04-11-2009, 05:38 AM
#21 | | Registered User
| Re: my little sound system now, even traffic is pretty enjoyable....crank up the music and let the good times roll! |
04-13-2009, 05:28 PM
#22 | | Registered User
| Re: my little sound system Super clean install. I will post mine when I have my 10 posts. I build my subwoofer into the same side as yours. I am very happy with it there. |
04-14-2009, 12:07 AM
#23 | | Registered User
| Re: my little sound system |
04-14-2009, 11:41 PM
#24 | | Registered User
| Re: my little sound system OK, so apparently it takes 30 posts to add a link or an image.... No more than I am on here, it will likely be a year...
Grrrrr.. yeah tried it and get a message saying I need 30 posts... ok who to spammm.....
04-15-2009, 08:18 PM
#25 | | Registered User
| Re: my little sound system post your links like this
www , fhjasdfjk; . com |
04-15-2009, 08:53 PM
#26 | | Registered User
| Re: my little sound system http ; ://s177.photobucket.com/albums/w215/rudeman2k/?action=view¤t=100_0880 . .jpg
Good idea, there is no www(dot) in there. If you cant find it, Ill get em up soon either way. there is also another look at 0081 and 0082(dot jpg)
04-15-2009, 11:07 PM
#27 | | Registered User
| Re: my little sound system <a href="http://s177.photobucket.com/albums/w215/rudeman2k/?action=view¤t=100_0880.jpg" target="_blank"><img src="http://i177.photobucket.com/albums/w215/rudeman2k/100_0880.jpg" border="0" alt="Photobucket"></a>
wrong code
looks good man, nice and clean
04-17-2009, 01:54 PM
#28 | | Registered User
| Re: my little sound system You sir are the man. thanks for posting it for me and thanks for the compliments. |
04-17-2009, 01:57 PM
#29 | | Registered User
| Re: my little sound system looks good.....but i think you should take the carpet out and do something a little more high end looking like suede!....^^ |
04-17-2009, 02:05 PM
#30 | | Registered User
| Re: my little sound system How did you get the nav flush? Whats the wire hanging from the glove box?
Looks sick man those kick panels are fucking expensive. |
04-17-2009, 04:15 PM
#31 | | Registered User
| Re: my little sound system that little wire is the switch for the piaa lights i have for my foglights!...still need to fiberglass a panel for the ipod, piaa switch...led flashlight...all in the cup holder i rarely use! Quote:
Originally Posted by seppuku27 How did you get the nav flush? Whats the wire hanging from the glove box?i redrilled the metal bracket that was oem....and flattened out the two large holes on the side...and its a matter of alignment of the holes and you are done....all in less than 2 hours!
Looks sick man those kick panels are fucking expensive. | yes, expensive but worth every penny...it was alot of work to make them....2 solid days of fiberglassing, sanding, fiberglassing....cutting mdf.....cutting 40+ sticks to get the mdf in position to fiberglass and a new set of oem kick panels.....trust me it was worth it....
04-17-2009, 04:56 PM
#32 | | Registered User
| Re: my little sound system I'll have to pop mine back out and mess with it somemore when I buy my back up camera and PAC SWI.
It looks worth it. I bet it sounds awesome also.
We've got to get you some decent pictures up of your work. You should make a build thread. |
04-17-2009, 05:57 PM
#33 | | Registered User
| Re: my little sound system thanks, lets do it someday! |
04-24-2009, 08:12 AM
#34 | | Registered User
| Re: my little sound system Nice install, love the kicks!
Did you have to relocate the relays behind the kicks any? |
04-24-2009, 12:01 PM
#35 | | Registered User
| Re: my little sound system no need there is plenty of room back there |
04-26-2009, 11:44 PM
#36 | | Registered User
| Re: my little sound system working on some 8" subs under the seat...need more impact!...the JL 12s are way too loose.....I think i don't like the stealthbox anymore....time to change out the subs. Next inline are the Image Dynamic subs..... |
04-27-2009, 10:41 AM
#37 | | Registered User
| Re: my little sound system Very clean install. Is the box fiberglass? |
04-27-2009, 01:34 PM
#38 | | Registered User
| Re: my little sound system yes it is fiberglass....but doesn't sound as good as i would like it to. |
06-01-2009, 12:59 AM
#39 | | xB RS5 Bagged!!!!
| Re: my little sound system is that suede black or charcoal....looks like a good match |
06-01-2009, 01:48 AM
#40 | | Registered User
| Re: my little sound system black is the color but hard to tell from the pics |
