Old 07-11-2009, 03:48 PM   #1
MasterVader
StykShift's Avatar
removing and painting pillars?
Is there a DIY on removing and painting the interior pillars??? I saw the one on the 1st gen, but i got the XB2. Anyone?
Old 07-22-2009, 04:06 PM   #2
sihawker's Avatar
sihawker is on a distinguished road
Thumbs up Re: removing and painting pillars?
How about painting interior parts? I saw one a few days ago and now I can't find it. Help!
sihawker is offline   Reply With Quote
Old 07-23-2009, 10:08 PM   #3
MasterVader
StykShift's Avatar
i could help you with some interior pieces. I did it all.
I post a updated pic soon. I painted more than whats shown. I even took the oem radio apart and painted that, LOL!!!!!
Old 07-28-2009, 03:37 AM   #4
scvscions's Avatar
the front pillars are hard cause you have to pop them about 1in out then get a screwdriver back into that black plastic piece and pop that out. The B pillars, just unbolt the shoulder harness, pop the top out and lift up. You will have to loosen the bottom section though. The C pillars, unbolt the seat belt at the floor so you can feed it thru the plastic. Pop the top and keep it going toward you till it comes loose a the bottom. We have a video of me doing a headliner but it's with the editing guy right now.
Old 07-28-2009, 09:42 PM   #5
MasterVader
StykShift's Avatar
oh! i need to see that vid asap!!!! thanks! send me a link when its complete!!!
Old 08-18-2009, 06:22 PM   #6
dajack761 is on a distinguished road
I want to paint my shifter trim panel and climate control trim panel. Did you sand the panels before painting them. Also what kind of paint did you use?
dajack761 is offline   Reply With Quote
Old 08-19-2009, 01:56 PM   #7
Slody4Futbol is on a distinguished road
for some reason my post disappeared.. but to get the a pillars off.. pop it out on the top and middle.. pull back the weatherstripping.. and use a pair of needlenose pliers to rotate the top piece 45 degrees holding the top of the panel in.. then the top will slide out easily and then you just lift up to release the bottom
have you painted the steering wheel trim since the pic was taken or do you want to know how to remove that as well?
Slody4Futbol is offline   Reply With Quote
Old 08-22-2009, 02:25 AM   #8
Dspeedy69 is on a distinguished road
ok so we dont have to worry about the air bags right, i mean on the pillars it shows the airbag word, but they are not located on the pillars right?
Dspeedy69 is offline   Reply With Quote
Old 08-22-2009, 05:06 AM   #9
they're behind the pillars.. you can remove the pillars.. the reason the top clip is made the way it is, is because when/if the air bags deploy, the a pillar doesn't fly off and hit someone in the head.. it will stay attached
Old 08-23-2009, 12:39 AM   #10
so the airbags are attach to the pillars? when taking off the pillars, is there any chance of the airbags deploying?
Old 08-23-2009, 12:48 AM   #11
no they are behind the pillars.. not attached to the plastic panels.. when you remove the plastic panel you REALLY remove it.. it's not connected to the air bags
and not technically.. if you do it properly then no.. if you short the wires or something then yeah it could.. but if you do the process which i posted above then they will not deploy
Old 08-23-2009, 07:47 PM   #12
thanks man, i was always wondering about that, but now its all clear. Thanks Slody4Futbol.
Old 08-25-2009, 07:25 PM   #13
Mark Mckee
MarkMckee's Avatar
MarkMckee is on a distinguished road
Man just think of it this way. Absolutely make sure the paint does not oversize the pillar thus interfering with the way the airbag deploys. Yes paint can crack but if it would send the bag just a little in any direction you can get hurt badly. Same as your seats are equipped with side curtain airbags. The bag deploys in milliseconds so any interference might cause a problem. This is why i did not paint the center of my steering wheel nor will i mess with the door pillars. Just my 2 cents. There have been people with major seperated shoulders that did their own seat covers that did not include a rip seam for the airbag to deploy.
MarkMckee is offline   Reply With Quote
Old 08-26-2009, 10:01 PM   #14
Phobic is on a distinguished road
Send a message via AIM to Phobic
I want to do all my interior pieces that are currently the stock silver in black so bad. that red looks insane!
Phobic is offline   Reply With Quote
Old 08-27-2009, 10:14 AM   #15
MasterVader
StykShift's Avatar
Early this week, I played with the pillars. I got the C pillars out with a LOT of force, but cant get the seat belt off. Any tips? And how exactly do you pull the A pillars out? My week vacation from work is coming. I want to do this project, wrapping the headliner, painting the pillars, and custom seat covers. I already started on the seat covers and pillar removal, but need additional help on pillar removal.
Old 09-10-2009, 10:52 PM   #16
rulerofall
rulerofall's Avatar
rulerofall is on a distinguished road
wow!!! thats alot of painting
i have done alot in black...not done yet though...still some more peices that i want done...
rulerofall is offline   Reply With Quote
Old 09-25-2009, 06:01 PM   #17
i posted how a few posts up.. remove weather stripping.. pull out on top and middle.. get a pair of needlenose pliers and reach in and rotate the top clip 90 degrees.. you'll see what i'm talking about.. it's the piece that won't pop out when you pull the panel out, it only comes out so far and stops.. rotate it and that release the clips from the car.. then lift up and your a pillar is out
overhead console box
08' navigation system
Custom Shift Knob
DIY Dash
painted interior version 1.0
xB2 factory tint?...
Roll out the Dynamat :)
Gauge cluster led
Page generated in 0.29524 seconds with 13 queries
