08-13-2009, 11:12 PM
#1 | | The Punisher
| Headliner Does anyone know how to remove the headliner and how hard it will be? I am thinking about wapping it in black Seude.  |
08-13-2009, 11:30 PM
| Re: Headliner x2 I would like to do this as well, not sure about the suede, but i would like to wrap mine in black also |
08-14-2009, 11:56 AM
#3 | | The Punisher
| Re: Headliner Yeah, I've seen it done in other cars, it look good, but i will also have to wrap doors and i am going to paint pillers a high gloss piano black paint. also wrap seude on dark plastic in rear of car. under the c pillers. |
02-08-2010, 05:18 PM
| Re: Headliner does anyone know how to remove the sun visors im having a hard time taking them off |
02-08-2010, 08:28 PM
| Re: Headliner hopefully this can help you out. go on Scionlife on the xb2 forum, and under ice & interior, and serch under healiner removal and you will find one with a website that will help you out. sorry i cant post the actual link but i guess im not on the 30 count yet.
let me know if this helps you thou, im planing on doing this too. |
02-08-2010, 09:28 PM
#6 | | HELA FASS DOOO
| Re: Headliner xbgrl did her headliner and posted a bunch of info/pics that should get you started Sueding It Up
scvscions posted a bunch of DIY on how to remove the bits that hold the liner together Scion xB Interior - Scion xB Forum
I hope this helps  |
02-08-2010, 10:00 PM
#7 | | HELA FASS DOOO
| Re: Headliner |
02-08-2010, 10:37 PM
#8 | | HELA FASS DOOO
| Re: Headliner I do what I can  |
02-10-2010, 06:20 PM
#9 | | Registered Hater
| Re: Headliner Unless your planning something extensive or the material is unvailable in the size you need, headliner removal is not that complicated. And a little (actually a lot) of 3M adhesive spray will get just about any fabric/vinyl/felt/polyester/suede/leather/m&m's to stick.
What I have always like about customizing the headliner is it adds a crap load of detail to the interior for such a "simpler" single mod...
Maybe have it smoothed out and have a scene airbrushed on it. I would but I plan on adding the panoramic sunroof... |
03-01-2010, 05:24 PM
| Re: Headliner Xweapon, any idea on how much the sunroof addition would be? i was considering for mine as well...just never priced out.
other than that still need to get that headliner down to get 2 or 3 layers of fatmat up there. damn, these cars are loud |
03-08-2010, 02:50 PM
#11 | | "Vote Simpson in 08"
| Re: Headliner if your good with carving out things you could also do a logo and glue to headliner before wrapping for a raised 3d emblem! all you would need is some extra glue and probably 1/2 inch thick foam sheet?? |
03-08-2010, 04:13 PM
#12 | | Registered Hater
| Re: Headliner Quote:
Originally Posted by rswscion08 if your good with carving out things you could also do a logo and glue to headliner before wrapping for a raised 3d emblem! all you would need is some extra glue and probably 1/2 inch thick foam sheet?? |
I like the way you think...  |
03-10-2010, 02:05 AM
#13 | | Straight Creepin
| Re: Headliner 1/4" closed cell foam is better and bevel the edges of the design with sandpaper to a 45 degree for a smooth transition, or you could even use some fiberboard for a harder edge look...... oh and some patience too! |
