Make sure you remove all wax oil grease from body parts where kit is going to be installed.. Alocohol works great that every one should have.
rear and front. Steps..
After you prep the body now your ready to install.. test fit once again and using a crayon mark Kit and Body so you can align it prefect again when you put it back up.
Now your ready to prep the double sided tape.. it works best to work your way out from the middle. Cut the center with razor of the tape and lift up backing and bend it over 45deg angle so its get exposed when you place kit on body. whenon body and you lineup all the makes you just made with the crayon pull backingoff the tape and go slow and press down , the kit will stick.
after this step kit should be on now all you need to dois put the screws in .. you will need drill to this..
Now your ready for the side.. it basicly the same process again but you need to remove a peace thats in the front wheel well. there a bolt in the fender well and under the car .Keep bolt that came of becuase you will have to reuse it
