Automatic shifter overhaul and shortening project - Scion xB Forum
post #1 of 12 Old 11-21-2011, 12:28 AM Thread Starter
Quoted: 3 Post(s)
I have been contemplating this mod since the first day I had my xB. Just lowering the stock handle a little bit was all I wanted and thanks to Cliff/bbszero I got a shifter I could experiment with and not risk messing up my car.
Basic removal and disassembly steps for the Auto shifter are available here: http://scionlife.org/Scion_Docs/2004...t/overhaul.pdf
I took some pictures in the process that may help someone doing similar repair or modification work. Exploded view of the shifter with all components:
Even though it has so many parts, taking everything apart is fairly easy and does not require any special tools. The only tricky step is removing the lever from the base. The inner push rod is held by the pressed pin that needed to be knocked out with the help of a punch and a deep socket on the other end:
That operation is only necessary when keeping the factory T-handle because the tube needed to be tapped at the new screw locations and the push rod needed to be shaved and rounded off:
One of the parts that can give problems during the car's life is the shift release solenoid (allows shifting only when the brake pedal is depressed):
Putting everything together is fairly easy. White Moly grease is used on all the parts that rub:
Routing the wires for the Over Drive switch and illumination:
They share the connector so the pins for OD harness needed to be unpacked from the plug during the disassembly:
And there it is: lower by 1.5" than stock. As subtle as this mod is, I am happy with it
PCH is offline
post #2 of 12 Old 11-21-2011, 12:34 AM
HELA FASS DOOO
Quoted: 6 Post(s)
SAKURA has a spectacular aura about SAKURA has a spectacular aura about
Re: Automatic shifter overhaul and shortening project
props to PCH for taking it to the next level!
and thumbs up to Cliff/bbszero
SAKURA is offline
post #3 of 12 Old 11-21-2011, 12:37 AM Thread Starter
Quoted: 3 Post(s)
To the lower level Thanks Eric!
PCH is offline
post #4 of 12 Old 11-21-2011, 06:07 AM
XB05's Avatar
Quoted: 0 Post(s)
thats tight! *hands down*
WTB: Boo Boos
XB05 is offline
post #5 of 12 Old 11-21-2011, 06:12 AM
Zman's Avatar
Quoted: 106 Post(s)
Zman will become famous soon enough Zman will become famous soon enough
Pics in the car!
Now it wont look like a school bus shifter anymore lol.
Zman is offline
post #6 of 12 Old 11-21-2011, 06:42 PM Thread Starter
Quoted: 3 Post(s)
School bus lol. Yes, I was going for more comfort with it. Also smoothed out the bumps for the detent spring so it doesn't feel as notchy:
I'll take pics of it installed but honestly it doesn't show much. Unless you put two shifters side by side
PCH is offline
post #7 of 12 Old 11-21-2011, 07:49 PM
Quoted: 67 Post(s)
DTRAIN619 is a jewel in the rough DTRAIN619 is a jewel in the rough DTRAIN619 is a jewel in the rough
Garage
Shortened auto shifter FTW!!! Excellent craftsmanship as usual, Victor.
Transmitted via my Stormtrooper Comlink
post #8 of 12 Old 11-21-2011, 10:29 PM
RS4 #303
sdsnybny's Avatar
Quoted: 67 Post(s)
sdsnybny has a spectacular aura about sdsnybny has a spectacular aura about
Garage
Up to the same old tricks again Victor,
excellence as expected. Carry on.
Steve
#303 MYRS4XB/single parent its all good style
sdsnybny is offline
post #9 of 12 Old 11-21-2011, 11:50 PM
I love Box
Box Lover's Avatar
Quoted: 0 Post(s)
Box Lover is on a distinguished road
Wow that's awesome! I need to do that! I remember I saw some where a few years ago a shift boot for our auto stick, does anyone know where to find them?
2005 Scion xB
2004 Porsche Boxster
Box Lover is offline
post #10 of 12 Old 11-22-2011, 06:01 AM
Zman's Avatar
Quoted: 106 Post(s)
I want to see if it's level with the front seats.
I've had mine bumped into neutral by a passenger's knee, if it were lower that wouldn't happen.
Zman is offline
post #11 of 12 Old 11-22-2011, 04:26 PM Thread Starter
Quoted: 3 Post(s)
Zman it's still higher than the seats. I was only able to drop it 1.5" because i wanted to keep stock handle. You can do more with the aftermarket one for sure. Old DIY on that: Automatic Shifter Knob replacement and lowering
I'll try to snap a pic of it installed tonight.
Box Lover check Sponsored Sales in the Classified may be Redline Goods have the boot for autos. Scion Shoppe used to sell them but they closed long time ago.
Thank you Dion and Steve It was an easy project. Only cutting and drilling/tapping two new holes:
Factory screws are M4x0.7 thread so i had to get metric tap for $5.
PCH is offline
post #12 of 12 Old 11-30-2011, 03:16 PM
Quoted: 0 Post(s)
tommyt is on a distinguished road
this is awesome! this will be my next upgrade!
tommyt is offline
