View Poll Results: orion hcca VS. re audio xxx
orion hcca 12 0 0%
re audio 12 1 100.00%
2 ohm 1 100.00%
4 ohm 0 0%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
Old 08-14-2009, 04:59 PM   #1
elusive_xb
elusive_xb's Avatar
Give me some info....
what is a better sub?
orion hcca 12?
or
re audio xxx 12?
and is 2 or 4 ohm better?
and y?
any body????
Old 08-17-2009, 03:15 PM   #2
nosotros213's Avatar
Re: Give me some info....
Impedance all depends on the amp you're getting. Most higher end amps now have the same wattage across any load from 1.5 to 4 ohms. Hard to tell which one is better based on specs and I've never heard these two subs so who knows.
Old 08-19-2009, 08:45 PM   #3
Slody4Futbol is on a distinguished road
^^ true
it all depends on the amp, how many subs, etc.. you may want to look into proper airspace for each sub.. how many you want to run.. and see if you have room for either sub..
Slody4Futbol is offline   Reply With Quote
Old 08-19-2009, 11:23 PM   #4
elusive_xb
elusive_xb's Avatar
ok.... so say i have a us amps md3d....
or what amp would work best?
im only going with 1 x 12" sub....
Old 08-20-2009, 03:42 PM   #5
ok so another post of mine disappeared..
a dual 2 ohm would be fine since your amp does 2000w @ 1 ohm.. you can wire your sub in parallel and get it down to 1 ohm and they are 2000w RMS so that will match up perfectly
Old 08-20-2009, 03:45 PM   #6
elusive_xb
elusive_xb's Avatar
ok.... well what sub would be better for the md3d amp? hcca or xxx?
Old 08-24-2009, 09:03 PM   #7
loud1500 is on a distinguished road
I would pick the RE, but are you open to other suggestions?
loud1500 is offline   Reply With Quote
Old 08-24-2009, 09:23 PM   #8
elusive_xb
elusive_xb's Avatar
yeah what do u think?
Old 08-24-2009, 10:45 PM   #9
I would look into FI car audio, Incriminator Audio, Ascendant Audio, Digital Designs...... It really just comes down to how much you want to spend, and how much room you are willing to give up for the enclosure.
Old 09-16-2009, 06:05 PM   #10
elusive_xb
elusive_xb's Avatar
as long as it fits in the cargo space and dosent cover my rear window on my xb2 its fine
money???? im good at saving cash
i heard a fully loaded fi btl is better than a re audio xxx
is that true?
Old 09-16-2009, 09:34 PM   #11
What model xxx are you referring to? Before US amps bought re or before?
I would take the btl over the xxx, but it's also install dependent. FI's customer service is also another reason I would run them, along with it being a great product.
Old 09-17-2009, 02:54 PM   #12
elusive_xb
elusive_xb's Avatar
ok cool so say i get a fully loaded 12" or 15" fi btl.... whats the best amp to run?
Old 09-17-2009, 09:20 PM   #13
I would say to look for one around 2500 "real" watts, I don't know if you're trying to stay with a certain brand or not.
You also have to remember that you're probably going to need to upgrade some of your electrical to withstand the current draw.
Some options would be Crunch GP3000d, RF T2000, RF T2500, Sundown Audio 2000d, there's more but I can't think of them off the top of my head.
Old 09-24-2009, 12:27 AM   #14
the BTL requires a ported box, and if you do it right, the 15 will need like 7-7.5 cubes gross. pretty sure that wont fit under the window. a 12 would be fine as long as you do the necessary electrical
my I.C.E. setup on my xB2
Custom sub/amp rack
the oem security system
dash kit for 08
JL Stealth 12 Sub Box.
Rear view camera
Page generated in 0.20852 seconds with 14 queries
