09-23-2007, 05:03 PM
Join Date: Sep 2007 Location: Glendora/Riverside/Garden Grove, CA
| TRD Shift Knob..HELP please!? Hey Everyone!
I had a question regarding the TRD shift knob. I have a manual 2008 scion xb, and I ordered the TRD leather wrapped shift knob. My question is that when I removed the stock rubber black knob, there is a white plastic part that holds the boot to the shift lever.
Normally I wouldn't mind it, but when I screw in my new TRD shift knob, the white plastic part still shows. It kinda bugs me, and and I wondering what can be done about this...if any...
Please help?
Mike |
09-23-2007, 09:23 PM
#2 | | Undercover Moderator
| Re: TRD Shift Knob..HELP please!? Bump!
Anyone with a manual '08?? |
09-23-2007, 09:58 PM
#3 | | Haole Grandpa Moderator
| Re: TRD Shift Knob..HELP please!? If it works like the first gen, just twist it up farther on the stick. |
09-23-2007, 10:38 PM
| Re: TRD Shift Knob..HELP please!? Hey mikeytomas, I had the same problem when I installed my shift knob. You can take off the shifter panel and remove the boot. Then pull off the white plastic piece and paint it. It's on there pretty tight so you're gonna have to tug on it hard, but it'll come off. Heres a pic of mine. Make sure you put you hand on top of the knob while tugging so you don't mess up the shifter. |
09-24-2007, 03:51 PM
| Re: TRD Shift Knob..HELP please!? hey that looks great how did you paint the silver dash |
09-24-2007, 05:04 PM
| Re: TRD Shift Knob..HELP please!? yeah i got my xb2 from scion of cybertron mines looks a little diffrent
09-24-2007, 09:48 PM
| Re: TRD Shift Knob..HELP please!? Quote:
Originally Posted by JACKNTHEBOX hey that looks great how did you paint the silver dash | Hey jacknthebox...I basically took off the panels, lightly sand it with ultrafine sandpaper and painted it with 3 light coats of Duplicolor paint from Kragen's. Then 3 light coats of top coat was applied and buffed to a desired shine. |
09-25-2007, 01:10 AM
| Re: TRD Shift Knob..HELP please!? ninja, do you have a step-by-step on how to remove the panels? I really don't want to f*** up anything, if you know what i mean... |
09-25-2007, 02:43 AM
Originally Posted by mikeytomas ninja, do you have a step-by-step on how to remove the panels? I really don't want to f*** up anything, if you know what i mean... | which panels are you talking about? some are easier than others.... and some would require pics....but here is a DIY if you wanna take apart your dash from Jason, aka scvscions http://www.clubxb.com/forums/f70/124...dash-08-style/ |
09-29-2007, 11:14 AM
#10 | | The Mad Cow
| Re: TRD Shift Knob..HELP please!? OBX Shift knob from the tC with the little twist off piece on it from a manuel cover's everything. That's what I'm running.  |
10-11-2008, 12:39 PM
| Re: TRD Shift Knob..HELP please!? This is what I did to mine.
Just by looking at the pics you should be able to figure out how I did it.
The first pic is an old silk shirt where I cut the fabric from. |
10-15-2008, 07:25 PM
Please help?
Mike | This is the second time I've responded to this question, and it's probably the last. I just allowed the boot to cover the white plastic. To each their own, of course, but it works for me  ! |
01-29-2010, 01:07 PM
| Re: TRD Shift Knob..HELP please!? where can i find a pink manual shift knob for my 2008 |
