Old 12-03-2007, 01:21 PM   #1
Bon Jersey!!!!
whitebreadbox's Avatar
whitebreadbox is on a distinguished road
Question under seat sub
i've been looking for trunk space solutions. right now i have a 10" in a wedge box the trunk. every time i have to get under the rear cover, i have to pull it out. and since no one is making an enclosure (that looks well made!!!) for the right rear sunken panel, i was thinking of going under the front pass seat. has anyone tried this one http://www.edesignaudio.com/edv2/pro...roducts_id=463 ? i contacted them and they said its about .3cf. does anyone know of a sub that works well with that space, that can handle 400w and has 2 voice coils? how is the sound with it being there. does it fill the car evenly like a rear fire? any info and help would be great. thank you!!!
whitebreadbox is offline   Reply With Quote
Old 12-03-2007, 03:41 PM   #2
LoneWolf
LoneWolf51's Avatar
LoneWolf51 is on a distinguished road
Send a message via ICQ to LoneWolf51 Send a message via AIM to LoneWolf51 Send a message via MSN to LoneWolf51 Send a message via Yahoo to LoneWolf51
Re: under seat sub
have you seen this one? http://cgi.ebay.com/SCION-xB-Gen2-Su...QQcmdZViewItem
a bit pricey but, its tempting to not lose the cargo space and not have to fab something up.
LoneWolf51 is offline   Reply With Quote
Old 12-03-2007, 07:13 PM   #3
Lvbitwiz's Avatar
Re: under seat sub
Finished this the other day, granted I still needed to wire it up when I took this but you get the idea
Old 12-03-2007, 07:43 PM   #4
Bon Jersey!!!!
Re: under seat sub
THAT is what i want. did you build it or buy it? it looks great. i want to know how it sounds!!!!!
Old 12-03-2007, 07:56 PM   #5
Lvbitwiz's Avatar
Re: under seat sub
built it, there's a DIY up on scionapocalypse.com
Old 12-04-2007, 10:22 AM   #6
Bon Jersey!!!!
Re: under seat sub
well, damn good job on the build. i don't think i'm ready to tackle a fiberglass job just yet. i just got some good advice from "the other site" on an under seat sub and purchased a box that needs a bit of modification and a new fosgate 2ohm DVC sub. so thank you to ScionFred!!! and thank you to those who offered suggestions. and if this set up sounds like crap, whould you like to build me one of those???
Old 12-06-2007, 12:13 AM   #7
Re: under seat sub
This is my 10" underseat sub setup. The box is 12"x13.25"x7.5", down-firing and has a volume of .3cf. The box is from Ebay, the stand-offs are made from 7/8" dowel rod with rubber slip-on feet and the driver is a 2 ohm SQ10 from eD. It fits well, sounds great, doesn't waste any cargo space and is unlikely to get any windows broken to steal it.
I had to relocate the black sensor module and the wiring connectors to the top of the metal rail and bend the sensor bracket arms up for clearance. There was one more connector towards the back that had to be relocated. I removed the metal bracket and just stuffed the connector under the seat cover.
Lvbitwiz: Great job on that box! I wish I knew how to do glass work.
whitebreadbox: I hope you noted that the box only has 4.25" of mounting depth. That's why I went with the 3" deep SQ10. If you got the shallow RF 10", it should work great. I don't recall if I mentioned it already but you'll need to caulk the driver-side panel seams in the box. I used a small squeezable tube because a caulk gun won't fit. I wish I could hear your finished setup.
Old 12-06-2007, 06:03 PM   #8
Bon Jersey!!!!
Re: under seat sub
whitebreadbox: I hope you noted that the box only has 4.25" of mounting depth. That's why I went with the 3" deep SQ10. If you got the shallow RF 10", it should work great. I don't recall if I mentioned it already but you'll need to caulk the driver-side panel seams in the box. I used a small squeezable tube because a caulk gun won't fit. I wish I could hear your finished setup.[/quote]
hey fred, yes, you mentioned the caulking. i will be caulking and then putting the "b-quiet" inside it as well to dampen the mdf a bit. soaks up the sonic resonance. yes, the RF p3sd210 http://www.rockfordfosgate.com/produ...n_US&p_status=
is a piece of art!!! from their recommendations, the box should be from .4-1.0cf with the best being .5cf i'm a bit worried about the box we have (.3cf) being too small. if thats the case, i'm only out $45 and i'll build my own and go back to the trunk area or fork out the cash for a custom, like a few pix up. i'll let you know how it turns out after the recommended 24-48hr break in on the sub. (wtf???)
