 Post(s)
ketchup_xb will become famous soon enough ketchup_xb will become famous soon enough
the same thing happen to me too sid. i thought it was the alternator. but it was just the "stock battery". purchased a new one. problem solved. i hope you get the problem solved. and have that baby dashlights on free.
HelaFassDooo
Thank you my HFD family from the bottom of my<3 for the rack!
2ZERO6FACTORY.COM
[B][COLOR="Cyan"]
ketchup_xb is offline
post #15 of 126 Old 09-01-2009, 01:45 AM
HELA FASS DOOO
Quoted: 6 Post(s)
btw, sid is running the red top optima which drained couple of times and have recharged it. iirc, optima needs to be trickled charge on high?
sid, have that battery checked. if anything, you should have a warranty on those or where you purchased them from if its not holding charge.
SAKURA is offline
post #16 of 126 Old 09-01-2009, 01:52 AM
Quoted: 5 Post(s)
oh gotcha. red optima. i went with the bosch one. so far never had problems. the dashlights and stalling never came back.
HelaFassDooo
2ZERO6FACTORY.COM
[B][COLOR="Cyan"]
post #17 of 126 Old 09-01-2009, 10:34 AM
Quoted: 3 Post(s)
Check all fuses and fusible links first.
PCH is offline
post #18 of 126 Old 09-01-2009, 11:15 AM Thread Starter
sid
sid's Avatar
Quoted: 2 Post(s)
I tested the alternator, its giving 13.99 volts, engine idle.
Battery gives 12.6-12.38(engine shut off), slowly draining.
Gave it a 5 block run this morning, no limping, but 4 lights still there.
I will drive it more later today and see how it goes.
i'm trying to save the Optima, draining(dead bat) only happen if i don't start the xB for 2 days.
victor, what fuse do you think is connected?? and where?
I only checked the 15A EFI fuse and its good.
and what is that A/C MG relay?? are we suppose to have one? mine doesn't have it.
sid is offline
post #19 of 126 Old 09-01-2009, 12:08 PM
Quoted: 3 Post(s)
I don't have that relay either, just empty plug. Guess that's not used on xB's.
Try checking all fuses. If you have a test light just probe both sides so you don't have to pull them out- very quick this way. What happend doesn't make much sense, but rule out the basics.
PCH is offline
post #20 of 126 Old 09-01-2009, 12:11 PM
HELA FASS DOOO
Quoted: 6 Post(s)
Fuse - POWER SOURCE LOCATION
SAKURA is offline
