Old 07-17-2009, 09:29 PM   #1
aslader13 is on a distinguished road
anyone running 0 or low offset on a gen 2?
I am looking into a set of 0 offset wheels for my 08 and looking for some help. I can only get the wheels in a 0 offset 17 x7. I was wondering if anyone had a setup close to this and has any probles (wheel bearings, rubbing, turning...) ? I also live in RI so the roads suck here, so ride quality is an issue as well. Thanks for the help
aslader13 is offline   Reply With Quote
Old 07-17-2009, 09:39 PM   #2
Yeup!
Exist's Avatar
Exist is on a distinguished road
Re: anyone running 0 or low offset on a gen 2?
ur only 17x7 it should be fine.
and 0 looks good on a stock body.
at most you will have to roll your fenders but a soft mallet will solve that
Exist is offline   Reply With Quote
Old 07-17-2009, 09:46 PM   #3
I have a black 08 and I am looking at american racing salt flat specials, the painted ones. They are really a hot rod rear wheel drive wheel but I hope they will work. I may be able to order them with a +5 offset.
Old 07-17-2009, 09:47 PM   #4
Yeup!
Exist's Avatar
I have them in a 15x10 - 25 lol.
so I think you will be ok, it all depends if you have coils springs etc.
Old 07-17-2009, 09:54 PM   #5
At least you are 3,000 mi away and we probably won't be running into each other. Any pics of low offset wheels on a gen 2 would be great. I really don't plan on dropping the box much. It is a daily driver and my wife is pregnant so I will soon have a little one in back that I don't want bouncing out of her car seat. I don't mind a little bit of wheel and tire sticking out but not a ton. I know a few of you so cal negative camber -200 offset guys don't mind showing some rubber.
Old 07-18-2009, 09:03 AM   #6
Mother Lover...
I have the 0 offset 512's 16x8.
Old 07-18-2009, 10:52 AM   #7
They look great. Do you have any rubbing, turning or any other problems? How are they on the highway at 80mph. The wider stance must feel nice on corners. I'm trying to find out as much info as possible before I purchase some wheels. If I am going to be burning up wheel bearings then I may go with a higher offset. I am also staying at stock ride height for a while. If I do go lower it will only be a small amount.
Old 07-18-2009, 01:13 PM   #8
Mother Lover...
Yes they rub. I'm on Df210's in the front, stock '05 xB springs in the rear. Fronts rub on almost anything if you have a little bit of speed. Speed humps, quick cornering, dips, etc. Rears rub with three adults in the back and bad roads or dips on Highway. Don't even try Df210's in the rear, Ha. I had to put my 1Gen springs on after a week of the most carefull driving. I need sway bars atleast, probably help. I love the look and feel, If I could get around the rubbing issues, I don't think I could be happy with regular offset wheels now.
Old 07-18-2009, 01:23 PM   #9
what do you think if i ran stock springs? id sacrifice lowering the box for the wheels i really want.
Old 07-18-2009, 08:33 PM   #10
Mother Lover...
I don't know, it would look funny to me. Like a rollerskate or something.
Old 09-10-2009, 01:04 PM   #11
marked03's Avatar
marked03 is on a distinguished road
PADANKY, do you think if you ran tanabe nf210's or gen1 xb springs all around would you still have some rubbing issues? Im looking to get some 16x8 0 offset, but i do not want to deal with any rubbing or having to roll my fenders.
marked03 is offline   Reply With Quote
Old 09-10-2009, 08:00 PM   #12
Maurice is on a distinguished road
Hello,
My name is Maurice, and I am also in love with a low offset wheel.
I found the XXR 512 in an 18x8, and I love the hot rod look of it. On their website, they even have a picture of a Gen2 xB with them mounted!
You can see them at: www (dot) xxrwheels (dot) com/sportmax_512.shtml
Sorry, I can't include links in my messages yet!
When I spoke with a tire person at Les Schwab, he said that the +15 offset would require rolling of the fenders, and possibly more work to make them fit without rubbing.
My 2009 xB has TRD lowering springs, shocks and sway bar, so I already have given up some clearance. Anyone think I would be able to run that wheel without too much rubbing? If not, would rolling the fenders be enough to provide the clearance I would need? Could I make the situation better with a particular tire size, maybe?
The xB is my daily driver, so I don't want to make it into something that rubs on every little bump and corner.
Thanks a lot for your help! This forum is by far the best I have found for xB information. It's nice to know there are others who love their xBs like I do!
Maurice is offline   Reply With Quote
Old 09-11-2009, 02:43 AM   #13
Wow, that's one loooooong sentence.
And yes, we are all aware that you can't post links yet...
Anyway, someone else can answer this one.
Old 09-13-2009, 12:02 PM   #14
azztinthebox's Avatar
azztinthebox is on a distinguished road
Send a message via AIM to azztinthebox Send a message via Yahoo to azztinthebox
I have 16x8 0 offset same as padanky but I am running df210s all around on 195/45, I have wheel gap now. However I think you could run a 205/50 and not rub with rolling rear fenders.
This is how it sits with the df210s. I plan going much lower w/coilovers so thats why I went with the 195/45
Last edited by azztinthebox : 09-13-2009 at 12:02 PM. Reason: Automerged Doublepost
azztinthebox is offline   Reply With Quote
Old 09-13-2009, 12:19 PM   #15
Cubist
Hondaguy12's Avatar
Hondaguy12 is on a distinguished road
Send a message via AIM to Hondaguy12
^ looks great man..cant wait to see it lower..
Hondaguy12 is offline   Reply With Quote
Old 09-13-2009, 01:28 PM   #16
Blackscionxb
blackscionxb's Avatar
blackscionxb is on a distinguished road
Man that's pretty nice. what brand tire did ou go with?
blackscionxb is offline   Reply With Quote
Old 09-14-2009, 01:17 AM   #17
it looks hella nice. fender flares?
Old 09-15-2009, 08:20 PM   #18
no fender flares for the gen 2, when the coilovers are put on the fenders will be pulled and rolled more so they will flare enough to hopefully tuck all the way around! thats my plan of attack for now.
oh yeah and i'm running yokohoma s-drive tires they are amazing!
Last edited by azztinthebox : 09-15-2009 at 08:20 PM. Reason: Automerged Doublepost
Old 09-19-2009, 02:43 PM   #19
SheaMc is on a distinguished road
Man i love that look. I like the red rims on the white that looks nice.
SheaMc is offline   Reply With Quote
Old 09-20-2009, 09:35 AM   #20
Thanks for the comments guys: it deffinitly turns heads going down the road
Pink Rims?
20's on an 08???
Show me your Wheels & Tires
Staggered rims on 08
Sittin on 20's
Please pick one from these rims
Page generated in 0.27431 seconds with 14 queries
