| Re: Problems with the TRD rear sway anyone? I haven't yet got my hands on my xB, but I am considering using some TRD parts when I do start the mods. Did the TRD sway bar come with a packet of lithium grease, or other lubricant? Most sway bars should have a lubricant that needs to be applied to the bushings that hold the bar in place. If you don't lube those bushings, then as the bar rotates up & down, it will grind & growl.
I would start by checking the bushings for lube, and reapplying if need be. White lithium grease should work best, and is available at most any auto parts store for pretty cheap. (Under $5 for a small tube)
The annoying factor there is that you either need to get your car on a lift, or up on jack stands & shimmy under to check this.
Hope this helps. |
