09-28-2009, 12:44 AM
#41 | | elusive_xb
| Re: anyone running 0 or low offset on a gen 2? Quote:
Originally Posted by azztinthebox Sounds goood padanky!
What wheels do you have now elusive? | i just got a set of RED 16x7 sportmax xxr 002's and im looking to trade 2 for 2 |
09-28-2009, 01:41 PM
#42 | | Registered User
| Re: anyone running 0 or low offset on a gen 2? |
09-28-2009, 04:51 PM
#43 | | elusive_xb
| Re: anyone running 0 or low offset on a gen 2? i donno lol how do i check? |
09-28-2009, 07:01 PM
#44 | | Mother Lover...
Originally Posted by azztinthebox Ah what offset? | It's a +38 |
09-28-2009, 07:04 PM
#45 | | Registered User
| Re: anyone running 0 or low offset on a gen 2? woah, hmmm i think that would be to much for me |
09-30-2009, 01:45 PM
#46 | | Registered User
| Re: anyone running 0 or low offset on a gen 2? I am interested to see more wide wheels with low offsets - not that I am changing the wheels on mine anytime soon - but I like the idea and I have done some wide(r) wheels on my VW's in the past. Check out stanceworks - those crazy cats are doing some mad stuff with some wide wheels. |
09-30-2009, 10:21 PM
#47 | | Registered User
| Re: anyone running 0 or low offset on a gen 2? yeah, but the new xb's fenders won't allow to much roll and pull action so slammed out on real wide wheels without cutting is a hard on to pull off. |
10-01-2009, 08:44 AM
#48 | | Registered User
| Re: anyone running 0 or low offset on a gen 2? Use the force you must.
Someone has to have a decent fender roller or some mad old school skills here. I have rolled fenders a bajillion times, but the metal is different for german and japanese. I will look at them tonight and see what you guys are up against. |
10-01-2009, 09:28 AM
#49 | | Registered User
| Re: anyone running 0 or low offset on a gen 2? I used an actuall roller for mine that mounts to the hub, I'm gonna go for round two when I get the coilovers, the problem is the bumpers they are mounted so high up on the fender that its hard to get them to match if you pull and roll is what I am fearing. |
10-01-2009, 10:22 AM
#50 | | Registered User
| Re: anyone running 0 or low offset on a gen 2? I now see what you are saying. the transition from the bumper to the fender is a much greater transition because of the height - and it would make you look almost widebody fender'd to do that without some form of bumper pull as well. |
10-01-2009, 01:27 PM
#51 | | Registered User
| Re: anyone running 0 or low offset on a gen 2? Exactly but if your running the wheel tire combo you only have maybe 6 to 7 inches of clearance with the df210s that is from bottom of car to ground |
10-12-2009, 07:55 PM
#52 | | Mother Lover...
| Re: anyone running 0 or low offset on a gen 2? I just ordered the 205/45/16's Falken's 912's for $329, weather is getting shitty nowadays so I figured new tires now is cheaper than paying my insurance deductable later driving on soon to need replaced tires. I'll post pics up when I get them in and put on.
14k miles good for our stockers? I don't baby it at all!
this size tire will make it 1.6" lower not counting the little stretch. Accoding to this easy to use calculator: Tire Dimensions Made Simple - Discount Tire
10-15-2009, 01:01 AM
#53 | | Registered User
| Re: anyone running 0 or low offset on a gen 2? I only got 14k outta my stockers before I was showing wire. I'm at 1.97" difference, thats why I bottom out everywhere. It knocked my speedo off 5 mph. So if my speedo reads 65 i'm really only going 59...interesting, I thought something was different. |
10-16-2009, 07:44 AM
#54 | | Registered User
| Re: anyone running 0 or low offset on a gen 2? Still rollin on my Stockers, just crested 25K, still have a lot of tread. I have an auto so no burnouts, and I rotate them every 5K.... |
10-16-2009, 05:06 PM
#55 | | Mother Lover...
Originally Posted by BlackKnight Still rollin on my Stockers, just crested 25K, still have a lot of tread. I have an auto so no burnouts, and I rotate them every 5K.... | Yeah, I'm a stick and have made about 10 passes down the 1/8th mile. And I drive it hard, two rotations. Got a $130 ticket a couple weeks ago for "Digging out" long 2nd gear burn out of first screwing with a Vette. |
10-16-2009, 06:56 PM
#56 | | Lock n' LOAD
| Re: anyone running 0 or low offset on a gen 2? I'm runnin' 10 psi. BOOST. |
10-16-2009, 07:25 PM
#57 | | Mother Lover...
Originally Posted by TheXfactor I'm runnin' 10 psi. BOOST. | And?????????? |
10-17-2009, 03:28 AM
#58 | | Registered User
| Re: anyone running 0 or low offset on a gen 2? I'm running no psi, woo hoo for cheap gas and still can do hella burnouts in first and second...fail.... Mine wore quickly due to autocross, and zero rotations. My new tires are holding up better though, I may just get some more miles outta them. |
10-19-2009, 11:09 AM
#59 | | Registered User
| Re: anyone running 0 or low offset on a gen 2? Hello all,
I finally decided, after trying XXR 502s and not liking the look, to go with 18" XXR 512s. They were mounted up this weekend, and I am pretty happy with the way they fit. The fronts stick out about 1/4" past the edge of the fender, and the rears are flush. I am running TRD lowering springs, so I stil have a decent amount of clearance. I will get a picture up this evening so people can see what they look like.
I would like to stretch the front fenders slightly, to get the fronts closer to flush. I know there is the risk of paint cracking, but is there any risk of damaging any mechanical components? |
10-19-2009, 12:45 PM
#60 | | Mother Lover...
I would like to stretch the front fenders slightly, to get the fronts closer to flush. I know there is the risk of paint cracking, but is there any risk of damaging any mechanical components? | No mechanical damage, you'll burn through the fender liner clips if anything (ones near front bumper bolts up, on the backside of the fender). |
