Old 09-26-2009, 11:31 PM   #1
SigTauGuy07 is on a distinguished road
caliper paint???
I want to paint my calipers but I'm not sure what kind of paint to use. I know it has to be heat resistant of course. Do I need primer? Do I need a clear or protection coat? What brands? Any hints or suggestions to make this easier?
SigTauGuy07 is offline   Reply With Quote
Old 09-26-2009, 11:41 PM   #2
Re: caliper paint???
Old 09-27-2009, 01:42 AM   #3
s9e9t9h
s9e9t9h's Avatar
s9e9t9h is on a distinguished road
I used G2 Caliper Paint.
Website: G2 - producer and distributor of the G2 BRAKE Caliper Paint System Set and other high quality carstyling and performance products.
Look at my signature and go to my car domain and look at some pics.
Click on the side view images and see if you think it turned out good. I actually painted mine orange. My brother used dupli-color and it seems to work great as well. Just make sure you use caliper paint because of the heat. Note: Most paints say you might have to re-paint them every 6 months. I don't think you will and it only took me about 8-10 hours to finish the project.
G2- 980 degress and around 45.00 dollars (has more color options)
Duplicolor- 500 degrees and around 20.00 dollars (can buy at auto zone)
s9e9t9h is offline   Reply With Quote
Old 09-27-2009, 01:45 AM   #4
elusive_xb
elusive_xb's Avatar
i used tri color brand or something.... i got it at autozone and it chips easy and i know i cleaned them good and i put tons of dry on dry coats
good luck
Old 09-27-2009, 10:19 PM   #5
did any one use primer, or just clean them up really well?
Old 09-27-2009, 11:37 PM   #6
s9e9t9h
s9e9t9h's Avatar
Cleaned them and used rubbing alcohol
Old 09-29-2009, 03:00 AM   #7
xtylerx's Avatar
xtylerx is on a distinguished road
I used the duplicolor kit. Just cleaned the calipers with brake clean. Haven't notices any chips or anything yet, but it's only been about a month.
xtylerx is offline   Reply With Quote
Old 10-29-2009, 09:27 PM   #8
azul box rollin on 18s
marty2495's Avatar
marty2495 is on a distinguished road
another paint you can use would be dupli-color engine anamel. its for high heat and looks great!
i would recommend a good cleaning and some primer just in case.
marty2495 is offline   Reply With Quote
Old 10-30-2009, 02:00 AM   #9
PDX_xB is on a distinguished road
I also used the G2 brake caliper kit. It's actually a two-part epoxy. It dries very hard and should last a LONG time. It comes with a can of brake cleaner. I went a little overboard on the cleaning (even though my car was only a month old - better safe than sorry) and had to buy another can of brake cleaner at Autozone.
I already posted these in another thread, but here's a couple shots of my finished calipers:
PDX_xB is offline   Reply With Quote
Old 10-30-2009, 05:07 AM   #10
Likes to party
xPartyx's Avatar
Old 10-30-2009, 10:56 AM   #11
u can acutally use base coat clear coat too thats whats on mine i just cleaned them real good n when i painted my xB i painted them with it and its been 8 months and mine has held up good no chips or anything
XB05 is offline   Reply With Quote
Who is making kits
Rumion mods
2008 Scion XB Bomex lip kit
Oem Wing
Aftermarket Grill?
Gen 2 Woody Kit!!!!!!
Shark Fin Antenna
Page generated in 0.19624 seconds with 14 queries
