Old 08-03-2009, 01:49 AM   #21
A_Snell is on a distinguished road
Re: 08+ XB rear wiper delete plug
Originally Posted by snkysnake View Post
Well I did the wiper delete today. I used a black nylon plug from Lowes.Here's a heads up, I originally went shopping for a 1 7/8s or 32 mm plug, as stated above. That is not the correct size for a 2009 XB RS6. I could not find a metal plug, as the size needed is somewhere between 1 inch and 1 1/8 . One inch metal being too small, and 1 1/8 being too big. The Black nylon 1 inch was a perfect fit.
It is a 1" hole. The reason why the 1" and 1/78" METAL plug will NOT work is because the metal plug has a ton of little "fingers" that hold it in. where as the nylon plug has 2 clips that stick out just a fraction more than the metal plug does. it's the extension of the slips that make the difference. I even tried spreading the clips(fingers) of the metal plug just a little to make it grab, but I couldn't make it work. the nylon plug "snapped" right into place.
A_Snell is offline   Reply With Quote
Old 08-04-2009, 09:30 AM   #22
supra tuner
PMSupra is on a distinguished road
Send a message via AIM to PMSupra
going to Lowe's to get mine. thanks for the info
PMSupra is offline   Reply With Quote
Old 08-26-2009, 10:31 PM   #23
Phobic is on a distinguished road
Send a message via AIM to Phobic
is there a DIY w/ pics on how to do this? wanna do this but kind nervous about it.
Phobic is offline   Reply With Quote
Old 09-01-2009, 04:59 PM   #24
Slody4Futbol is on a distinguished road
wow.. the plug is only $7.26 at the honda dealer.. all 3 of the local dealerships were out of stock on it though =( guess i'll have to get it next month when i'm home oh well
Slody4Futbol is offline   Reply With Quote
Old 10-02-2009, 10:17 PM   #25
so i ordered two.. one to paint and one to not paint.. anyone have any tips on getting paint to not crack when you press the plug into the hole? i got a small bottle of touch up paint and brushed it over the plug.. matched great.. but when i pressed it into the hole, the coat of paint on the plug split down the middle =(
Old 10-03-2009, 12:33 PM   #26
The touchup paint from the dealer, does it come in a spray can? Or in a small bottle with an applicator brush? Those who have the BSP xb are you using the touchup paint in a bottle or did you buy an aerosol spray? If so which color seems to match the best?
Old 10-03-2009, 03:22 PM   #27
xtylerx's Avatar
xtylerx is on a distinguished road
Has anyone heard of someone putting a rear-view cam in the wiper hole? If so, I'd be interested to see that.
xtylerx is offline   Reply With Quote
Old 10-04-2009, 02:33 AM   #28
there's a flush mount rear camera on ebay.. it requires a 1.25" hole though.. you'd have to widen the hole and then you could flush mount that camera in there.. i'm sure there are others out there that may be smaller, but that was the first i found
Who is making kits
Rumion mods
2008 Scion XB Bomex lip kit
Oem Wing
Aftermarket Grill?
Gen 2 Woody Kit!!!!!!
Shark Fin Antenna
Page generated in 0.29506 seconds with 13 queries
