05-16-2008, 01:17 AM
#41 | | Registered User
| Re: Have you changed your AC Control Lights? Quote:
Originally Posted by Aaron93 Nice!!!!!!!!!!!!
Where did you get your overlays? | Made that one myself actually |
05-16-2008, 09:31 AM
#42 | | Registered User
Originally Posted by Aaron93 Thanks!! I get nervous when it comes to Air bags!! So all you have to do is disconnect the neg term on the battery? | That's it. Airbags need electricity to be set off, if you don't have any then no boom. |
05-17-2008, 12:27 PM
#43 | | Registered User
| Re: Have you changed your AC Control Lights? How many plcc2 Leds do you need for the guages. I assume they are soder on not just replacable.
thanks
-nick |
05-17-2008, 04:49 PM
#44 | | its what you do with it.
Originally Posted by GregS That's it. Airbags need electricity to be set off, if you don't have any then no boom. | Don't forget to wait at least five minuets as they retain power as a back up for a short period. |
05-17-2008, 09:44 PM
#45 | | Registered User
| Re: Have you changed your AC Control Lights? |
05-20-2008, 07:21 AM
#46 | | Registered User
Originally Posted by GregS Actually it's pretty easy to get to, I took it apart yesterday to look at it.
All you need to do is undo the two Torx bolts on either side of the back of the steering wheel and the airbag/horn assembly will come right off. From there you can see the one phillips screw holding the radio controls in. Once the screw is removed pull hard as the locater pin is very tight. Unplug the harness from the column and the horn and then remove the two phillips screws ont he back of the switch assembly and you can pull the circuit board right out and re-solder the LED. Install is the reverse of removal of course.
Obviously disconnect the negative terminal of the battery before starting this just to make sure you don't set off the airbag.
When I get around to it I'll post a How-to in the DIY section. Maybe tomorrow morning. | Hey GregS where's the DIY? I am sure you are busy just trying to give you a hard time! I just know Dummies like me need pics! and Thanks for All your help!!! |
05-20-2008, 05:33 PM
#47 | | Registered User
Originally Posted by Aaron93 Hey GregS where's the DIY? I am sure you are busy just trying to give you a hard time! I just know Dummies like me need pics! and Thanks for All your help!!! |
Yeah, yeah, yeah.
Actually I'll try to get it done today. This is the begining of my weekend so I now have time to work on it.
OK here's the link to the DIY for the steering wheel radio control, http://www.clubxb.com/forums/f19/207...wheel-control/
And just for good measure here is the one for the window switch, http://www.clubxb.com/forums/f19/207...itch-lighting/
Enjoy!
05-20-2008, 09:08 PM
#48 | | Registered User
| Re: Have you changed your AC Control Lights? Thanks!! NICE DIY!!! Now trying to find the one for the AC and the dash I saw them some where. GOing to the DIY section. I know there are some pics here of the disassembly but nothing on the board. Thanks!!! Greg. |
06-11-2008, 01:31 AM
#49 | | Registered User
| Re: Have you changed your AC Control Lights? For the gauges, how many PLCC-2 led's do I need? I know the A/C control ones needed 3...but what about the one for the gauges? Thanks! |
06-11-2008, 01:20 PM
#50 | | Registered User
| Re: Have you changed your AC Control Lights? 15 if you are just doing the dials, digital speedometer and display. If you want to do the indicator lights then you'll need one more for each. |
06-21-2008, 08:25 AM
#51 | | Registered User
| Re: Have you changed your AC Control Lights? I Hope They Dont Cost A Lot |
07-08-2008, 04:18 PM
#52 | | The Punisher
07-08-2008, 04:46 PM
#53 | | Gabriel
07-08-2008, 08:02 PM
#54 | | Registered User
| Re: Have you changed your AC Control Lights? And you can replace all???
The tach too? |
07-09-2008, 12:14 AM
#55 | | Registered User
Originally Posted by jrcpr And you can replace all???
The tach too? | Yes you can. This is from Scionlife.com: ScionLife View topic - DIY: LED swap Tutorial (No 56k!!)
I changed mine out...this was an amazing tutorial. I also changed out my 'Mode' button LED in the Steering wheel:  |
07-12-2008, 10:02 PM
#56 | | mnkysrbtr
| Re: Have you changed your AC Control Lights? sick! I can't wait to change out those ugly orange lights. |
07-22-2008, 03:18 PM
#57 | | Registered User
| Re: Have you changed your AC Control Lights? yea is it twist out the old and twist in the new?? |
07-22-2008, 05:21 PM
#58 | | its what you do with it.
Originally Posted by tru21self yea is it twist out the old and twist in the new?? | Well The Hvac controls are a twist in led, but you do have to dissemble the dash area. Also remember that the leds have a polarity so if you twist one in and it doesn't light try it the other way. DO not forget to test them before you put everything back together. The rest require soldering.
Reason: der
09-27-2008, 12:38 AM
#59 | | Registered User
Originally Posted by Aaron93 Thanks!! I get nervous when it comes to Air bags!! So all you have to do is disconnect the neg term on the battery? | I think anyone that has been hit with an airbag gets nervous around them hahahaha....I do to sir I do to....don't be ashamed of it either!!!! THEY HURT! |
09-27-2008, 01:28 AM
#60 | | its what you do with it.
| Re: Have you changed your AC Control Lights? I should note I had one of my ac lights burn out. Just ordered a new set of ones that are supposed to be 30% brighter . We shall see tomorrow. |
