I have a 08 xb and I wanna lower it with springs but I dunno if I should. I have 18' rims that I don't want to rub and I have so many speed bumps and even larger ones that are called speed humps. I don't think it would be a good idea to lower it. What do you think?
Rubbing also depends on the offset and tire size you're running on your wheels. I was riding the K Sports on bump stops up front tucking an inch of tire and not rubbing one bit on the stock steelies before "upgrading" to the TRD 19s which needed a good half inch of fender clearance to keep from rubbing.. Hotchkis sways help quite a bit with the cornering where most if any rubbing occured. I also have the coils set to extremely stiff
