Old 08-28-2007, 02:01 PM   #1
Poor man's HID low beams
Just mod some H9s to replace the stock H11s.
H11 = 55W/1200 Lumens
H9 = 65W/2100 Lumens
http://www.rx8club.com/showthread.php?t=119161
http://www.danielsternlighting.com/p.../products.html
I just ordered a pair of Sylvania H9s from Amazon for $20 + $5 shipping. I'll post my results later.
Old 08-29-2007, 05:07 AM   #2
yellow_sub's Avatar
Re: Poor man's HID low beams
hmmm sounds interesting
yellow_sub is online now   Reply With Quote
Old 08-29-2007, 11:21 AM   #3
I'm sure that H9s will produce much more light and my only concern is that they may be too bright or possibly burn too hot. Both the H9 and H11 use the same axial element placement so the beam pattern should be the same. I'm just hoping that they won't be too bright for oncoming traffic or melt the diffusor lens.
Old 09-05-2007, 03:40 AM   #4
Installed the H9 bulbs tonight in about 15 minutes and what a difference! Same cut-off but much more light. What can I say? $25 to go from 1200 lumens to 2100 lumens vs $100-300 to go from 1200 to 3200 lumens with 4300K HIDs.
Old 09-05-2007, 03:44 AM   #5
HELA FASS DOOO
pics of these fer sure.
Old 09-05-2007, 04:04 AM   #6
Unfortunately I don't have any before pics and from what I've seen posted in many HID threads, you can't tell shit about RL headlight performance from pics anyway...
Old 09-27-2007, 05:13 PM   #7
its what you do with it.
WhiteNoise's Avatar
Fred how about a quick update on how the h9 light bulbs have performed? Thanks.
Old 10-05-2007, 10:41 PM   #8
The H9s are great. No problems at all, just much more illumination. They've been in for about 3 weeks now and so far I've only been flashed once and that was probably because my lights are aimed higher due to the TRD springs.
Old 10-06-2007, 01:28 AM   #9
WhiteNoise's Avatar
Good deal, i was thinking of replacing my fogs which i believe are h11s. think that would be ok?
Old 10-07-2007, 08:43 AM   #10
I've heard of others replacing H11 fog bulbs with H9s and they were happy with the results. I can think of only 2 potential problems:
1) H9s will burn a little hotter
2) H9s draw 10W more (5.4A vs 4.6A)
Old 10-22-2007, 03:00 AM   #11
jrw1981's Avatar
jrw1981 is on a distinguished road
i swapped out the h11's for h9's as well on my xB2. definately an improvement. they're far from HID, but i'll take what i can get. the springs i put on there lowered the back .7 inches more than the front, so i also had to aim the lowbeams a bit lower. this was much easier than i thought it would be. there is an easily accessible bolt on the back of the light that controls the angle of the lens. toyota really did a great job making everything on this car easily accessible.
jrw1981 is offline   Reply With Quote
Old 11-04-2007, 07:39 PM   #12
slvrbullet8069's Avatar
slvrbullet8069 is on a distinguished road
Interesting to know, I usually just buy the Nokya Hyper White bulbs to get the HID effect (I have them in now).....But now I'm thinkin I might have to try this on my xb2 to see which is better. Thanks for the info....
slvrbullet8069 is offline   Reply With Quote
Old 11-10-2007, 10:27 PM   #13
SnekerBox is on a distinguished road
Where can I get the H9 bulbs, and do they just plug in. Also what and where is the low beam adj screw?
SnekerBox is offline   Reply With Quote
Old 11-18-2007, 05:08 AM   #14
Maddman is on a distinguished road
Fred, did you have to use the same mod for the low beams as the link u posted for the fogs?
Maddman is offline   Reply With Quote
Old 11-18-2007, 10:31 AM   #15
H9s are a little scarce but I got my Sylvania (Osram) H9s from Amazon for ~$25. The silver 8mm HL adjustment screw is located near the top of each HL assy and accessible from the engine compartment. Use the notches as a guide. After installing TRD springs I adjusted mine down 6 notches which was just like stock. I'm now running them only 3 notches down because the stock setting was too low, IMO.
H9s require the same mods for any H11 application.
Old 11-18-2007, 04:09 PM   #16
I found them at Auto Zone this morning 14 bucks ea, did the mod ,,well see tonight :-)
Old 12-22-2007, 10:51 AM   #17
al74dart is on a distinguished road
OK, I have located the 8mm silver bolt to adjust the headlights hight but which way do I turn the bolt to raise the beam? I am running all stock but my beams seem to be low as I overdrive my lights at night.
Al
al74dart is offline   Reply With Quote
Old 12-23-2007, 09:07 AM   #18
Al
I forgot which way to turn the bolt but just park in front of a wall at night and it should be obvious. Before you start adjusting, it's a good idea to mark the original position with something. I used a permanent marker. Keep in mind that what looks like a little at 10' is a lot more at 100'. Just a few notches makes a big difference.
Old 12-24-2007, 01:50 PM   #19
Any sign of a melt down on the defuser?
Old 12-24-2007, 06:11 PM   #20
OK, I just checked the direction and turning the screw Clockwise moves the beam up. I moved mine 6 marks as a starting point. I may have to back it down some later. I marked the adjustment screw so I can always go back to factory setting and wrote down which way I turned the screw and the number of marks. This way I can keep track of what works best for me.
Al
fog lights
Sad Headlights
Lighting additions so far..
I am soooo Blue
Sony 6x9's + c-pillars = :)
Page generated in 0.27079 seconds with 13 queries
