Serpentine belt installation help - Scion xB Forum
post #1 of 18 Old 11-30-2011, 01:50 AM Thread Starter
Quoted: 3 Post(s)
One of the tricky steps during the serpentine belt replacement on 1NZ-FE engine is moving the alternator to get the correct belt tension. Many installs ended with damaging the VVT Control Valve because it sits very close to the alternator. Extra care needs to be taken when working near the valve and its connector:
A simple mod that costs less than $2 makes the belt tightening much easier and risk free. All we need are the M8x1.25 bolt with a nut and a washer:
The alternator tensioner bracket has a hole with the nut welded to the back of it- that is where the bolt needs to be installed and tightened with the jam nut:
Now it can be used as the safe leverage point to move the alternator:
Good sources for metric fasteners are ACE Hardware and Do it Center stores.
Hope that helps.
PCH is offline
post #2 of 18 Old 11-30-2011, 07:43 AM
RS4 #303
sdsnybny's Avatar
Quoted: 67 Post(s)
sdsnybny has a spectacular aura about sdsnybny has a spectacular aura about
Garage
Re: Serpentine belt installation help
Perfect Victor and great pics of the tight location
Steve
#303 MYRS4XB/single parent its all good style
sdsnybny is offline
post #3 of 18 Old 11-30-2011, 07:49 AM
bbszero's Avatar
Quoted: 6 Post(s)
bbszero will become famous soon enough bbszero will become famous soon enough
Garage
Damn, that is brilliant Victor! Gotta do the belts on the new box soon, gonna do this for sure!
Hub Spacers * Camber * Plate Mounts * HVAC Knobs * NS Wheels *Clazzio Seat Covers * Grip Royal steering wheels* and more.....
THE FACTORY HAS COMPLETE AIR RIDE KITS STARTING AT 1,425!
[url]http://www.facebook.com/?
bbszero is offline
post #4 of 18 Old 11-30-2011, 09:59 AM
ogerdgonz's Avatar
Quoted: 19 Post(s)
Send a message via Skype™ to ogerdgonz
Isn't it extra tricky to do a serpentine belt on our car since we do not use a serpentine belt..... Only kidding. Once again excellent advice and detailed photos from Victor.
National Sales Rep for Dare 2B Different Motorwerks
Check out the new Facebook Page
http://www.facebook.com/D2BDmotorwerks
ogerdgonz is offline
post #5 of 18 Old 11-30-2011, 11:57 AM Thread Starter
Quoted: 3 Post(s)
LOL, you don't say. Especially since we don't have an alternator either. According to the tech literature it's a generator. And the belt: the fan and generator V–ribbed belt
Thanks guys. I'm gonna attack my belts soon, already got the genuine Mitsuboshi from the dealer. Thinking if i should change the water pump at the same time since i'm at 80K.
PCH is offline
post #6 of 18 Old 11-30-2011, 12:12 PM
RS4 #303
sdsnybny's Avatar
Quoted: 67 Post(s)
Garage
Gates makes racing belts for our cars in blue
Steve
sdsnybny is offline
post #7 of 18 Old 11-30-2011, 12:29 PM Thread Starter
Quoted: 3 Post(s)
They look real nice. I also thought about GatorBack – some people have good words about them. But decided to stick with the originals. Mitsuboshi lasted more than required and i only had to tighten it once.
PCH is offline
post #8 of 18 Old 12-02-2011, 06:43 PM
linuxBx's Avatar
Quoted: 0 Post(s)
linuxBx is on a distinguished road
I replaced the same belt just the other day before joining this forum (this tip sure would have been useful). I still took care of not damaging anything around there when trying to put tension on the belt. Since then when I use the AC, there is still some squeaking. So I might just end up doing this again... I just dread trying to get to the bottom bolt because the last time my arm got stuck between the radiator and the alternator. Thanks for the tip!
linuxBx is offline
post #9 of 18 Old 12-03-2011, 02:35 PM Thread Starter
Quoted: 3 Post(s)
Make sure you don't overtighten the belt because that will put more stress on the water pump and that's a real weak spot. If you just can twist the longest part of the belt (between alternator and main pulley) by hand 90 degrees but no more than that- that's tight enough. Lower quality belts will squeak even when they are tight.