Old 12-06-2007, 06:16 PM   #9
Regular abUser
Iron_Lion_Scion's Avatar
Re: under seat sub
Different year model but same concept. I did mine about a year ago and have loved it ever since. I have a 12" shallow mount pioneer premier I've mounted under the passenger seat. Check out my thread and it might help w/ ideas although mine is a 1st gen so measurements will be different.
http://www.clubxb.com/forums/f23/122...n-lions-audio/
Old 12-06-2007, 07:04 PM   #10
Re: under seat sub
is a piece of art!!! from their recommendations, the box should be from .4-1.0cf with the best being .5cf i'm a bit worried about the box we have (.3cf) being too small. if thats the case, i'm only out $45 and i'll build my own and go back to the trunk area or fork out the cash for a custom, like a few pix up. i'll let you know how it turns out after the recommended 24-48hr break in on the sub. (wtf???)[/quote]
The ideal box size for the SQ10 is also .5cf but eD says that .3cf is okay. Obviously it's not ideal but a little poly-fill might help. I stuffed my box but can't say if it helped or not. I'm looking forward to hearing about your results.
Old 12-08-2007, 02:42 AM   #11
Matrixv01 is on a distinguished road
Re: under seat sub
Man that looks good.
Matrixv01 is offline   Reply With Quote
Old 12-16-2007, 07:38 PM   #12
Bon Jersey!!!!
Re: under seat sub
well fred, got everything installed and it sounds like garbage!!! not saying that all of them will, but the RF sub i have doesn't match with the cu ft of the box we have. so, i'll be building one that will go under the front seat and fill the rear floor on the pass side. my daughters car seat is there so it will still be a downfire and built so that she can step on it to get in and out. of course, that will be when it warms up a bit. so i have the polk in the rear taking up space again, but at least it sounds good!! LOL. i'll keep you updated in a few months when i get the new build done. thanks for the help and interest!!! much appreciated!!!!
Old 12-16-2007, 11:07 PM   #13
Lvbitwiz's Avatar
Re: under seat sub
Thanks, I'm not having much love with the suede though, I'm thinking of having it sprayed with line-x or just finishing it out and painting it
Old 12-17-2007, 12:12 PM   #14
Re: under seat sub
I'm really sorry to hear that. I guess the box is just too small for your RF sub. The empty box is only .3cf and the SQ10 takes up about .0275cf of space and I believe your RF driver is a bit larger still, making your final volume between .25 and .275cf. The only other thing I can think of is that the speaker connector plug was a loose fit and had to be sealed with caulk but I suspect you already took care of that.
I suspect that the new box will sound much better. I'm sure that my SQ10 would sound better in a larger box too but it seems to work pretty well in this little box.
Old 12-17-2007, 07:44 PM   #15
Bon Jersey!!!!
Re: under seat sub
everything, including the wire connector was caulked like a mofo!!! again, i do appreciate the interest. i'll keep you informed as soon as its done!
Old 12-20-2007, 11:55 PM   #16
Re: under seat sub
I was pretty sure that wasn't the problem but I'm still getting to know you and thought I'd mention it just in case.
I'm not a very seasoned audiophile so it's also possible that you're looking for a higher level of SQ than what satisfies me. All I can say definitively about my SQ10 under-seat box is that it sounds much better than my 10" Pioneer or Polk DB drivers did in a Q-Logic .66cf sealed box when fed the same 120Wrms. The Pioneer driver was spec'd for a .7-1cf box and the Polk was spec'd at .67cf, FWIW.
Old 12-21-2007, 01:19 PM   #17
Reppin SE
NVSBox's Avatar
NVSBox is on a distinguished road
Re: under seat sub
Can you send me the link I have been looking for a box for a single 10". Thanks.
NVSBox is offline   Reply With Quote
Old 12-23-2007, 09:11 AM   #18
Re: under seat sub
Old 09-26-2008, 10:21 PM   #19
Exposure101 is on a distinguished road
Re: under seat sub
i did about the same thing as Lvbitwiz except mine is a little bigger and is a 12" MTX sub. It was my first fiberglassing project and it turned out pretty good IMO. I def like Lvbitwiz's box too...it looks clean
Exposure101 is offline   Reply With Quote
Old 10-03-2008, 08:04 AM   #20
Re: under seat sub
Hey NVSBox, if the Pic on for your avatar is you, can I convince you to come to Mass and Marry me
my I.C.E. setup on my xB2
JL Stealth 12 Sub Box.
Custom sub/amp rack
the oem security system
dash kit for 08
Rear view camera
Page generated in 0.29584 seconds with 13 queries
