Old 09-27-2007, 02:29 PM   #1
nonstopboost is on a distinguished road
AfterMarket Remote start!!
Has anyone installed and aftermarket remote start???
I put one in the new 08...but it never worked!! so just curious if anyone has installed one!!
thanx
nonstopboost is offline   Reply With Quote
Old 09-27-2007, 06:48 PM   #2
Regular abUser
Iron_Lion_Scion's Avatar
Re: AfterMarket Remote start!!
I installed my viper, but it was in my 06 so its probably totally different wires.
Old 09-28-2007, 02:04 PM   #3
Unfortunately they are different wires.....i have found most of the wires by hunting and searching but it still wont work!! Im thinking that there might be a second starter wire!!
Old 09-28-2007, 06:16 PM   #4
ididntdoit5150 is on a distinguished road
i have had one installed on my 08 but i didnt do it so i cant tell you what went wrong, but i can tell you that it will work
ididntdoit5150 is offline   Reply With Quote
Old 10-03-2007, 08:50 AM   #5
Hella Bastos
viper is pretty popular.
Old 10-03-2007, 08:49 PM   #6
x2 da b's Avatar
x2 da b is on a distinguished road
Send a message via AIM to x2 da b
you know there is a chip in the key now like the tc. you need a 556uw and loose a key. nissans are really known for 2nd starter wires. you should be able to find wire colors for teh new xb, i will look around.
well if the wires are like the tc the second starter wire is green, you will need a relay.
x2 da b is offline   Reply With Quote
Old 10-04-2007, 02:17 PM   #7
There is not a chip in the key! Therefore not needing a bypass...and it has quite different wiring than the tC. I found a sencond wire that acts like a second starter. It was black and but 18g. I used a relay to wire it with no success!! Dealing with the starter manufacture they have decided it to be faulty so i have sent it back to them for some exchanges!! $hitty thing about the wiring in the new xb is probably 75% of all wires are white!!
Old 10-06-2007, 01:13 AM   #8
New Xb owner
mykvr6 is on a distinguished road
no chip, no bypass needed. There is a second starter and you may have to hit the keysense wire as well for it to crank.
mykvr6 is offline   Reply With Quote
Old 10-11-2007, 10:22 AM   #9
Have you installed one yourself?? What color is the keysense wire and how can i test it?? Also how can i connect that into the system??
Old 10-11-2007, 10:26 PM   #10
eight08customs's Avatar
eight08customs is on a distinguished road
i have a viper and there is no chip in the key..
Mines is installed in a Manual 5spd.. I have the new remolte start kit in which you have to set the hand brakes than arm the remolte start before you take out the key.. when you take o ut the key the car stays running untill you close the door and the car shuts off. than you arm the alarm. this makes sure you didnt leave the car in gear..
My sponsor did my install so i dont know what they did.. to what wires.
eight08customs is offline   Reply With Quote
Old 09-15-2009, 01:06 PM   #11
manguman's Avatar
manguman is on a distinguished road
I had a checkmate KD 500 installed on mines,, works great,
manguman is offline   Reply With Quote
my I.C.E. setup on my xB2
Custom sub/amp rack
the oem security system
dash kit for 08
JL Stealth 12 Sub Box.
Rear view camera
Page generated in 0.19138 seconds with 13 queries