Factory belt replacement manual (thanks Tomas!): http://scionlife.org/Scion_Docs/2004...eplacement.pdf
PCH is offline
post #10 of 18 Old 12-03-2011, 03:56 PM
HELA FASS DOOO
Quoted: 6 Post(s)
SAKURA has a spectacular aura about SAKURA has a spectacular aura about
two thumbs up victor!
SAKURA is offline
post #11 of 18 Old 12-04-2011, 01:41 AM Thread Starter
Quoted: 3 Post(s)
Thanks Eric, HFD are good people
Another thing that sometimes gets difficult is breaking the alternator pivot bolt loose. You only have to give less than one complete turn to be able to move the alternator but the bolt is extra tight (Bolt "B" in the factory diagram).
We need 14mm socket, ratchet and some extra leverage:
Now the job is much easier. A/C line is held out of the way with electrical tape or a zip tie:
PCH is offline
post #12 of 18 Old 12-04-2011, 07:37 PM
TTxB's Avatar
Quoted: 0 Post(s)
TTxB is on a distinguished road
The Gates Racing Belts are very nice and they are a cool blue color, too.
I got the 2 of them. Sometimes on Amazon they sell them as used for a much lesser price. But they are not used, they are merely open boxed.
---------- Post added 12-04-2011 at 03:38 PM ----------
Or the box is shelf worn and they cant sell them full price.
TTxB is offline
post #13 of 18 Old 03-04-2012, 11:59 PM
GET TO DA TOASTA!!!!!!!!!
hectarpit's Avatar
Quoted: 0 Post(s)
hectarpit is on a distinguished road
Send a message via AIM to hectarpit
This is a great write up if i get the guts to do it ill definitely keep this open.
and dang you must have the cleanest engine bay in the world!
hectarpit is offline
post #14 of 18 Old 03-05-2012, 08:58 AM
Its a box.
ProLogics's Avatar
Quoted: 0 Post(s)
ProLogics is on a distinguished road
Used this when I did my belt! Work perfect!
I was having trouble getting it tight before doing this!
Great write up!
2006 BSP
ProLogics is offline
post #15 of 18 Old 05-07-2012, 05:30 PM
LowBoxLife
Shoeboxtop's Avatar
Quoted: 1 Post(s)
Shoeboxtop is on a distinguished road
Dang Victor I wish I had read this cuz it cost me 78 bucks to replace the oil control valve but the water pump is still leeking so I guess I will be changing it next weekend. But once again thanks for all the help and tips bro I really do appreciate it.
jORDAN
Shoeboxtop is offline
post #16 of 18 Old 05-08-2012, 12:05 AM Thread Starter
Quoted: 3 Post(s)
Man, sorry it had to happen to you. Good luck with the water pump, i may have that replaced in future and not too looking forward to it. I hope it still lasts though.
PCH is offline
post #17 of 18 Old 05-08-2012, 04:53 PM
LowBoxLife
Shoeboxtop's Avatar
Quoted: 1 Post(s)
thanks I will let you know how hard it is when I get done and if I find a trick or two I will let you know.
jORDAN
post #18 of 18 Old 07-14-2012, 03:28 PM
Mini Trucker
91extcab's Avatar
Quoted: 0 Post(s)
91extcab is on a distinguished road
I never did like tightening up alternators that you had to put leverage on to get the belt tight... On my truck its got a built in tensioning system... Where you tighten one bolt and that bolt you turn pours tension on the belt for you... Then you causally tighten your remaining bolts... I might have to come up with with a way of adapting one for use on the xb when I finally get one... I'll make a diy out of it... Lol
---------- Post added 07-14-2012 at 04:29 PM ----------
Puts not pours, auto correct
Leland
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my ride!"
91extcab is offline
