Old 08-10-2009, 02:45 AM   #41
L808xb is on a distinguished road
Re: I am soooo Blue
Looks great!
L808xb is offline   Reply With Quote
Old 08-10-2009, 12:04 PM   #42
myleshouston is on a distinguished road
Re: I am soooo Blue
that looks great i am gonna get the red kit next paycheck.
myleshouston is offline   Reply With Quote
Old 09-22-2009, 10:39 AM   #43
ledbootz's Avatar
ledbootz is on a distinguished road
How to add LED interior lights
So to get power to the lights, is the approach decribed below of tapping into the appropriate fuse the approach to use?
Single Color LED Expandable Interior Installation and Operation
Depending on your vehicle and knowledge of automotive wiring, choose the appropriate wiring method.
Connecting to a Fuse Panel
If you choose to wire the Interior Kit to an automatically switched ignition source in your vehicle, you must first locate the fuse for such a source. You may need your owner’s manual or the help of a mechanic.
Choose a fused source with at least a 10 amp fuse for the kit, anything less may blow the fuse with the kit installed and running.
Next, run the positive power wire (red) directly to a fuse slot in your vehicle’s fuse panel and insert it on one side of the fuse slot. * Make sure not to bridge the fuse with the wire or it will render the fuse useless in the event of a short circuit in your vehicle. You may also purchase a replacement fuse with accessory wire attached to one side, at an automotive parts store.
Finally the ground wire (black) may be connected to any ground source or any bear metal on the vehicle.
ledbootz is offline   Reply With Quote
Old 10-30-2009, 11:41 PM   #44
2009ledxb's Avatar
2009ledxb is on a distinguished road
Re: I am soooo Blue
nice job i did this to mine to but yours look way brighter than mine ;(
2009ledxb is offline   Reply With Quote
fog lights
Sad Headlights
Lighting additions so far..
I am soooo Blue
Poor man's HID low beams
Sony 6x9's + c-pillars = :)
Page generated in 0.14246 seconds with 12 queries
