Old 11-17-2009, 09:03 PM   #1
xbsmitty is on a distinguished road
Will they rub??
I'm still rim/tire shopping and came across a set of 18's that are 8 wide with 45 offset, will they rub?
xbsmitty is offline   Reply With Quote
Old 11-17-2009, 09:08 PM   #2
Lifex's Avatar
Lifex will become famous soon enough
Re: Will they rub??
nope - those are the specs on the TRD upgrade wheels for xB's - except they are 7.5" wide and you will need to run a set of 10mm spacers to clear the rear suspension brace - also if you are lowered (a lot - like 3"+) you will need to make sure you aren't gonna bite your fenders when you turn
Lifex is offline   Reply With Quote
Old 11-17-2009, 09:15 PM   #3
Re: Will they rub??
Cool, thanks for the info. Also, I see some guys are runnin' 20's on their box's, what size 20's will work on an xB?
Old 11-17-2009, 09:18 PM   #4
Lifex's Avatar
Re: Will they rub??
like width wise? it would be dependent on the offset, but once above +45et then you need to start putting in spacers to clear, I haven't seen anything bigger then 20" diameter and the timing gets WAY screwed up anyways going that big or beyond. but the 18's are fine cuz they are available as upgrades from toyota dealerships
Old 11-17-2009, 09:21 PM   #5
Re: Will they rub??
Cool, sounds good. thanks again
Old 11-18-2009, 09:38 AM   #6
ocotillo's Avatar
Re: Will they rub??
The TRD wheels for the Gen 2 are 19", not 18".
ocotillo is offline   Reply With Quote
Old 11-18-2009, 11:03 AM   #7
Lifex's Avatar
Re: Will they rub??
I drive a gen1 - therefore I assumed smitty had a gen1 . . .oh well, cuz I have also seen 20's on gen1's and you could probably go to 22's on gen 2's - whoops, muh bad
Old 11-19-2009, 09:17 PM   #8
Re: Will they rub??
Ok, I got another one here for you...What about 18" factory SC430 rims/tires? Has the same lug nut pattern, 255/45/18 tires, 8 width, and 45 offset. Will they fit?
and another set I'm looking at are on 215/40/18 tires, and 42 offset?
Old 11-19-2009, 09:44 PM   #9
Lifex's Avatar
Re: Will they rub??
not too keen on the gen 2 clearance but I imagine the SC430 rims will fit fine - im just not sure what stock tire size is for gen2's
Old 11-20-2009, 06:58 AM   #10
ocotillo's Avatar
Re: Will they rub??
255 tire width? On an 8" wheel?
Pink Rims?
20's on an 08???
Show me your Wheels & Tires
Staggered rims on 08
Sittin on 20's
Show me your deep lips!
Page generated in 0.18941 seconds with 13 queries
