06-11-2007, 10:32 PM
| Light bulbs for xB2 For quick reference, these are the bulbs as listed on page 254 of the owner's manual: Code: Headlight (lo) - 9704/H11 (55W)
Headlight (hi) - 9005/HB3 (60W)
Front Turn/Park - 1157NA (27/8W) - Bayonet
Front Sidemarker - Wedge (5W)
Side Turn Signal - LEDs (0.4W)
Rear Turn Signal - 7440 (21W)
Stop/Tail - 7443 (21/5W)
Rear Side Marker - 7443 (21/5W)
Backup - 7440 (21W)
Third Brakelight - LEDs (3.6W)
License Plate - Wedge (5W)
Interior - Double End* (8W) - Festoon
Personal - Wedge (8W)
Trunk - Double End* (5W) - Festoon * I believe Double End is what is called a Festoon bulb which usually are referred to by length in mm. When I find out more, I'll update this post. |
06-15-2007, 04:07 PM
| Re: Light bulbs for xB2 It looks like Scion has installed some really bright headlights on the new xB's. I don't think we will need to upgrade them at all. I do think I will be adding some Yellow fog lights to my car when I get it. I think I may even look into using them as daytime running lights. I read somewhere that Yellow lights used during the day help oncoming cars see you better then regular headlights.
Here is link to some good info on lights. http://www.danielsternlighting.com/t...ulb_types.html
The info on this site can be a little difficult to locate but the info is very good with some "how to do's" that may help some.
Al |
06-17-2007, 08:16 PM
| Re: Light bulbs for xB2 if i where u i would get a HID kit for the low beams... it will make those headlights 3 times brighter. |
06-18-2007, 12:28 AM
| Re: Light bulbs for xB2 Quote:
Originally Posted by al74dart I read somewhere that Yellow lights used during the day help oncoming cars see you better then regular headlights.
Al | This is especially true if you have a white or silver car. Statistically drivers find it harder to see silver and white cars and make them more of a target to be hit. Drive with any form of lights on in the day will help prevent this from happening. Now I'm gonna go knock on wood that my new baby doesn't get hit!!! |
06-18-2007, 11:53 AM
Originally Posted by polarproject if i where u i would get a HID kit for the low beams... it will make those headlights 3 times brighter. | Lets see, 3 times brighter would make them two times brighter than the hi beams! The current low beams are about 1200 Lumens and the hi beams are about 1700 Lumens. The current low beams are already brighter then most cars on the road hi beams. I don't think that would be a good idea. The idea is to be able to see objects and vehicles ahead of you and for others to see you, not blind others. There are already a lot of complaints about some cars having lights that are too bright causing problems for oncoming traffic. Blinding the other guy especially if he is a cop may not be in your best interest.
I think just making sure your lights are properly adjusted especially after making changes to the vehicle as far as height goes would go a long way to improving visibility. With many of the drop kits not lowering the car evenly and some folks putting different size tires on the front and rear this can really screw up the headlight aiming.
Al |
06-22-2007, 06:37 PM
| Re: Light bulbs for xB2 Thanks man
Where'd you get that?
06-22-2007, 11:58 PM
| Re: Light bulbs for xB2 Since we are talking about HID's, does anybody know where I can buy some for my new '08 xB. I have been looking like crazy and still had no luck... it is very frustrating.  |
06-23-2007, 12:22 AM
| Re: Light bulbs for xB2 If you only want to upgrade your hi beams why not just change the 9005's to the 9011/HIR1's. These bulbs are almost a direct plug in, only a little filing on the bulb from what I understand. The stock bulbs are about 1700 Lumens and the 9011's are about 2350 Lumens. The price of the new bulbs are about $30 each. Make sure you get the Toshiba bulbs ONLY. The others may not be as good. Here are two links about the bulbs, do a search to find out more if you want to. http://www.danielsternlighting.com/t...ulb_types.html http://www.rallylights.com/hella/9005.asp
I would think this would be a lot cheaper then HID's and these are legal, used on the Corvette, Dodge Viper, and other cars.
Al |
06-23-2007, 12:12 PM
| Re: Light bulbs for xB2 AL:
I actually want to upgrade my low beam projectors. Do you know of any websites. |
06-23-2007, 02:52 PM
Originally Posted by efuentes AL:
I actually want to upgrade my low beam projectors. Do you know of any websites. | I don't know of anything for the low beams. The low beams are already quiet bright compared to most other cars on the road, even brighter then many hi beams. You might try doing a google search to see if there are any bulbs that you can just plug in the low beams. My guess is because the low beams are already quite bright you will have to go with HID's if you need more light. I seem to remember reading here or on the other Scion group's page someone having a business that sells the HID's. You could also check Ebay to see what you can find. Do a search here and on scionlife to see what you can find under HID's.
Al |
06-23-2007, 06:52 PM
| Re: Light bulbs for xB2 Thanks alot. I will check on that and see. |
07-01-2007, 02:43 PM
Originally Posted by efuentes Since we are talking about HID's, does anybody know where I can buy some for my new '08 xB. I have been looking like crazy and still had no luck... it is very frustrating.  | if you search for 'h11 hid' on ebay, you'll get many results http://search.ebay.com/search/search...hid&category0= |
07-02-2007, 12:23 AM
| Re: Light bulbs for xB2 I got my 8000k HIDs from Clifford at Mobile HID.
Not sure if this is OK to post here, but if you look him up over at ScionLife you can get the $170 price.
Malibu Rapper posted some nice pics and links to videos of the 6000k install on his 2008 xB. http://www.scionlife.com/forums/view...light=#2642189
I love mine.
One addition to the bulb list, the Scion Fog light bulbs are H11's.
07-21-2007, 12:47 PM
#14 | | Registered User
| Re: Light bulbs for xB2 According to my measurements, the rear cargo festoon is 28mm and the dome light is 31mm. Hope this helps... |
08-29-2007, 10:11 PM
#15 | | Registered User
Originally Posted by roXor_boXor
One addition to the bulb list, the Scion Fog light bulbs are H11's. | I always thought they're 9006...lucky that I saw this before I buy bulbs for my fog light!  |
01-11-2008, 09:18 AM
#16 | | Registered User
| Re: Light bulbs for xB2 Has anyone change the light bulbs on the fog lights to Hyer White lights or has installed HID's |
04-24-2008, 12:11 PM
#17 | | its what you do with it.
| Re: Light bulbs for xB2 |
04-25-2008, 09:33 AM
#18 | | Registered User
| Re: Light bulbs for xB2 Our lights are bright but still have that yellowish tint. Any other bulbs that would give a white tint without going with HID?
_____________ |
04-30-2008, 12:00 AM
#19 | | Registered User
| Re: Light bulbs for xB2 anyone know off hand the bulb size for the fog lights? i just ordered mine and i want to order HIDs asap |
11-02-2009, 08:54 PM
#20 | | Registered User
| Re: Light bulbs for xB2 autozone sells some silver star h11s that aren't hids but are white not yellow |
