Old 11-06-2008, 12:28 PM   #1
its what you do with it.
WhiteNoise's Avatar
V Led 194s
Has anyone tried these in their license plate?
HID WHITE 6 LED M-SMT FLANK BULBS 194 168 158 2825 | V-LEDS.COM
Just not sure if they will fit the housing.
Old 11-18-2008, 03:22 PM   #2
hotboxd's Avatar
hotboxd is on a distinguished road
Re: V Led 194s
no. those would not work for your license plate lights!
hotboxd is offline   Reply With Quote
Old 11-18-2008, 03:37 PM   #3
WhiteNoise's Avatar
Re: V Led 194s
Thanks for your input hotboxd. I actually ended up with the 194 superstars with metal heat sinks from autolumination. They are plenty bright and have yet to fail.
Old 01-06-2009, 09:31 AM   #4
sjboy9999 is on a distinguished road
Re: V Led 194s
194=168 they are all the same size
sjboy9999 is offline   Reply With Quote
Old 01-30-2009, 01:12 PM   #5
Scion Apocalypse
_Keith_'s Avatar
_Keith_ is on a distinguished road
Send a message via AIM to _Keith_
Re: V Led 194s
Glad it worked out for you Chris!
What up!
_Keith_ is offline   Reply With Quote
Old 01-30-2009, 02:33 PM   #6
WhiteNoise's Avatar
Re: V Led 194s
What up!
Yeah thanks..to Kevin. I wouldn't mind an even brighter set but the housing is small. I gave some 194 smt towers from Autolumination to a friend for his FJ and they are very bright.
Old 01-30-2009, 05:45 PM   #7
seppuku27's Avatar
Re: V Led 194s
194 168 W5W 2825 Map Led Parking Signal Marker Bulbs
Is that the one you got for the license plate blubs? Is it plug and play?
Old 01-30-2009, 11:22 PM   #8
WhiteNoise's Avatar
Re: V Led 194s
Since AUTOLUMINATION's website is stupid I'm not sure which one you are linking to. I have a set that is the 5th one down with the metal heat sinks and they have been great. It is just plug and play once you remove the inside hatch panel. It's held on by plastic clips. PM me if you need any more info.
Old 01-31-2009, 10:16 AM   #9
seppuku27's Avatar
Re: V Led 194s
Okay I think I see them. Did you replace the map lights with leds too? What did you use for them? I'm such a noob when it comes to leds....
Old 01-31-2009, 11:18 AM   #10
WhiteNoise's Avatar
Re: V Led 194s
I just ordered and Oznuim dome light 5x1.5 in blue.
http://www.oznium.com/thin-led-dome light
I'm pretty sure it will fit. They are beyond bright. I have not replaced the map lights yet. but I imagine the 1x1.5 dome light would fit in there. They are all just plug and play.
Old 02-04-2009, 02:26 PM   #11
seppuku27's Avatar
Re: V Led 194s
I am going to order those sometime soon and see how they work. I have already ordered the license plate ones.
Old 02-05-2009, 07:45 PM   #12
ocotillo's Avatar
Re: V Led 194s
I just installed the Oznium ultra thin led dome- 1.5" x 5". Other than the wires being a little too long and having a little issue with hiding everything, I like them. Super bright.
ocotillo is offline   Reply With Quote
Old 02-05-2009, 07:51 PM   #13
seppuku27's Avatar
Re: V Led 194s
Was that for the map light?
Old 02-05-2009, 07:53 PM   #14
WhiteNoise's Avatar
Re: V Led 194s
That size will definitely not fit in the map lights. (I consider the map lights to be the front two push lights closer to the rear view mirror.) It was for the dome light.
You could always just cut down the wires and solder them, or probably even just tape them. Some people have even soldered the wires directly to the posts.
Old 02-05-2009, 08:14 PM   #15
ocotillo's Avatar
Re: V Led 194s
For the two map lights, I got cool white leds from Garage 1217. These are also very bright.
Old 02-05-2009, 08:29 PM   #16
WhiteNoise's Avatar
Re: V Led 194s
Thanks for the input.
Old 02-08-2009, 06:01 PM   #17
wattspd is on a distinguished road
Re: V Led 194s
I did it for my license plate lights. looks tight like a lexus....
wattspd is offline   Reply With Quote
Old 02-08-2009, 06:32 PM   #18
WhiteNoise's Avatar
Re: V Led 194s
Finally got my blue Oznium dome 5x1.5 it was on backorder but worth the wait. It is super bright.
fog lights
Sad Headlights
Lighting additions so far..
I am soooo Blue
Sony 6x9's + c-pillars = :)
Page generated in 0.30413 seconds with 13 queries
