Old 07-13-2008, 06:11 PM   #41
2008 XB
robertjcurrie's Avatar
robertjcurrie is on a distinguished road
Re: Hotchkis Sway Bars
I just had the Hotchkis TVS kit installed and I really like it....
robertjcurrie is offline   Reply With Quote
Old 09-24-2008, 10:16 PM   #42
FoGbOx is on a distinguished road
I autox my box so putting in Hotchkis Competition Set and Hotchkis Street Coil Spring Set greatly improved my ride. a little stiff but handles great going into hard corners
i bought it from TRDSPARKS . COM
cost me only $205.95 that is the best deal i found it anywhere.
please note that i have Competition Set and not regular Sport Set
second gen Sport set cost
$ 266.25
FoGbOx is offline   Reply With Quote
Old 09-25-2008, 09:57 AM   #43
Question, Most of the aftermarket Sways look like Pairs (other that the TRD). Are the Paired sets "tuned" if so I think I will spring for a paired set rather than just pop one in the rear end.
Old 09-26-2008, 09:12 PM   #44
Industrial Sports Box
TartanJack's Avatar
The TRD one is designed to work with the front sway ALREADY in the xB2.
The others are different designs and are sets that are designed to work together for a good balance.
Mixing front and rears is certainly possible, BUT only is a "good idea" IF you really know the various sway bars and are after a certain feel.
For everyone else, you are FAR more likely to make the xB handle freaky than to improve handling.
Oh, and I am planning to get the hotchkis sway set just as soon as I have enough cash and justifiable excuse to get.
It is a somewhat more "aggressive" set up than the TRD one, which is fine for 90% of xB drivers. The slightly bigger Hotchkis sways are what I am after.
Each sway set has its own designed-in pros and cons.
The TRD (stock front and rear addition) is a decent set up too.
Old 09-29-2008, 10:09 PM   #45
CrazyMPG is on a distinguished road
Hi,
This is probably a dumb quesiton, but since I am new to the xB I will ask it...heh Does a company make a chasis brace for this car or it doesn't even require one...
Thanks....runs off and hides...
CrazyMPG is offline   Reply With Quote
Old 10-23-2008, 04:27 PM   #46
Site Sponsor
I think that Tanabe was making a center brace for the 2nd gen. I think it came out, but am not sure.
Old 10-23-2008, 06:35 PM   #47
its what you do with it.
WhiteNoise's Avatar
There is this one: Scion 2008 xB Tanabe Under Brace|Tanabe Sustec Under Brace|Tanabe Suspension Systems seems a bit steep for what you get.
Old 12-21-2008, 05:53 PM   #48
vip_xb2's Avatar
vip_xb2 is on a distinguished road
Send a message via AIM to vip_xb2 Send a message via Yahoo to vip_xb2
does any one how much body roll is reduced from adding the sway bars ? and if so how much stifer does the ride get thanks
vip_xb2 is offline   Reply With Quote
Old 12-23-2008, 08:29 AM   #49
TartanJack's Avatar
First, you need some idea of what one is and what it does:
HowStuffWorks "How do stabilizer bars work?"
Sway bar - Wikipedia, the free encyclopedia
It does reduce body roll, but with the MAIN purpose of making the suspension components move less, and the wheels not move into odd positions as the vehicle corners.
Old 01-02-2009, 06:40 PM   #50
xB2 agent
scionkid's Avatar
scionkid is on a distinguished road
who else make sway bars for the 2nd gen? I got a scoop on the hotchkis that they are starting to break, so now im a little scared to get them. was fixing to hit the purchase link then had a lite go off I should ask someone at P-Tuning about these and they did not recomend them.
scionkid is offline   Reply With Quote
Old 01-07-2009, 12:11 AM   #51
Thumper_XBox is on a distinguished road
I have the Hotchkis install. Will this effect the warranty?
Thumper_XBox is offline   Reply With Quote
Old 01-07-2009, 04:55 AM   #52
Bench2 is on a distinguished road
Do you have any information on where the Hotchkis bars are breaking? Is it the front and/or rear bar?
Now I'm getting nervous...
Bench2 is offline   Reply With Quote
Old 03-10-2009, 10:14 PM   #53
NinSol is on a distinguished road
I have front and rear bars and i love them, I still have body roll but not as much as stock and I have no lowering springs. I've heard if you lower the B, the rear sway might snap.
NinSol is offline   Reply With Quote
Old 03-26-2009, 05:01 AM   #54
GRAFIK
grafik is on a distinguished road
I just got my sway bar set today...my question is how much better would it be to add a strut bar to the top front?
grafik is offline   Reply With Quote
Old 03-26-2009, 08:17 AM   #55
I make the assumption it would make a difference. Possibly a large one given the fact that there is nothing in the normal body that connects the top end of the shock mounts to make sure they stay equal distance apart and remove the "flex" of the body when put under stress.
Old 03-26-2009, 09:01 AM   #56
seppuku27's Avatar
Not alot of difference unless you really push it hard. But other wise it looks good when you pop the hood.
Old 04-12-2009, 12:07 AM   #57
Nonsense. That's simply not true.
Old 04-20-2009, 02:46 AM   #58
kimchiisbad is on a distinguished road
Sway bar will reduce the body roll and strut bar will have sharper turn-in. I have both and they work great together.
kimchiisbad is offline   Reply With Quote
Old 06-17-2009, 01:30 AM   #59
kostonjohn is on a distinguished road
Just installed my rear sway bar this weekend & I love it. I can actually take corners now w/o having to hold on to something :-) I can't wait to put the front one in about 2 weeks, I heard it makes the ride even more responsive. This will give me time to test out the rear more & to notice the difference between b4 & after the front sway bar.
kostonjohn is offline   Reply With Quote
Old 08-06-2009, 12:45 AM   #60
reb
reb is on a distinguished road
I see threads on the sway bars has anyone installed the stage one kit that has springs and sway bars? Other than price what is the handling difference between say a stage 1 kit and a coil over set up?
reb is offline   Reply With Quote
XB2 TRD rear sway bar
DF210's Installed W/ Pics
2nd Gen Air Bag Install
Hotchkis Sway Bars
tanabe df 210 I love them!!!
09 lowered on dubs
First dropped xB2
Lowering?
Page generated in 0.28285 seconds with 12 queries
