Old 10-02-2007, 02:47 AM   #1
Big Joe xB
rokji is on a distinguished road
Question How to Turn off Tire pressure monitor?
Anyone knows how to turn this off?
light is always on with new wheels.
rokji is offline   Reply With Quote
Old 10-02-2007, 10:44 AM   #2
its what you do with it.
WhiteNoise's Avatar
Re: How to Turn off Tire pressure monitor?
I do not know how to turn them off but I believe that you can have the sensors taken out of the old wheels and mounted in the new ones. Someone correct me if I'm wrong.
Old 10-02-2007, 11:14 AM   #3
EticketXb's Avatar
EticketXb is on a distinguished road
These new air pressure monitoring systems are required on all cars now. The only way to turn off the light is to put the sensors into your new wheels. I still have lots of friends in the wheel and tire biz and none of them have figured out how to turn any cars air pressure light off. Best of luck. If all else fails take apart the dash and get a black sharpie and color it black.
EticketXb is offline   Reply With Quote
Old 10-03-2007, 09:48 PM   #4
ToyotaTech is on a distinguished road
What we did on my anouther techs Tacoma because he put on some wheels and tires was we took the sensors out of his stock wheels and then broke down his spare tire placed all 4 sensors inside then inflated the tire to 32 psi and no more lite u just better hope u dont get a flat or u will destroy the sensors and they are expensive.
i think im gonna try this next time, using the toyota scan tool go in and get all the regisration id's and programe all the id's the same so u can put 1 sensor in the spare and thats it of course our cars have a doughnut but if u had a full size spare it would be perfect.
ToyotaTech is offline   Reply With Quote
Old 10-03-2007, 10:38 PM   #5
Elements893's Avatar
Elements893 is on a distinguished road
i actually had the tireshop install the pressure sensors from my original tires in my rims. might wanna go to a wheel shop and remove the tire to get the sensors installed.
Elements893 is offline   Reply With Quote
Old 02-21-2008, 12:50 AM   #6
soaringbird is on a distinguished road
a lot auto shops can transfer the sensors. transfered mine for about $20
soaringbird is offline   Reply With Quote
Old 02-23-2008, 01:45 PM   #7
ronsweden's Avatar
ronsweden is on a distinguished road
I like that idea the best because with alloys and low profiles, a loss of air is more serious than with a stock 50-60 sidewall. Ron
ronsweden is offline   Reply With Quote
Old 02-23-2008, 01:51 PM   #8
Scikotic
Daarken's Avatar
another easy way to do this is to grab a length of pvc pipe, stuff some rags in it, stuff your tpms's in it, cap/eal it off, and put a threaded air valve on one end, and pump it up with air to 35psi, and toss it in the back of the car.
Old 02-23-2008, 02:49 PM   #9
ronsweden's Avatar
Interesting...very interesting. But won't it blow up? Ron
Old 02-25-2008, 12:28 PM   #10
KUxB's Avatar
KUxB is on a distinguished road
You could just transfer the senors but the thing about the senor in my xb vs my bimmer is the xb does not tell you what tire and how low it is. I am going to look for the fuse and pull that out. That should do the trick if it is and independent fuse.
KUxB is offline   Reply With Quote
Old 02-25-2008, 04:10 PM   #11
WhiteNoise's Avatar
Why disable it? The tireshop I went to just transfered them from my stock tires to my new ones at no charge.
Old 02-26-2008, 12:31 PM   #12
ronsweden's Avatar
I think I read somewhere that they are going to make the monitors mandatory. For those of us in the snow belts, that would mean either:
1. buying new ones for the winter tires (I run 18s in the warm months, stock 16 rims with snow tires in the winter), or
2. changing your auto inspection date to a cold month like February when you'd have the stock wheels on and the monitors would work.
I'm frugal and opt for a February inspection sticker. Thanks, Ron
Old 02-26-2008, 12:58 PM   #13
KUxB's Avatar
Because in the winter here I will be putting the stock wheels back on and dont want to keep swapping sensors back and forth. And extra sensors are a little pricey for just saying that tire is low and not telling me which tire i slow and how low it is.
Old 02-26-2008, 01:43 PM   #14
WhiteNoise's Avatar
Originally Posted by KUxB View Post
Because in the winter here I will be putting the stock wheels back on and don't want to keep swapping sensors back and forth. And extra sensors are a little pricey for just saying that tire is low and not telling me which tire i slow and how low it is.
Sorry I forget about that whole snow and ice thing. I couldn't stand to have that light on all winter.
Old 02-26-2008, 02:53 PM   #15
ronsweden's Avatar
For reasons beyond my comprehension, the light goes off for a day or so. I'm getting used to it. Sort of. Thanks, Ron
Old 02-26-2008, 06:35 PM   #16
FirstHuman is on a distinguished road
is the sensors on 06 as well?
FirstHuman is offline   Reply With Quote
Old 02-26-2008, 09:20 PM   #17
ronsweden's Avatar
I don't believe so as they didn't change much, except for the RLs, from '04-07. Ron
Old 02-27-2008, 12:48 AM   #18
kev_xb is on a distinguished road
i work with tires all day (goodyear) the way the sensors work, at least on the new xB is its a unit that replaces the valve stem, if you break down the wheel it looks like a valve stem with a box on the bottom, and with a simple socket wrench you can transfer it to just about any wheel you want... its really easy and any tire shop should be able to do it for you at little to no charge...
... and if you take your car back to the same shop come winter time, they shouldn't have any problem swapping them back...
kev_xb is offline   Reply With Quote
Old 02-27-2008, 12:53 AM   #19
bB Squad
AirecK's Avatar
i need to do this to my Expedition tires.....
Old 02-27-2008, 01:52 PM   #20
ronsweden's Avatar
What's nice about this resource is there's always someone who really knows what he/she's talking about. And for tire monitors, kev_xb is that person. Thanks much. You solved, I beleive, everyone's problems. Ron
Pink Rims?
20's on an 08???
Show me your Wheels & Tires
Staggered rims on 08
Sittin on 20's
Please pick one from these rims
Page generated in 0.24222 seconds with 14 queries
